[GeoNode-users] Geonode-Project: paver sync and paver start	issue
    Julierme Pinheiro
    juliermeopensourcedeveloper at gmail.com
    Tue Aug  7 09:16:09 PDT 2018
Hi Alessio,
Thank you very much for your reply.
I will do as you said when I find an issue.
Kind regards
Julierme
On Fri, Aug 3, 2018 at 5:50 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hello Julierme,
> will try to have a look today.
> geonode-project stuff has been now backported to official GeoNode
> repositories
> https://github.com/GeoNode/geonode-project
> Whenever you find issues or want to propose enhancements/improvements, I'd
> suggest to open issues directly there in order to keep track of the
> dicsussions.
> Il giorno mer 1 ago 2018 alle ore 16:58 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear GeoNode users,
>> I am setting a new geonode-project in a python virtualenv following [1].
>> While running all the command line, paver sync is hitting a error:
>> Traceback (most recent call last):
>>   File "manage.py", line 31, in <module>
>>     execute_from_command_line(sys.argv)
>>   File "/home/geo/Envs/geonode_project/local/lib/python2.7/
>> site-packages/django/core/management/__init__.py", line 364, in
>>     utility.execute()
>> site-packages/django/core/management/__init__.py", line 356, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>> site-packages/django/core/management/base.py", line 283, in run_from_argv
>>     self.execute(*args, **cmd_options)
>> site-packages/django/core/management/base.py", line 327, in execute
>>     self.check()
>> site-packages/django/core/management/base.py", line 359, in check
>>     include_deployment_checks=include_deployment_checks,
>> site-packages/django/core/management/base.py", line 346, in _run_checks
>>     return checks.run_checks(**kwargs)
>> site-packages/django/core/checks/registry.py", line 81, in run_checks
>>     new_errors = check(app_configs=app_configs)
>> site-packages/django/core/checks/urls.py", line 16, in check_url_config
>>     return check_resolver(resolver)
>> site-packages/django/core/checks/urls.py", line 26, in check_resolver
>>     return check_method()
>> site-packages/django/urls/resolvers.py", line 254, in check
>>     for pattern in self.url_patterns:
>> site-packages/django/utils/functional.py", line 35, in __get__
>>     res = instance.__dict__[self.name] = self.func(instance)
>> site-packages/django/urls/resolvers.py", line 405, in url_patterns
>>     patterns = getattr(self.urlconf_module, "urlpatterns",
>> self.urlconf_module)
>> site-packages/django/urls/resolvers.py", line 398, in urlconf_module
>>     return import_module(self.urlconf_name)
>>   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>> import_module
>>     __import__(name)
>>   File "/home/geonode_project/my_geonode/my_geonode/urls.py", line 24,
>> in <module>
>>     from geonode.urls import urlpatterns
>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/urls.py",
>> line 89, in <module>
>>     url(r'^catalogue/', include('geonode.catalogue.urls')),
>> site-packages/django/conf/urls/__init__.py", line 50, in include
>>     urlconf_module = import_module(urlconf_module)
>> import_module
>>     __import__(name)
>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/urls.py",
>> line 22, in <module>
>>     from . import views
>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/views.py",
>> line 29, in <module>
>>     from pycsw import server
>> site-packages/pycsw/__init__.py", line 35, in <module>
>>     __version__ = pkg_resources.require("pycsw")[0].version
>> site-packages/pkg_resources/__init__.py", line 892, in require
>>     needed = self.resolve(parse_requirements(requirements))
>> site-packages/pkg_resources/__init__.py", line 783, in resolve
>>     raise VersionConflict(dist, req).with_context(dependent_req)
>> pkg_resources.ContextualVersionConflict: (xmltodict 0.9.2
>> (/home/geo/Envs/geonode_project/lib/python2.7/site-packages),
>> Requirement.parse('xmltodict==0.10.2'), set(['pycsw']))
>> And paver start
>> pavement.start
>> ---> pavement.start_geoserver
>> cd /home/geonode_project/my_geonode/geoserver/data
>> java -version
>> java version "1.8.0_181"
>> Java(TM) SE Runtime Environment (build 1.8.0_181-b13)
>> Java HotSpot(TM) 64-Bit Server VM (build 25.181-b13, mixed mode)
