[GeoNode-users] Initial GeoNode account...
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Sep 1 00:52:02 PDT 2017
Hi, "geonode createsuperuser" (or python manage.py createsuperuser) is your
command.
Hope it helps
2017-08-31 22:23 GMT+02:00 Chris Jackson <webturtles at gmail.com>:
> Hi all
> I have managed to install GeoNode 2.6 successfully on a clean Azure W2016
> VM. I can log into Geoserver and can see the GeoNode homepage with sample
> datasets. Admittedly the installer is not quite 100% there, I had to
> manually add most the environment variables.
> Question I have is how do you set up the initial GeoNode admin user
> account, as it isn't covered as part of the install, and the Windows Binary
> Installer instructions don't cover it either. I am guessing it is a
> command line process?
> Thanks
> Chris
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170901/81a2d0fd/attachment.html>
More information about the geonode-users
