[GeoNode-users] Geonode-Project: paver sync and paver start issue
    Julierme Pinheiro
    juliermeopensourcedeveloper at gmail.com
    Wed Aug  1 07:57:59 PDT 2018
Dear GeoNode users,
I am setting a new geonode-project in a python virtualenv following [1].
While running all the command line, paver sync is hitting a error:
  File "manage.py", line 31, in <module>
    execute_from_command_line(sys.argv)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 364, in execute_from_command_line
    utility.execute()
  File
line 356, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/base.py",
line 283, in run_from_argv
    self.execute(*args, **cmd_options)
  File
line 327, in execute
    self.check()
  File
line 359, in check
    include_deployment_checks=include_deployment_checks,
  File
line 346, in _run_checks
    return checks.run_checks(**kwargs)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/registry.py",
line 81, in run_checks
    new_errors = check(app_configs=app_configs)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/urls.py",
line 16, in check_url_config
    return check_resolver(resolver)
  File
line 26, in check_resolver
    return check_method()
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/urls/resolvers.py",
line 254, in check
    for pattern in self.url_patterns:
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/functional.py",
line 35, in __get__
    res = instance.__dict__[self.name] = self.func(instance)
  File
line 405, in url_patterns
    patterns = getattr(self.urlconf_module, "urlpatterns",
self.urlconf_module)
  File
line 35, in __get__
  File
line 398, in urlconf_module
    return import_module(self.urlconf_name)
  File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
    __import__(name)
  File "/home/geonode_project/my_geonode/my_geonode/urls.py", line 24, in
<module>
    from geonode.urls import urlpatterns
  File "/home/geo/Envs/geonode_project/src/geonode/geonode/urls.py", line
89, in <module>
    url(r'^catalogue/', include('geonode.catalogue.urls')),
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/conf/urls/__init__.py",
line 50, in include
    urlconf_module = import_module(urlconf_module)
    __import__(name)
  File
"/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/urls.py",
line 22, in <module>
    from . import views
  File
"/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/views.py",
line 29, in <module>
    from pycsw import server
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pycsw/__init__.py",
line 35, in <module>
    __version__ = pkg_resources.require("pycsw")[0].version
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pkg_resources/__init__.py",
line 892, in require
    needed = self.resolve(parse_requirements(requirements))
  File
line 783, in resolve
    raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.ContextualVersionConflict: (xmltodict 0.9.2
(/home/geo/Envs/geonode_project/lib/python2.7/site-packages),
Requirement.parse('xmltodict==0.10.2'), set(['pycsw']))
And paver start
pavement.start
---> pavement.start_geoserver
cd /home/geonode_project/my_geonode/geoserver/data
java -version
java version "1.8.0_181"
Java(TM) SE Runtime Environment (build 1.8.0_181-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.181-b13, mixed mode)
java -Xms512m -Xmx2048m -server -XX:+UseConcMarkSweepGC
-XX:MaxPermSize=512m
-DGEOSERVER_DATA_DIR=/home/geonode_project/my_geonode/geoserver/data
-Dgeofence.dir=/home/geonode_project/my_geonode/geoserver/data/geofence
-jar
/home/geonode_project/my_geonode/downloaded/jetty-runner-9.4.7.v20170914.jar
--port 8080 --log /home/geonode_project/my_geonode/geoserver/jetty.log
/home/geonode_project/my_geonode/scripts/misc/jetty-runner.xml > /dev/null &
Starting GeoServer on http://localhost:8080/geoserver/
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option
MaxPermSize=512m; support was removed in 8.0
2018-08-01 11:43:11.942:INFO::main: Logging initialized @483ms to
org.eclipse.jetty.util.log.StdErrLog
2018-08-01 11:43:11.962:INFO:oejr.Runner:main: Runner
2018-08-01 11:43:12.832:INFO:oejs.Server:main: jetty-9.4.7.v20170914
2018-08-01 11:43:19.024:INFO:oejs.session:main: DefaultSessionIdManager
workerName=node0
2018-08-01 11:43:19.029:INFO:oejs.session:main: No SessionScavenger set,
using defaults
2018-08-01 11:43:19.032:INFO:oejs.session:main: Scavenging every 660000ms
ago 01, 2018 11:43:20 AM
it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless
you need to use the GDAL plugins: they won't be enabled.
java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
ago 01, 2018 11:43:23 AM org.geoserver.platform.GeoServerExtensions
checkContext
WARNING: Extension lookup 'XStreamPersisterInitializer', but
ApplicationContext is unset.
checkContext
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is
unset.
checkContext
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is
unset.
checkContext
unset.
2018-08-01 11:43:23.501:INFO:oejshC.geoserver:main: Initializing Spring
root WebApplicationContext
ago 01, 2018 11:43:40 AM org.geoserver.platform.GeoServerExtensions
checkContext
WARNING: Extension lookup 'MonitorDAO', but ApplicationContext is unset.
checkContext
unset.
checkContext
unset.
checkContext
unset.
ago 01, 2018 11:43:42 AM org.geoserver.platform.GeoServerExtensions
checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but
checkContext
unset.
checkContext
unset.
checkContext
unset.
ERROR StatusLogger Log4j2 could not find a logging implementation. Please
add log4j-core to the classpath. Using SimpleLogger to log to the console...
Security framework of XStream not initialized, XStream is probably
vulnerable.
2018-08-01 11:44:34.666:INFO:oejsh.ContextHandler:main: Started
o.e.j.w.WebAppContext at 19bb089b
{/geoserver,file:///home/geonode_project/my_geonode/geoserver/geoserver/,AVAILABLE}{../geoserver}
2018-08-01 11:44:34.676:INFO:oejs.AbstractNCSARequestLog:main: Opened
2018-08-01 11:44:34.716:INFO:oejs.AbstractConnector:main: Started
ServerConnector at 3934e643{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}
2018-08-01 11:44:34.721:INFO:oejs.Server:main: Started @83260ms
2018-08-01 11:44:35.206:INFO:oejshC.geoserver:qtp885284298-13: Initializing
Spring FrameworkServlet 'dispatcher'
The logs are available at
---> pavement.start_qgis_server
---> pavement.start_django
 python -W ignore manage.py runserver 0.0.0.0:8000 &
sleep 30
Performing system checks...
Unhandled exception in thread started by <function wrapper at
0x7f616da7f7d0>
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/autoreload.py",
line 228, in wrapper
    fn(*args, **kwargs)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/commands/runserver.py",
line 124, in inner_run
    self.check(display_num_errors=True)
  File
line 359, in check
  File
  File
  File
  File
  File
line 254, in check
  File
line 35, in __get__
  File
  File
line 35, in __get__
  File
    __import__(name)
<module>
89, in <module>
  File
line 50, in include
    __import__(name)
  File
    from . import views
  File
  File
  File
  File
GeoNode is now available.
has anyone faced these issues and could give me a hint?
[1] https://github.com/geosolutions-it/geonode-project
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180801/8f81254a/attachment-0001.html>
More information about the geonode-users
