[GeoNode-users] Auth via Restful requests?
francesco bartoli
xbartolone at gmail.com
Wed Aug 15 01:09:14 PDT 2018
Also certainly any documented procedure is missing so if you are happy with
that a PR for docs would be appreciated :)
Thanks,
Francesco
Il giorno mer 15 ago 2018 alle ore 10:06 francesco bartoli <
xbartolone at gmail.com> ha scritto:
> Hi,
> you are lucky that feature already exists. You should add a fixture to
> have an apykey from tastypie like this:
> "fields": {
> "user": 1000,
> "key": "pyxW5djJ7XsjeFUXduAsGpR4xMGUwpeBGQRqTeT3",
> "created": "2018-06-28T14:54:51Z"
> "model": "tastypie.apikey",
> "pk": 1
> and then use such key to your calls to geonode api systems. The code
> responsible for this should be here:
> https://github.com/GeoNode/geonode/blob/master/geonode/api/authorization.py#L80
> Please see the PR which provided it
> https://github.com/GeoNode/geonode/pull/3415, is it enough for your use
> case?
> Il giorno mer 15 ago 2018 alle ore 05:58 Gus MacAulay <
> gusmacaulay at gmail.com> ha scritto:
>> Hi List,
>> I've been working on a custom web application which uses geonode for data
>> catalog and auth. So far we have used a form submission POST from
>> javascript and various page scrapes (access token etc.) to allow login and
>> registration from our app to geonode - however we have run into some
>> limitations with regard to redirects on login error. It doesn't look like
>> there is currently a way to login RESTfully - assuming this doesn't already
>> exist, can someone point me in the direction of what code I would need to
>> modify/enhance to add this functionality?
>> Regards
>> Gus
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180815/9566c410/attachment-0001.html>
More information about the geonode-users
