[GeoNode-users] geoserver error
Paolo Corti
pcorti at gmail.com
Thu Sep 28 12:55:46 PDT 2017
According to your previous log (the first file), that was causing the
error which prevented GeoServer to start ("java.net.BindException:
Address already in use").
In this log you have attached now, I still see you are using
default minimal RAM parameters:
OpenJDK Runtime Environment (IcedTea 2.6.11) (7u151-2.6.11-1+deb7u1)
OpenJDK 64-Bit Server VM (build 24.151-b01, mixed mode)
java -Xmx512m -XX:MaxPermSize=256m -
Please try to use higher values and see if the error replicates
p
On Thu, Sep 28, 2017 at 3:24 PM, Vicente <deluca.vicente at gmail.com> wrote:
> Geoserver on 8080?
> I modified the jetty starter on pavement.py to run on 8082, just like the
> local_settyngs.py file and it worked perfect.
> It now runs on 8084 and the problem persists
> I think that's not the problem
> On Thu, Sep 28, 2017 at 4:01 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> According to first log, GeoServer is not starting because there is already
>> a process running on 8080.
>> Make sure to run "paver stop" before running again "paver start" and send
>> the log of it if still failing
>> cheers
>> p
>> On Thu, Sep 28, 2017 at 2:51 PM, Vicente <deluca.vicente at gmail.com> wrote:
>>> I attach two log files, one is the output of the paver start command, the
>>> other is the log of the geoserver/data/logs/geoserver.log folder
>>> I increased the memory in the command line that runs the jetty and the
>>> problem persists.
>>> The command line running the jetty worked perfectly until yesterday
>>> thks!
>>> On Thu, Sep 28, 2017 at 3:20 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>>> Could you attach a larger portion of the log? From here it is not clear
>>>> that this error is the cause of GeoServer not being able to start.
>>>> Generally when I see bean errors most of the time is because the Java
>>>> process of the container of GeoServer (Tomcat or Jetty) is lacking RAM.
>>>> Having a lot of RAM in the server doesn't mean that it will be correctly
>>>> used by GeoServer, as it must be optimized (by default the GeoServer which
>>>> comes with GeoNode is using parameters which are not ideal for production):
>>>> http://docs.geoserver.org/latest/en/user/production/container.html
>>>> regards
>>>> p
>>>> On Thu, Sep 28, 2017 at 12:17 PM, Vicente <deluca.vicente at gmail.com>
>>>> wrote:
>>>>> Please, look at these error lines. Do not they tell you anything?
>>>>> Caused by: java.lang.RuntimeException: Could not decode: EPSG: 4326
>>>>> at org.geoserver.importer.format.KMLFileFormat. <clinit>
>>>>> (KMLFileFormat.java:65)
>>>>> ... plus
>>>>> Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No
>>>>> "EPSG: 4326" code from the "European Petroleum Survey Group" authority found
>>>>> for the "IdentifiedObject" object.
>>>>> On Thu, Sep 28, 2017 at 1:15 PM, Vicente <deluca.vicente at gmail.com>
>>>>> wrote:
>>>>>> yes, I have 8GB, memory is not the problem
>>>>>> Then it must be the kml that I loaded
>>>>>> I'm ready to make a flush, could this solve it?
>>>>>> On Thu, Sep 28, 2017 at 1:03 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>>>>>> They are warnings and I don't think they are causing GeoServer to
>>>>>>> fail.
>>>>>>> For sure deleting the default admin GeoNode users won't cause this
>>>>>>> kind of problem.
>>>>>>> Are you running GeoServer with enough memory?
>>>>>>> p
>>>>>>> On Thu, Sep 28, 2017 at 11:52 AM, Vicente <deluca.vicente at gmail.com>
>>>>>>> wrote:
>>>>>>>> Sorry, maybe this is off-topic, my question is, Does removes some
>>>>>>>> projection stuff when I delete the admin (default) user?
>>>>>>>> The geoserver log error says
>>>>>>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'raster'
>>>>>>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'point'
>>>>>>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'line'
>>>>>>>> 'polygon'
>>>>>>>> 2017-09-28 10:16:59,003 INFO [org.geoserver] - Loaded default
>>>>>>>> workspace geonode
>>>>>>>> 2017-09-28 10:16:59,005 INFO [org.geoserver] - Loaded workspace
>>>>>>>> 'geonode'
>>>>>>>> 2017-09-28 10:16:59,294 WARN [referencing.factory] - Unavailable
>>>>>>>> authority factory: European Petroleum Survey Group
>>>>>>>> 2017-09-28 10:16:59,295 WARN [referencing.factory] - Unavailable
>>>>>>>> 2017-09-28 10:16:59,296 WARN [referencing.factory] - Unavailable
>>>>>>>> 2017-09-28 10:16:59,301 WARN [referencing.factory] - Unavailable
>>>>>>>> 2017-09-28 10:16:59,302 WARN [referencing.factory] - Unavailable
>>>>>>>> 2017-09-28 10:16:59,303 WARN [referencing.factory] - Unavailable
>>>>>>>> 2017-09-28 10:16:59,308 WARN [support.DisposableBeanAdapter] -
>>>>>>>> Invocation of destroy method failed on bean with name 'importer':
>>>>>>>> java.lang.NullPointerException
>>>>>>>> 2017-09-28 10:16:59,309 WARN [support.DisposableBeanAdapter] -
>>>>>>>> Invocation of destroy method failed on bean with name 'geoServerLoader':
>>>>>>>> 2017-09-28 10:16:59,310 ERROR [context.ContextLoader] - Context
>>>>>>>> initialization failed
>>>>>>>> org.springframework.beans.factory.BeanCreationException: Error
>>>>>>>> creating bean with name 'kmlFormat' defined in URL
>>>>>>>> [jar:file:/var/www/geo/httpdocs/geonode/geoserver/geoserver/WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]:
>>>>>>>> Instantiation of bean failed; nested
>>>>>>>> Another thing I did was add a kml file, but it looked fine!
>>>>>>>> Some of the two things broke something in the geoserver.
>>>>>>>> Thank you!
>>>>>>>> On Wed, Sep 27, 2017 at 8:54 PM, Vicente <deluca.vicente at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hi,
>>>>>>>>> the #paver start command throws the following error,
>>>>>>>>> Error creating bean with name 'kmlFormat' defined in URL
>>>>>>>>> [jar:file:/var/www/{...}/geoserver/geoserver/WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]:
>>>>>>>>> exception is java.lang.ExceptionInInitializerErro
>>>>>>>>> I think it might have happened after removing some admin users from
>>>>>>>>> geonode. It's possible?
>>>>>>>>> I added them again but the problem persists, I do not want to lose
>>>>>>>>> the information already loaded in the geoserver.
>>>>>>>>> Thank you!
>>>>>>>>> Vicente Deluca
>>>>>>>>> +54 11 6091 4579
>>>>>>>> Vicente Deluca
>>>>>>>> +54 11 6091 4579
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> Paolo Corti
>>>>>>> Geospatial software developer
>>>>>>> web: http://www.paolocorti.net
>>>>>>> twitter: @capooti
>>>>>>> skype: capooti
>>>>>> Vicente Deluca
>>>>>> +54 11 6091 4579
>>>>> Vicente Deluca
>>>>> +54 11 6091 4579
>>>> Paolo Corti
>>>> twitter: @capooti
>>>> skype: capooti
>>> Vicente Deluca
>>> +54 11 6091 4579
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
> Vicente Deluca
> +54 11 6091 4579
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users
