[GeoNode-users] Poor performance GeoNode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Sep 7 07:21:07 PDT 2017
Can you please better explain what you mean with "Map Performance" exactly?
Getting the list of layers or rendering the map?
Also, how many layers you have and which type (vectorial / raster) ?
Are you able to identify performance issues? Those are on GeoNode or
GeoServer?
In the first case it is certainly an issue of your HTTP Server
configuration (and most probably the proxy module), in the second case it
could be an issue of data not correctly processed.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Sep 7, 2017 at 8:54 AM, Ana Boljevic <ana.boljevic at cedis.me> wrote:
> Hi Angelos and John,
> Let me explain one more time, our performance issue. We have done fresh
> Geonode 2.6.2 installation (standard deployment), give VM 24GB RAM and 12
> CPU. After installation, we have done:
> 1) Replace OpenJVM with OracleJVM
> 2) We've increased the JVM memory by adding into /etc/default/tomcat7
> JAVA_OPTS="-Xmx12288M -Xms12288M -XX:MaxPermSize=1024M
> -XX:CompileCommand=exclude,net/sf/saxon/event/ReceivingContentHandler.
> startEvent"
> 3) Enable Native JAI and Native JAI ImageIO
> 4) Enable Tile caching into External PostgreSQL database
> Additionally, we have tried the following:
> 1) In /etc/tomcat7/server.xml added maxThreads="50":
>   <Connector port="8080" protocol="HTTP/1.1"
>                connectionTimeout="20000"
>                URIEncoding="UTF-8"
>                redirectPort="8443" maxThreads="50"/>
> 2) In /etc/apache2/mods-enabled/mpm_event.conf
> try to change conf parameters with no results:
> <IfModule mpm_event_module>
>         StartServers                     2
>         MinSpareThreads          25
>         MaxSpareThreads          75
>         ThreadLimit                      64
>         ThreadsPerChild          25
>         MaxRequestWorkers         150
>         MaxConnectionsPerChild   0
> </IfModule>
> Still, when 4-5 clients try to render maps, performance radically decrease
> and geonode become unresponsive.
> Do you have any idea how to increse performance ?
> Best regards,
> Ana Boljevic
> *From:* John Jediny [john.jediny at gmail.com]
> *Sent:* Saturday, September 02, 2017 3:32 AM
> *To:* Angelos Tzotsos
> *Cc:* Ana Boljevic; geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] Poor performance GeoNode
> apache2 mod_wsgi needs tuning. Add workers and up memory limits per worker
> On Fri, Sep 1, 2017 at 3:56 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
> wrote:
>> You need to add more workers on your WSGI server.
>> Best,
>> Angelos
>> On 08/29/2017 11:43 AM, Ana Boljevic wrote:
>> Dear Geonode Community,
>> We have installed fresh Geonode v2.6.2 on Ubuntu Server 16.04. In order to speed up system, we gave Geonode 24GB of RAM and 12 CPU. Unfortulnally, performance are still poor. Apart from basic installation (standard, not developement deployment) we have done:
>> 1) Replace OpenJVM with OracleJVM (see attachment geoserver.png)
>> JAVA_OPTS="-Djava.awt.headless=true -Xms6144m -Xmx6144m -XX:+UseParallelOldGC -XX:+UseParallelGC -XX:NewRatio=2 -XX:+AggressiveOpts -Xrs -XX:PerfDataSamplingInterval=500 -XX:MaxPermSize=512m"
>> For some reason, Server is not consuming memory no mater how many clients are requesting maps. There is always more than 16GB free memory (attachment free.jpg).
>> If you can give as any hint, idea or help, we would be thankful.
>> Regards,
>> Ana Boljevic
>> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-users
>> Angelos Tzotsos, PhD
>> Charter Member
>> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
> Cell: 973-931-0580
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170907/4a337f56/attachment-0001.html>
More information about the geonode-users mailing list
