[GeoNode-users] Getfeatureinfo list - display order
Naresh N naresh919 at gmail.com
Tue Sep 12 03:30:43 PDT 2017
Dear Alessio,
  Thanks a lot for quick response.* Even order change of attributes is not
reflecting in  GeoNode Attribute Tab on the Layer Details.  Is any setting
need to be enable?*
In case ,shapefile have large no of attributes, on click of it ,it will
show the all the attributes. This may not be good to display all the
attributes.If user has option  from  GeoNode GUI to select list of
attributes for display  and including order of the display, it will be good
facility for the users.
Please  kindly include this option in newer version of GeoNode.
Thanks&Regards,
Naresh
On Tue, Sep 12, 2017 at 3:32 PM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Naresh,
> currently, as far as I know, that stuff is applied only to the GeoNode
> GetFeatureInfo request is currently issued directly to GeoServer. There's
> no automatic or trivial way to do what you are requesting.
> It can be implemented, but this would be a new feature of GeoNode.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054  Massarosa
> (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Sep 12, 2017 at 11:59 AM, Naresh N <naresh919 at gmail.com> wrote:
>> Dear Alessio,
>>   Thanks for responding. End user will not have access of creating
>> ftl(feature template) and uploading into geoserver workspace.  I think, for
>> this reason GeoNode has  option for  changing the ordering of display
>> attributes including label name using Metadata Graphical user Interface.
>> Please find the attache screenshot. Please verify once , suggest me to
>> overcome the issue.
>> Thanks&Regards,
>> Naresh. N
>> On Tue, Sep 12, 2017 at 1:05 PM, Alessio Fabiani <
>>> Hi Naresh,
>>> you can try to use GeoServer custom featureinfo templates. For more
>>> information take a look here
>>> http://docs.geoserver.org/latest/en/user/tutorials/GetFeatur
>>> eInfo/index.html
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> 55054  Massarosa
>>> (LU)
>>> Italy
>>> phone: +39 0584 962313 <0584%20962313>
>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>> mob:   +39 331 6233686 <331%20623%203686>
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Tue, Sep 12, 2017 at 7:59 AM, Naresh N <naresh919 at gmail.com> wrote:
>>>> Dear All,
>>>>  Kindly suggest some alternative for  my query.
>>>> Thanks&Regards,
>>>> Naresh
>>>> On Mon, Sep 11, 2017 at 3:34 PM, Naresh N <naresh919 at gmail.com> wrote:
>>>>> Dear All,
>>>>>  I have used MetaData option and *changed the order of the display of
>>>>> attributes, on click of the feature(getfetureinfo) display order is
>>>>> not reflected*.
>>>>> I have also tried in demo portal . I have  changed the order of the
>>>>> display of attributes , but on getfeatureinfo the display order is not
>>>>> reflected
>>>>> Please visit the following link and select the info icon,feature
>>>>> http://demo.geonode.org/layers/hr1%3Ashape_first_1
>>>>> Kindly suggest, how to over come above.
>>>>> *Is it possible to display few attributes of shapefile on click of
>>>>> getfeatureinfo ?*
>>>>> Thanks&Regards,
>>>>> Naresh. N
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170912/3f3f78ca/attachment-0001.html>
More information about the geonode-users mailing list
