[GeoNode-users] Geonode-Project Inherited by Geonode Production
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Thu Aug 16 13:09:09 PDT 2018
Dear users and contributors,
I am still trying to figure out the way Apache2/geonode.conf is configured
in order to have geonode production inheriting the changes in
geonode-project, mainly ./geonode_proj/static_root/css/site_base.css and
./geonode_proj/templates/site_index.html and site_base.html.
Based on [1]  I added the following lines to  the geonode.conf which
default configuration is found in [2]:
    Alias /static/ /home/geonode/geonode_proj/geonode_proj/static_root/
    Alias /templates/ /home/geonode/geonode_proj/geonode_proj/templates/
    Alias /site_index.html
/home/geonode/geonode_proj/geonode_proj/templates/site_index.html
    Alias /site_base.html
/home/geonode/geonode_proj/geonode_proj/templates/site_base.html
############################### New Configuration for site inheritance
    <Directory "/home/geonode/geonode_proj/">
        Order allow,deny
        Options Indexes FollowSymLinks
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/geonode_proj/geonode_proj/templates/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/geonode_proj/geonode_proj/static_root/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/geonode_proj/geonode_proj/">
         <Files wsgi.py>
             Order deny,allow
             Allow from all
             Require all granted
         </Files>
        Order allow,deny
        Allow from all
        IndexOptions FancyIndexing
    </Directory>
#######################################################################################################3
Within this configuration, geonode production is inheriting the
site_base.css in ./geonode-proj/static_root/css/, but site_index.html and
site_base.html.
I also have to mention that WSGI being used is production WSGIScriptAlias /
/home/geonode/my_geonode/my_geonode/wsgi.py.
My first guest is: although I have created all the Alias path (including
the templates directory) as showed above, Apache2 still looking for the
site_index.html and site_base.html in the production folder
/home/geonode/my_geonode/my_geonode/templates/.
One thing I can not understand is: I created the Alias for geonode-project
static_root and Apache is doing exactly what I want: getting the
site_base.css. But why is not doing for the geonode_project templates.
To test my first guest, I copied site_index.html and site_base.html to
production path /home/geonode/my_geonode/my_geonode/templates and the
response was a request to site_base.html, but site_index.html.
Lastly, I have to say that I have production and geonode-project in the
same virtualenv.
I am very confused. Could someone give me a hint on that please? And my
apologies for bringing this topic to discussion again.
Thank you for your time in advance
Kind regards
Julierme
[1] https://docs.djangoproject.com/en/2.1/howto/deployment/wsgi/modwsgi/
[2]
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180816/9b0764c1/attachment.html>
More information about the geonode-users mailing list
