[GeoNode-users] GeoNode-Project: migration and createsuperuser (Julierme Pinheiro)
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Thu Aug 2 07:16:14 PDT 2018
Here one thing that I am wondering:
I have geonode-project at 2.8.0 and geonode-project at 2.6.3 running in the same
VN. When site_base.css is added to ./static_roo/css/, I am not supposed to
see the template changes over the browser, mainly index.html? Because both,
GeoNode-Project at 2.8.0 and GeoNode-Project at 2.6.3 are not retrieving
site_base.css in ./static_roo/css/
--> .home .jumbotron { background: green }
Kind regards
Julierme
On Thu, Aug 2, 2018 at 10:45 AM, Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Francesco and Toni,
> I got (sipam_geonode) geo at gis: /home/sipam_geonode/my_geonode working.
> Awesome!!!!!!!
> I added pygdal==2.2.1.3 to requirements.txt
> Yep. (;
> Thank you very very much for your help. And sorry for the long previous
> e-mail.
> I appreciated it
> Kind regards
> Julierme
> On Thu, Aug 2, 2018 at 10:22 AM, Julierme Pinheiro <
>> Dear Francesco,
>> Thank you very much for your reply and resource suggestion. I am taking a
>> python course and as soon as I finished it, I will devour the information
>> in http://www.paolocorti.net/foss4g_2017_geonode_solr/.
>> <http://www.paolocorti.net/foss4g_2017_geonode_solr/>
>> Regarding Gdalinfo, I have gdal at 2.2.1 and pygdal at 2.2.1.3
>> geo at gis:~$ gdal-config --version
>> 2.2.1
>> 2.2.1
>> geo at gis:~$ pip show pygdal
>> Version: 2.2.1.3
>> Before entering to the resource you sent me, let me just give some more
>> information about what I am trying to do. I created three virtualenv for
>> GeoNode-Project named by: my_geonode, geonode_project, and sipam_geonode.
>> Sorry if I am misunderstanding, but I think I can do that without mixing
>> the requirements  (requirements.txt) for each GeoNode vesrion. Also I
>> created three users /home/my_geonode; /home/geonode_project and
>> /home/sipam_geonode.
>> (my_geonode) geo at gis: /home/my_geonode/my_geonode  # contains
>> GeoNode-Project at 2.8.0. installed according to the pdf in attached.
>> Fine. GeoNode is up and running.
>> One issue only: I collected the static directory by running python
>> manage.py collectstatic, but I did not see css changes on the index.html.
>> site_base.css ---> .home .jumbotron { background: yellow }
>> (geonode_project) geo at gis: /home/geonode_project/my_geonode  # contains
>> GeoNode-Project at 2.9.0. installed according to
>> https://github.com/geosolutions-it/geonode-project
>> Issue1: paver sync
>> Response:
>>  pavement.sync
>>  python -W ignore manage.py makemigrations --noinput
>> Traceback (most recent call last):
>>   File "manage.py", line 31, in <module>
>>     execute_from_command_line(sys.argv)
>>   File "/home/geo/Envs/geonode_project/local/lib/python2.7/site-
>> packages/django/core/management/__init__.py", line 364, in
>>     utility.execute()
>> packages/django/core/management/__init__.py", line 356, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>> packages/django/core/management/base.py", line 283, in run_from_argv
>>     self.execute(*args, **cmd_options)
>> packages/django/core/management/base.py", line 327, in execute
>>     self.check()
>> packages/django/core/management/base.py", line 359, in check
>>     include_deployment_checks=include_deployment_checks,
>> packages/django/core/management/base.py", line 346, in _run_checks
>>     return checks.run_checks(**kwargs)
>> packages/django/core/checks/registry.py", line 81, in run_checks
>>     new_errors = check(app_configs=app_configs)
>> packages/django/core/checks/urls.py", line 16, in check_url_config
>>     return check_resolver(resolver)
>> packages/django/core/checks/urls.py", line 26, in check_resolver
>>     return check_method()
>> packages/django/urls/resolvers.py", line 254, in check
>>     for pattern in self.url_patterns:
>> packages/django/utils/functional.py", line 35, in __get__
>>     res = instance.__dict__[self.name] = self.func(instance)
>> packages/django/urls/resolvers.py", line 405, in url_patterns
>>     patterns = getattr(self.urlconf_module, "urlpatterns",
>> self.urlconf_module)
>> packages/django/urls/resolvers.py", line 398, in urlconf_module
>>     return import_module(self.urlconf_name)
>>   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>> import_module
>>     __import__(name)
>>   File "/home/geonode_project/my_geonode/my_geonode/urls.py", line 24,
>> in <module>
>>     from geonode.urls import urlpatterns
>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/urls.py",
>> line 89, in <module>
>>     url(r'^catalogue/', include('geonode.catalogue.urls')),
>> packages/django/conf/urls/__init__.py", line 50, in include
>>     urlconf_module = import_module(urlconf_module)
>> import_module
>>     __import__(name)
>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/urls.py",
>> line 22, in <module>
>>     from . import views
>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/views.py",
>> line 29, in <module>
>>     from pycsw import server
>>   File "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pycsw/__init__.py",
>> line 35, in <module>
>>     __version__ = pkg_resources.require("pycsw")[0].version
>> packages/pkg_resources/__init__.py", line 892, in require
>>     needed = self.resolve(parse_requirements(requirements))
>> packages/pkg_resources/__init__.py", line 783, in resolve
>>     raise VersionConflict(dist, req).with_context(dependent_req)
>> pkg_resources.ContextualVersionConflict: (xmltodict 0.9.2
>> (/home/geo/Envs/geonode_project/lib/python2.7/site-packages),
>> Requirement.parse('xmltodict==0.10.2'), set(['pycsw']))
>> Captured Task Output:
>> ---> pavement.sync
>> Build failed running pavement.sync: Subprocess return code: 1
>> Issue2: paver start
>> *Note*: The issue seems to be related to xmltodict version. It is
>> installed xmltodict 0.9.2, but it requires xmltodict 0.10.2. My concern is
>> to try to upgrade the requirements version and get everything messed up.
