[GeoNode-users] GeoNode-Project: migration and createsuperuser
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Wed Aug 15 11:18:31 PDT 2018
Hi Paolo Corti,
Thank you very much for your reply. I got it.
Kind regards
Julierme
On Mon, Aug 13, 2018 at 3:39 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi
> that means you have gdal-bin on your system. To know if you have also
> the Python bindings try running: pip freeze | grep -i gdal and you
> should see a line with something like pygdal==1.11.3.3
> In case they are not there, install the ones needed by your GDAL version.
> kind regards
> Paolo
> On Wed, Aug 1, 2018 at 12:44 PM Julierme Pinheiro
> <juliermeopensourcedeveloper at gmail.com> wrote:
> > Hi Francesco,
> > Thank you very much for your reply. Yes I do:
> > geo at gis:~$ gdal-config --version
> > 2.2.1
> > Kind regards
> > Julierme
> > On Wed, Aug 1, 2018 at 1:30 PM, francesco bartoli <xbartolone at gmail.com>
> wrote:
> >> It seems your environment is missing the python binding to the gdal
> library. Do you have GDAL installed on your system?
> >> Il giorno mer 1 ago 2018 alle ore 17:55 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
> >>> [1] http://geonode.org/dev-workshop/#/2/3
> >>> On Wed, Aug 1, 2018 at 12:43 PM, Julierme Pinheiro <
> >>>> Dear GeoNode Users,
> >>>> I am trying to install geonode-project at 2.6.x according to [1].
> >>>> When I run  python manage.py migrate I hit the following error:
> >>>> Traceback (most recent call last):
> >>>>   File "manage.py", line 29, in <module>
> >>>>     execute_from_command_line(sys.argv)
> >>>>   File "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-
> packages/django/core/management/__init__.py", line 354, in
> >>>>     utility.execute()
> packages/django/core/management/__init__.py", line 328, in execute
> >>>>     django.setup()
> >>>>   File "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/__init__.py",
> line 18, in setup
> >>>>     apps.populate(settings.INSTALLED_APPS)
> packages/django/apps/registry.py", line 108, in populate
> >>>>     app_config.import_models(all_models)
> packages/django/apps/config.py", line 198, in import_models
> >>>>     self.models_module = import_module(models_module_name)
> >>>>   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
> import_module
> >>>>     __import__(name)
> >>>>   File "/home/sipam_geonode/geonode/geonode/base/models.py", line
> 56, in <module>
> >>>>     from geonode.utils import bbox_to_wkt
> >>>>   File "/home/sipam_geonode/geonode/geonode/utils.py", line 30, in
> <module>
> >>>>     from osgeo import ogr
> >>>> ImportError: No module named osgeo
> >>>> Also when I run python manage.py createsuperuser
> >>>>     utility.execute()
> >>>>     django.setup()
> line 18, in setup
> import_module
> >>>>     __import__(name)
> 56, in <module>
> <module>
> >>>> Does anyone has faced this problem before, and could share some hints?
> >>>> Thank you for your time in advance
> >>>> Best Regards
> >>>> Julierme
> >>> _______________________________________________
> >>> geonode-users mailing list
> >>> geonode-users at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180815/cb68e001/attachment.html>
More information about the geonode-users mailing list
