[GeoNode-users] Stable ppa throws an ImportError during GeoNode postinstall
Dave Kennewell
davekennewell at gmail.com
Tue Apr 17 07:35:26 PDT 2018
Yup, that does indeed solve it - thanks, at least I'm back online now.
But I'm still nervous about what's changed and any side-effects this might
create.
Anyone have thoughts as to the root cause here?
On 17 April 2018 at 18:23, Federico Gianoli <alpacagis at gmail.com> wrote:
> Hi Dave,
> have you tried to re-run " sudo apt-get install geonode" ?
> regards
> Federico
> 2018-04-17 16:17 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
>> Hi all,
>> I've started new thread so this doesn't get lost, but it follows on from
>> Elton's issues in the "Geonode 2.8.0 is out!" thread.
>> I just ran an install script that is usually super-dependable, and got
>> the same error as Elton when the script runs "sudo apt-get install
>> geonode". I'm using the stable ppa on Ubuntu 16.04 (clean EC2 image).
>> Here is the log output:
>> Creating config file /etc/logrotate.d/tomcat8 with new version
>> Setting up tomcat8-admin (8.0.32-1ubuntu1.5) ...
>> Setting up geoserver-geonode (2.12.2-4) ...
>> Setting up geonode (2.8.0+thefinal0) ...
>> Sourcing /usr/share/geonode/config-post.sh as the configuration file
>> Step: 'once specified
>> Running GeoNode initial configuration ...
>> CREATE EXTENSION
>> CREATE ROLE
>> Step: 'post specified
>> Running GeoNode postinstall ...
>> Traceback (most recent call last):
>> File "/usr/bin/pip", line 9, in <module>
>> from pip import main
>> ImportError: cannot import name main
>> File "<string>", line 1, in <module>
>> ImportError: No module named geonode
>> File "/usr/bin/django-admin", line 9, in <module>
>> load_entry_point('Django==1.8.19', 'console_scripts', 'django-admin')()
>> File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
>> utility.execute()
>> File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 303, in execute
>> settings.INSTALLED_APPS
>> File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 48, in __getattr__
>> self._setup(name)
>> File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 44, in _setup
>> self._wrapped = Settings(settings_module)
>> File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 92, in __init__
>> mod = importlib.import_module(self.SETTINGS_MODULE)
>> File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
>> __import__(name)
>> ImportError: No module named geonode.settings
>> Is anyone else experiencing this issue with the stable apt-get install?
>> thanks
>> Dave
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180417/78a8cbd8/attachment.html>
More information about the geonode-users
