[GeoNode-users] GeoNode-Project: migration and createsuperuser
francesco bartoli
xbartolone at gmail.com
Wed Aug 1 09:30:46 PDT 2018
It seems your environment is missing the python binding to the gdal
library. Do you have GDAL installed on your system?
Il giorno mer 1 ago 2018 alle ore 17:55 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> [1] http://geonode.org/dev-workshop/#/2/3
> On Wed, Aug 1, 2018 at 12:43 PM, Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> wrote:
>> Dear GeoNode Users,
>> I am trying to install geonode-project at 2.6.x according to [1].
>> When I run python manage.py migrate I hit the following error:
>> Traceback (most recent call last):
>> File "manage.py", line 29, in <module>
>> execute_from_command_line(sys.argv)
>> File
>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>> line 354, in execute_from_command_line
>> utility.execute()
>> File
>> line 328, in execute
>> django.setup()
>> File
>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/__init__.py",
>> line 18, in setup
>> apps.populate(settings.INSTALLED_APPS)
>> File
>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/registry.py",
>> line 108, in populate
>> app_config.import_models(all_models)
>> File
>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/config.py",
>> line 198, in import_models
>> self.models_module = import_module(models_module_name)
>> File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>> import_module
>> __import__(name)
>> File "/home/sipam_geonode/geonode/geonode/base/models.py", line 56, in
>> <module>
>> from geonode.utils import bbox_to_wkt
>> File "/home/sipam_geonode/geonode/geonode/utils.py", line 30, in
>> <module>
>> from osgeo import ogr
>> ImportError: No module named osgeo
>> Also when I run python manage.py createsuperuser
>> File
>> utility.execute()
>> File
>> django.setup()
>> File
>> line 18, in setup
>> File
>> File
>> import_module
>> __import__(name)
>> <module>
>> <module>
>> Does anyone has faced this problem before, and could share some hints?
>> Thank you for your time in advance
>> Best Regards
>> Julierme
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180801/b6dfb734/attachment-0001.html>
More information about the geonode-users