>> java -Xms512m -Xmx2048m -server -XX:+UseConcMarkSweepGC
>> -XX:MaxPermSize=512m -DGEOSERVER_DATA_DIR=/home/
>> geonode_project/my_geonode/geoserver/data -Dgeofence.dir=/home/geonode_
>> project/my_geonode/geoserver/data/geofence -jar /home/geonode_project/my_
>> geonode/downloaded/jetty-runner-9.4.7.v20170914.jar --port 8080 --log
>> /home/geonode_project/my_geonode/geoserver/jetty.log
>> /home/geonode_project/my_geonode/scripts/misc/jetty-runner.xml >
>> /dev/null &
>> Starting GeoServer on http://localhost:8080/geoserver/
>> Java HotSpot(TM) 64-Bit Server VM warning: ignoring option
>> MaxPermSize=512m; support was removed in 8.0
>> 2018-08-01 11:43:11.942:INFO::main: Logging initialized @483ms to
>> org.eclipse.jetty.util.log.StdErrLog
>> 2018-08-01 11:43:11.962:INFO:oejr.Runner:main: Runner
>> 2018-08-01 11:43:12.832:INFO:oejs.Server:main: jetty-9.4.7.v20170914
>> 2018-08-01 11:43:19.024:INFO:oejs.session:main: DefaultSessionIdManager
>> workerName=node0
>> 2018-08-01 11:43:19.029:INFO:oejs.session:main: No SessionScavenger set,
>> using defaults
>> 2018-08-01 11:43:19.032:INFO:oejs.session:main: Scavenging every 660000ms
>> ago 01, 2018 11:43:20 AM it.geosolutions.imageio.gdalframework.GDALUtilities
>> loadGDAL
>> WARNING: Failed to load the GDAL native libs. This is not a problem
>> unless you need to use the GDAL plugins: they won't be enabled.
>> java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
>> ago 01, 2018 11:43:23 AM org.geoserver.platform.GeoServerExtensions
>> checkContext
>> WARNING: Extension lookup 'XStreamPersisterInitializer', but
>> ApplicationContext is unset.
>> checkContext
>> WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is
>> unset.
>> checkContext
>> WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is
>> unset.
>> checkContext
>> unset.
>> 2018-08-01 11:43:23.501:INFO:oejshC.geoserver:main: Initializing Spring
>> root WebApplicationContext
>> ago 01, 2018 11:43:40 AM org.geoserver.platform.GeoServerExtensions
>> checkContext
>> WARNING: Extension lookup 'MonitorDAO', but ApplicationContext is unset.
>> checkContext
>> unset.
>> checkContext
>> unset.
>> checkContext
>> unset.
>> ago 01, 2018 11:43:42 AM org.geoserver.platform.GeoServerExtensions
>> checkContext
>> WARNING: Extension lookup 'GeoServerSecurityProvider', but
>> checkContext
>> unset.
>> checkContext
>> unset.
>> checkContext
>> unset.
>> ERROR StatusLogger Log4j2 could not find a logging implementation. Please
>> add log4j-core to the classpath. Using SimpleLogger to log to the console...
>> Security framework of XStream not initialized, XStream is probably
>> vulnerable.
>> 2018-08-01 11:44:34.666:INFO:oejsh.ContextHandler:main: Started
>> o.e.j.w.WebAppContext at 19bb089b{/geoserver,file:///home/
>> geonode_project/my_geonode/geoserver/geoserver/,AVAILABLE}{../geoserver}
>> 2018-08-01 11:44:34.676:INFO:oejs.AbstractNCSARequestLog:main: Opened
>> 2018-08-01 11:44:34.716:INFO:oejs.AbstractConnector:main: Started
>> ServerConnector at 3934e643{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}
>> 2018-08-01 11:44:34.721:INFO:oejs.Server:main: Started @83260ms
>> 2018-08-01 11:44:35.206:INFO:oejshC.geoserver:qtp885284298-13:
>> Initializing Spring FrameworkServlet 'dispatcher'
>> The logs are available at /home/geonode_project/my_
>> ---> pavement.start_qgis_server
>> ---> pavement.start_django
>>  python -W ignore manage.py runserver 0.0.0.0:8000 &
>> sleep 30
>> Performing system checks...
>> Unhandled exception in thread started by <function wrapper at
>> 0x7f616da7f7d0>
>> site-packages/django/utils/autoreload.py", line 228, in wrapper
>>     fn(*args, **kwargs)
>> site-packages/django/core/management/commands/runserver.py", line 124,
>> in inner_run
>>     self.check(display_num_errors=True)
>> import_module
>>     __import__(name)
>> in <module>
>> import_module
>>     __import__(name)
>>     from . import views
>> GeoNode is now available.
>> has anyone faced these issues and could give me a hint?
>> [1] https://github.com/geosolutions-it/geonode-project
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A -
> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>  Massarosa
> (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180807/8a05858e/attachment-0001.html>
More information about the geonode-users