>> (geonode_project) geo at gis:/home/geonode_project/my_geonode$ pip show
>> xmltodict
>> Version: 0.9.2
>> packages/django/utils/autoreload.py", line 228, in wrapper
>>     fn(*args, **kwargs)
>> packages/django/core/management/commands/runserver.py", line 124, in
>> inner_run
>>     self.check(display_num_errors=True)
>> import_module
>>     __import__(name)
>> in <module>
>> import_module
>>     __import__(name)
>>     from . import views
>> GeoNode is now available.
>> (sipam_geonode) geo at gis: /home/sipam_geonode/my_geonode  # contains
>> GeoNode-Project at 2.6.x. installed according to
>> http://geonode.org/dev-workshop/#/2/3
>> Issues: python manage.py migrate
>>            python manage.py createsuperuser
>>            python manage.py shell
>> Response:
>>   File "manage.py", line 29, in <module>
>>   File "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packa
>> ges/django/core/management/__init__.py", line 354, in
>>     utility.execute()
>> ges/django/core/management/__init__.py", line 328, in execute
>>     django.setup()
>>   File "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/__init__.py",
>> line 18, in setup
>>     apps.populate(settings.INSTALLED_APPS)
>>   File "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/registry.py",
>> line 108, in populate
>>     app_config.import_models(all_models)
>>   File "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/config.py",
>> line 198, in import_models
>>     self.models_module = import_module(models_module_name)
>> import_module
>>     __import__(name)
>>   File "/home/sipam_geonode/geonode/geonode/base/models.py", line 56, in
>> <module>
>>     from geonode.utils import bbox_to_wkt
>>   File "/home/sipam_geonode/geonode/geonode/utils.py", line 30, in
>> <module>
>>     from osgeo import ogr
>> ImportError: No module named osgeo
>> What I am doing seems to be crazy (;. But I separated my project in two
>> parts, in one side I have GeoNode Production working fine and on the other,
>> I need to have GeoNode-project. My goal is to have geonode-project working
>> fine and make the connection between them. A bridge project started from
>> its land edges (;
>> Kind regards
>> Julierme
>> On Thu, Aug 2, 2018 at 7:51 AM, francesco bartoli <xbartolone at gmail.com>
>> wrote:
>>> Hi Julierme,
>>> just to give you some quick ways to check what could be wrong.
>>> Check what GDAL version is installed or it isn't
>>> $ gdalinfo --version
>>> Check if the python bindings for GDAL are installed
>>> (virtual environment)
>>> $ python manage.py shell
>>> (geonode installed systemwide)
>>> $ geonode shell
>>> then in the interactive python shell
>>> Remember to make sure to match the GDAL binary version when you install
>>> the python bindings pygdal as already suggested by Toni.
>>> A great resource to improve your confidence to programming GeoNode with
>>> the interactive shell is the workshop from Paolo Corti:
>>> Il giorno gio 2 ago 2018 alle ore 12:27 Julierme Pinheiro <
>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>> Hi Toni,
>>>> Thank you very much for your reply. The problem remains even after your
>>>> suggested command lines. I will separate a brand new Ubuntu at 16.04LTS
>>>> machine and see what happens.
>>>> I appreciated your time and help.
>>>> Kind regards
>>>> Julierme
>>>> 2018-08-02 6:07 GMT-03:00 Toni Schönbuchner <
>>>> toni.schoenbuchner at csgis.de>:
>>>>> Hi Julierme,
>>>>> you´re on ubuntu, right? can you check:
>>>>> $ sudo apt-get install python-gdal gdal-bin libgdal20 libgdal-dev libgdal-devpython-gdal –y
>>>>> $ pip install pygdal==2.2.1.3
>>>>> Cheers,
>>>>> Toni
>>>>> CSGIS
>>>>> Kolonnadenstraße 1
>>>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>>>>> 04109 Leipzig
>>>>> Mobil +49/ (0) 176 6680 3198
>>>>> Tel  +49/ (0) 341 24 04 738
>>>>> Fax  +49/ (0) 341 24 04 73
>>>>> Web http://csgis.de
>>>>> Hinweis gemäß § 33 BDSG
>>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument
>>>>> ist ausschließlich für den
>>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>>>> diese E-Mail versehentlich
>>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>>>> löschen Sie diese Nachricht
>>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>>> Vervielfältigung, Veränderung,
>>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>>>> Am 01.08.2018 um 19:12 schrieb geonode-users-request at lists.osgeo.org:
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180802/c0208027/attachment-0001.html>
More information about the geonode-users mailing list
