[GeoNode-users] Example GeoNode Proxy Set Up With Virtual Machines
Jones, Peter
plj2 at wustl.edu
Wed Apr 18 09:37:58 PDT 2018
Hello, Thank you for creating GeoNode. We’ve gotten an instance up and running, and I thought I’d send out a very brief summary of our configuration. We made use of the GeoNode Quickstart and GeoNode SSL tutorials.
Peter
* This configuration is just for testing. A production configuration would need verified SSL certificates from some trusted organization. *
We have 1 Physical Machine with 2 Virtual Machines.
The Physical Machine controls the firewall and sends traffic to virtual machine 1.
Virtual Machine 1 runs Apache and directs relevant requests to Virtual Machine 2.
Virtual Machine 2 is our new instance of GeoNode with SSL. We use https in the virtual bridge to avoid interception by other virtual machines.
############## BEGIN Physical Machine #########################
CentOS
outside ip address 111.112.113.114
qemu libvirt
virtual bridge ip address 192.168.122.1
iptables sends port 80 and 443 to Virtual Machine 1
##BEGIN EXCERPT Physical Machine /etc/sysconfig/iptables
-A PREROUTING -d 111.112.113.114/32 -p tcp -m tcp --dport 80 -j DNAT --to-destination 192.168.122.123:80
-A PREROUTING -d 111.112.113.114/32 -p tcp -m tcp --dport 443 -j DNAT --to-destination 192.168.122.123:443
-A PREROUTING -d 127.0.0.1/32 -p tcp -m tcp --dport 80 -j DNAT --to-destination 192.168.122.123:80
-A PREROUTING -d 127.0.0.1/32 -p tcp -m tcp --dport 443 -j DNAT --to-destination 192.168.122.123:443
##END EXCERPT Physical Machine /etc/sysconfig/iptables
#######BEGIN Virtual Machine #1 #####
CentOS
ip address 192.168.122.123
Virtual Machine 1 Controls Apache instance to the outside world.
Routes traffic to Virtual Machine #2
##BEGIN EXCERPT Virtual Machine #1 /etc/hosts
192.168.122.234 geonode.foo.bar.com
##END EXCERPT Virtual Machine #1 /etc/hosts
##BEGIN EXCERPT Virtual Machine #1 /etc/httpd/conf.d/z.geonode.foo.bar.com.conf
<VirtualHost *:443>
ServerName geonode.foo.bar.com
ErrorLog logs/geonode_error_log
TransferLog logs/geonode_access_log
LogLevel debug
SSLEngine on
SSLProxyEngine on
SSLProtocol all -SSLv2
SSLProxyCheckPeerName off
SSLProxyCheckPeerCN off
SSLCertificateFile /etc/pki/tls/certs/localhost.crt
SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
ProxyPass / https://geonode.foo.bar.com/
ProxyPassReverse / https://geonode.foo.bar.com/
ProxyPass / http://geonode.foo.bar.com/
SetEnvIf Request_URI .*admin/.* denyadmin
<Location />
<Limit GET POST PUT>
Order deny,allow
deny from env=denyadmin
Allow from 127.0.0.1
Allow from 128.252.246.0/255.255.255.0
</Limit>
</Location>
<Directory proxy:>
Order Deny,Allow
Allow from all
</Directory>
</VirtualHost>
<VirtualHost *:80>
Redirect permanent / https://geonode.foo.bar.com/
</VirtualHost>
##END EXCERPT Virtual Machine #1 /etc/httpd/conf.d/z.geonode.foo.bar.com.conf
#######END Virtual Machine #1 #####
###### BEGIN Virtual Machine #2 #####
A standard GeoNode installation with Ubuntu LTS
ip address 192.168.122.234
Used GeoNode Quick Installation Instructions here:
http://docs.geonode.org/en/master/tutorials/install_and_admin/quick_install.html
Used GeoNode SSL Instructions Here:
http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/ssl.html
##BEGIN EXCERPT Virtual Machine #2 /etc/hosts
127.0.0.1 geonode.foo.bar.com localhost
##BEGIN EXCERPT Virtual Machine #2 /etc/apache2/sites-available/geonode.conf
<IfModule mod_ssl.c>
<VirtualHost _default_:443>
Servername localhost
ServerAlias 127.0.0.1
ServerAlias 192.168.122.234
ServerAlias geonode.foo.bar.com
#STANDARD GEONODE TAGS HERE#
ProxyPreserveHost On
ProxyPass /geoserver http://localhost:8080/geoserver
ProxyPassReverse /geoserver http://localhost:8080/geoserver
SSLEngine on
SSLCertificateFile /etc/ssl/certs/geonode.crt
SSLCertificateKeyFile /etc/ssl/private/geonode.key
BrowserMatch "MSIE [2-6]" \
nokeepalive ssl-unclean-shutdown \
downgrade-1.0 force-response-1.0
# MSIE 7 and newer should be able to use keepalive
BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
</VirtualHost>
</IfModule>
<VirtualHost *:80>
</VirtualHost>
##END EXCERPT Virtual Machine #2 /etc/apache2/sites-available/geonode.conf
##BEGIN EXCERPT Virtual Machine #2 /etc/tomcat8/server.xml
proxyName="192.168.122.234"
##END EXCERPT Virtual Machine #2 /etc/tomcat8/server.xml
##BEGIN EXCERPT Virtual Machine #2 /etc/geonode/local_settings.py
SITEURL = 'https://geonode.foo.bar.com/'
PROXY_ALLOWED_HOSTS = ['127.0.0.1','192.168.122.234','geonode.foo.bar.com','localhost', '::1']
#ALLOWED_HOSTS = [urlparse(SITEURL).hostname] if os.getenv('ALLOWED_HOSTS') is None \
# else re.split(r' *[,|:|;] *', os.getenv('ALLOWED_HOSTS'))
ALLOWED_HOSTS = ['127.0.0.1','192.168.122.234', 'geonode.foo.bar.com','localhost', '::1']
##END EXCERPT Virtual Machine #2 /etc/geonode/local_settings.py
##BEGIN EXCERPT Virtual Machine #2 /usr/share/geoserver/WEB-INF/web.xml
<context-param>
<param-name>GEONODE_BASE_URL</param-name>
<param-value>https://localhost/</param-value>
</context-param>
##END EXCERPT Virtual Machine #2 /usr/share/geoserver/WEB-INF/web.xml
##BEGIN EXCERPT Virtual Machine #2 /usr/share/geoserver/data/global.xml
<proxyBaseUrl>https://geonode.foo.bar.com/geoserver</proxyBaseUrl>
##END EXCERPT Virtual Machine #2 /usr/share/geoserver/data/global.xml
###### END Virtual Machine #2 #####
############## END Physical Machine #########################
Peter Jones
Programmer II, Department of Psychiatry
Washington University School of Medicine in St. Louis
660 South Euclid Avenue, Box 8134
St. Louis, MO 63130
e-mail: PLJ2 at WUSTL.EDU | pronouns: he/him/his
The materials in this message are private and may contain Protected Healthcare Information or other information of a sensitive nature. If you are not the intended recipient, be advised that any unauthorized use, disclosure, copying or the taking of any action in reliance on the contents of this information is strictly prohibited. If you have received this email in error, please immediately notify the sender via telephone or return mail.
More information about the geonode-users
