[GeoNode-users] Poor performance GeoNode
Ana Boljevic
ana.boljevic at cedis.me
Thu Sep 14 03:29:59 PDT 2017
Dear John,
We have in-house server on the corporate LAN (100Mbps). We have tested bandwidth speed with iperf. We have started iperf on 4 Windows clients and on Ubuntu/GeoNode Server. Every time all clients are sharing 100Mbps (cca 25Mbps per client). So, we think it is not the network issue.
We have installed fresh Geonode v2.6.2 on Ubuntu Server 16.04. In order to speed up system, we gave Geonode 24GB of RAM and 12 CPU. Virtualization platform is Oracle VM.
In the moment when performance decrease, a server eats only 6-7GB of RAM (free is 17-18GB of RAM) and load average is about 7.
We have enabled GeoWebCache by doing the following:
- Caching to external postgresql database
Tile caching - Disk quota....Enable disk Quota ....Maximum tile cache size 50GiB
Disk quota check frequency:600s
Disk quota store type....External database
Target database type....PostgreSQL
JDBC data source...GeoServer managed connection pool
JDBC Driver class name.....org.postgresql.Driver
JDBC connection URL.....jdbc:postgresql://localhost:5432/geonode
User name..... geonode
Password.... ******
Validation query.....select 1
sudo service tomcat7 stop
sudo service apache2 stop
mkdir /var/cache/geoserver
chmod -R 777 geoserver
In:
vi /usr/share/geoserver/WEB-INF/web.xml
added:
<context-param>
<param-name>GEOWEBCACHE_CACHE_DIR</param-name>
<param-value>/var/cache/geoserver/</param-value>
</context-param>
sudo reboot
Here is the link of our map containing 140 internal layers (without external WMS layers) during heavy rendering of 4 clients:
https://www.dropbox.com/s/2ncig40ee0i0ybo/2017-09-14-12-08-17.mp4?dl=0
During online connection of Mr. Alessio Fabiani, he has made following changes:
-Geofence:
Size of the raw cache:600000
Cache refewsh interval: 600000
Cache expire interval: 600000
-Disk Quota:
Disk Quota check frequency : 600
Max.connections: 20
- Store - datastore:
max connections: 50
min connections: 10
fetch size : 100000
-WCS: Overview policy: Closest overview
Regards,
Ana
On 9/13/2017 11:44 PM, John Jediny wrote:
Are you running it on a cloud service provider or in-house? this seems like a network latency issue at first watch. Can you share the specs of the operating systems/machines (e.g. VM/containers) being used for total CPU/RAM/Network?
On Fri, Sep 8, 2017 at 3:11 AM, Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> wrote:
Hi Alessio,
Please receive screen video recording link, so you can see by yourself what do we mean by "Poor Performance".
https://www.dropbox.com/s/2ai2n8764p1ny9n/2017-09-08-08-38-33.flv?dl=0
This recording was taken during of heavy map rendering of 4 clients. We have 144 vector layers and 2 external WMS layers (behaviour is the same when we don't use WMS layers. In video link, we have used only local vector layers, not external WMS layers). We are not experienced enough to know what does cause the issue (GeoNode or GeoServer).
Please reveive one typical kml layer in the attachment.
Regards,
Ana Boljevic
From: Alessio Fabiani [alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>]
Sent: Thursday, September 07, 2017 4:21 PM
To: Ana Boljevic
Cc: John Jediny; Angelos Tzotsos; geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] Poor performance GeoNode
Can you please better explain what you mean with "Map Performance" exactly?
Getting the list of layers or rendering the map?
Also, how many layers you have and which type (vectorial / raster) ?
Are you able to identify performance issues? Those are on GeoNode or GeoServer?
In the first case it is certainly an issue of your HTTP Server configuration (and most probably the proxy module), in the second case it could be an issue of data not correctly processed.
Regards,
Alessio Fabiani
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Alessio Fabiani
@alfa7691 Founder/Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy phone: +39 0584 962313<tel:+39%200584%20962313> fax: +39 0584 1660272<tel:+39%200584%20166%200272> mob: +39 331 6233686<tel:+39%20331%20623%203686> http://www.geo-solutions.it http://twitter.com/geosolutions_it -------------------------------------------------------
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Thu, Sep 7, 2017 at 8:54 AM, Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> wrote:
Hi Angelos and John,
Let me explain one more time, our performance issue. We have done fresh Geonode 2.6.2 installation (standard deployment), give VM 24GB RAM and 12 CPU. After installation, we have done:
1) Replace OpenJVM with OracleJVM
2) We've increased the JVM memory by adding into /etc/default/tomcat7
JAVA_OPTS="-Xmx12288M -Xms12288M -XX:MaxPermSize=1024M -XX:CompileCommand=exclude,net/sf/saxon/event/ReceivingContentHandler.startEvent"
3) Enable Native JAI and Native JAI ImageIO
4) Enable Tile caching into External PostgreSQL database
Additionally, we have tried the following:
1) In /etc/tomcat7/server.xml added maxThreads="50":
<Connector port="8080" protocol="HTTP/1.1"
connectionTimeout="20000"
URIEncoding="UTF-8"
redirectPort="8443" maxThreads="50"/>
2) In /etc/apache2/mods-enabled/mpm_event.conf
try to change conf parameters with no results:
<IfModule mpm_event_module>
StartServers 2
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
MaxRequestWorkers 150
MaxConnectionsPerChild 0
</IfModule>
Still, when 4-5 clients try to render maps, performance radically decrease and geonode become unresponsive.
Do you have any idea how to increse performance ?
Best regards,
Ana Boljevic
From: John Jediny [john.jediny at gmail.com<mailto:john.jediny at gmail.com>]
Sent: Saturday, September 02, 2017 3:32 AM
To: Angelos Tzotsos
Cc: Ana Boljevic; geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
apache2 mod_wsgi needs tuning. Add workers and up memory limits per worker
On Fri, Sep 1, 2017 at 3:56 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com<mailto:gcpp.kalxas at gmail.com>> wrote:
You need to add more workers on your WSGI server.
Best,
Angelos
On 08/29/2017 11:43 AM, Ana Boljevic wrote:
Dear Geonode Community,
We have installed fresh Geonode v2.6.2 on Ubuntu Server 16.04. In order to speed up system, we gave Geonode 24GB of RAM and 12 CPU. Unfortulnally, performance are still poor. Apart from basic installation (standard, not developement deployment) we have done:
1) Replace OpenJVM with OracleJVM (see attachment geoserver.png)
JAVA_OPTS="-Djava.awt.headless=true -Xms6144m -Xmx6144m -XX:+UseParallelOldGC -XX:+UseParallelGC -XX:NewRatio=2 -XX:+AggressiveOpts -Xrs -XX:PerfDataSamplingInterval=500 -XX:MaxPermSize=512m"
For some reason, Server is not consuming memory no mater how many clients are requesting maps. There is always more than 16GB free memory (attachment free.jpg).
If you can give as any hint, idea or help, we would be thankful.
Regards,
Ana Boljevic
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
Cell: 973-931-0580<tel:%28973%29%20931-0580>
Cell: 973-931-0580
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170914/6afdbe28/attachment-0001.html>
More information about the geonode-users
