[GeoNode-users] geoserver error
Vicente deluca.vicente at gmail.com
Thu Sep 28 08:52:56 PDT 2017
Sorry, maybe this is off-topic, my question is, Does removes some
projection stuff when I delete the admin (default) user?
The geoserver log error says
2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'raster'
2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'point'
2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'line'
2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'polygon'
2017-09-28 10:16:59,003 INFO [org.geoserver] - Loaded default workspace
geonode
2017-09-28 10:16:59,005 INFO [org.geoserver] - Loaded workspace 'geonode'
2017-09-28 10:16:59,294 WARN [referencing.factory] - Unavailable authority
factory: European Petroleum Survey Group
2017-09-28 10:16:59,295 WARN [referencing.factory] - Unavailable authority
2017-09-28 10:16:59,296 WARN [referencing.factory] - Unavailable authority
2017-09-28 10:16:59,301 WARN [referencing.factory] - Unavailable authority
2017-09-28 10:16:59,302 WARN [referencing.factory] - Unavailable authority
2017-09-28 10:16:59,303 WARN [referencing.factory] - Unavailable authority
2017-09-28 10:16:59,308 WARN [support.DisposableBeanAdapter] - Invocation
of destroy method failed on bean with name 'importer':
java.lang.NullPointerException
2017-09-28 10:16:59,309 WARN [support.DisposableBeanAdapter] - Invocation
of destroy method failed on bean with name 'geoServerLoader':
2017-09-28 10:16:59,310 ERROR [context.ContextLoader] - Context
initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'kmlFormat' defined in URL
[jar:file:/var/www/geo/httpdocs/geonode/geoserver/geoserver/WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]:
Instantiation of bean failed; nested
Another thing I did was add a kml file, but it looked fine!
Some of the two things broke something in the geoserver.
Thank you!
On Wed, Sep 27, 2017 at 8:54 PM, Vicente <deluca.vicente at gmail.com> wrote:
> Hi,
> the #paver start command throws the following error,
> Error creating bean with name 'kmlFormat' defined in URL
> [jar:file:/var/www/{...}/geoserver/geoserver/WEB-INF/
> exception is java.lang.ExceptionInInitializerErro
> I think it might have happened after removing some admin users from
> geonode. It's possible?
> I added them again but the problem persists, I do not want to lose the
> information already loaded in the geoserver.
> Thank you!
> [image: MANTA] <http://www.estudiomanta.com/>
> Vicente Deluca
> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
Vicente Deluca
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170928/02a63b63/attachment-0001.html>
More information about the geonode-users mailing list
