[GeoNode-users] Package install errors from Ubuntu clean install
Jones, Peter
plj2 at wustl.edu
Sat Apr 14 16:35:27 PDT 2018
Hello, I've been following the instructions for an Ubuntu quick start install. This is a clean install. Everything works until I sudo apt-get install geonode. I've pasted the system info and errors below. What's the best way to proceed with the standard install?
Thanks for any insight! Peter
uname -a
Linux stirrgeonode 4.4.0-116-generic #140-Ubuntu SMP Mon Feb 12 21:23:04 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.4 LTS
Release: 16.04
Codename: xenial
Setting up tomcat8 (8.0.32-1ubuntu1.5) ...
Creating config file /etc/default/tomcat8 with new version
Adding system user `tomcat8' (UID 113) ...
Adding new user `tomcat8' (UID 113) with group `tomcat8' ...
Not creating home directory `/usr/share/tomcat8'.
Creating config file /etc/logrotate.d/tomcat8 with new version
Setting up tomcat8-admin (8.0.32-1ubuntu1.5) ...
Setting up geoserver-geonode (2.12.2-4) ...
Setting up geonode (2.8.0+thefinal0) ...
Sourcing /usr/share/geonode/config-post.sh as the configuration file
Step: 'once specified
Running GeoNode initial configuration ...
CREATE EXTENSION
CREATE ROLE
Step: 'post specified
Running GeoNode postinstall ...
File "/usr/bin/pip", line 9, in <module>
from pip import main
ImportError: cannot import name main
File "<string>", line 1, in <module>
ImportError: No module named geonode
File "/usr/bin/django-admin", line 9, in <module>
load_entry_point('Django==1.8.19', 'console_scripts', 'django-admin')()
File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
utility.execute()
File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 303, in execute
settings.INSTALLED_APPS
File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 48, in __getattr__
self._setup(name)
File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 44, in _setup
self._wrapped = Settings(settings_module)
File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 92, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
__import__(name)
ImportError: No module named geonode.settings
utility.execute()
self._setup(name)
__import__(name)
utility.execute()
self._setup(name)
__import__(name)
utility.execute()
self._setup(name)
__import__(name)
utility.execute()
self._setup(name)
__import__(name)
utility.execute()
self._setup(name)
__import__(name)
utility.execute()
self._setup(name)
__import__(name)
utility.execute()
self._setup(name)
__import__(name)
Site 000-default disabled.
To activate the new configuration, you need to run:
service apache2 reload
Considering dependency proxy for proxy_http:
Enabling module proxy.
Enabling module proxy_http.
service apache2 restart
Enabling site geonode.
Step: 'setup_apache_once specified
Configuring Apache ...
Module proxy already enabled
Module proxy_http already enabled
Replacing SITEURL value with 'localhost' in /etc/geonode/local_settings.py ... done.
Adding entry for 'localhost' in /usr/share/geoserver/data/printing/config.yaml ... 'localhost' already found to the printing whitelist.
utility.execute()
self._setup(name)
__import__(name)
Setting up oauth
/usr/sbin//geonode-updateip: line 154: restart: command not found
Waiting Tomcat Service to Restart...
Waiting Apache HTTPD Service to Restart...
utility.execute()
self._setup(name)
__import__(name)
utility.execute()
self._setup(name)
__import__(name)
dpkg: error processing package geonode (--configure):
subprocess installed post-installation script returned error exit status 1
Processing triggers for libc-bin (2.23-0ubuntu10) ...
Processing triggers for systemd (229-4ubuntu21.2) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for libgdk-pixbuf2.0-0:amd64 (2.32.2-1ubuntu1.4) ...
Processing triggers for ca-certificates (20170717~16.04.1) ...
Updating certificates in /etc/ssl/certs...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
done.
Errors were encountered while processing:
geonode
E: Sub-process /usr/bin/dpkg returned an error code (1)
Peter Jones
Programmer II, Department of Psychiatry
Washington University School of Medicine in St. Louis
660 South Euclid Avenue, Box 8134
St. Louis, MO 63130
e-mail: PLJ2 at WUSTL.EDU | pronouns: he/him/his
The materials in this message are private and may contain Protected Healthcare Information or other information of a sensitive nature. If you are not the intended recipient, be advised that any unauthorized use, disclosure, copying or the taking of any action in reliance on the contents of this information is strictly prohibited. If you have received this email in error, please immediately notify the sender via telephone or return mail.
More information about the geonode-users
