[GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Tue Aug 28 12:10:50 PDT 2018
...Anyway
On Tue, Aug 28, 2018 at 4:08 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Toni,
> Thank you very much for your reply and highlights. I got it. Now, I have
> only GeoNode-Project running in a CentOS VM and I am looking for a
> documentation giving more insights on the use of GeoNode_Project installed
> via docker. Looking at [1], the command line <docker-compose exec django
> django-admin.py collectstatic --noinput>. works as well. I changed
> site_base.css by adding the line <.home .jumbotron { background: yellow
> }>, but after running collectstatic the static_root has not been created.
> Also running the following commands according to [1], I get a warning:
> docker-compose exec django django-admin.py loaddata geonode/base/fixtures/initial_data.json
> WARNINGS:
> ?: (urls.W002) Your URL pattern '^/?$' [name='home'] has a regex beginning with a '/'. Remove this slash as it is unnecessary. If this pattern is targeted in an include(), ensure the include() pattern has a trailing '/'.
> CommandError: No fixture named 'initial_data' found.
> (geonode_project) [geo at gis geonode_project]$ docker-compose exec django django-admin.py loaddata geonode/base/fixtures/default_oauth_apps_docker.json
> System check identified some issues:
> WARNINGS:
> CommandError: No fixture named 'default_oauth_apps_docker' found.
> I removed '/' from urls.py but the Warnings remains.
> Any away I could not figure out why static_root has not been created after running collectstatic. Any additional comment on that will be very appreciated.
> Thank you all for the patience and help in advance.
> Kind regards
> Julierme
> [1] http://geonode.org/dev-workshop/#/2/1
> On Tue, Aug 28, 2018 at 2:53 AM Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> wrote:
>> Dear Julierme,
>> so if I understand correctly you installed two instances in your docker
>> environment:
>> - geonode (core)
>> - geonode (project)
>> If so I wouldn´t do it as as you´re writing ports will conflict. Maybe
>> naming of containers,
>> volumens as well.  May I ask you why do you need two instances running
>> on that machine? If there is no other reason the for learning I would
>> suggest to
>> just run geonode-project as it´s there for customisations.
>> Regarding collectstatics. So if I´m right and both are in a docker
>> context have
>> you tried to run the command not on your host but the django container?
>> docker exec -it <container_id_or_name> python manage.py …
>> cheers,
>> Toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Mobil +49/ (0) 176 6680 3198
>> Tel  +49/ (0) 341 24 04 738
>> Fax  +49/ (0) 341 24 04 73
>> Web http://csgis.de
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>> ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>> diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>> löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>> Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> Am 27.08.2018 um 18:05 schrieb Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com>:
>> Hi Toni,
>> Thank you very much for your reply. I am doing great. And I hope you are
>> doing just wonderful. Yes, you are right. The files site_index.htm,
>> site_base.html and site_base.css are ready to use. I configured/edit them
>> in a geonode_project installed in a virtualenv in a Ubuntu at 16.04 server.
>> Now I want to copy site_index.html, site_base.html and site_base.css. to a
>> CentOS server that contains GeoNode and GeoNode_Project installed via
>> docker.
>> In Centos:
>> 1  - GeoNode installed via Docker
>> GeoNode was installed according to [1], except I use the command line:
>> <docker-compose up --build -d>
>> 2 - GeoNode_Project installed via Docker
>> GeoNode was installed according to [2], and because Geonode_Project
>> django container port was conflicting with GeoNode django port. I
>> configured the files docker-compose.yml and docker-compose.override.yml as
>> follow:
>> docker-compose.yml
>> geonode:
>> ports:
>>    -81:80
>> django:
>> GEONODE_LB_HOST_IP: 192.168.00.02
>> GEONODE_LB_PORT: 81
>> SITEURL: http://192.168.00.02/ <http://192.168.0.2/>
>> ALLOWED_HOSTS: "['localhost', '192.168.0.02', '127.0.0.1', '::1']"
>> GEOSERVER_PUBLIC_LOCATION: http://192.168.0.02/geoserver/
>> <http://192.168.0.2/geoserver/>
>> celery:
>> GEONODE_LB_HOST_IP: 192.168.0.02
>> GEONODE_LB_PORT: 81
>> SITEURL: http://192.168.0.02/ <http://192.168.0.2/>
>> geoserver:
>> GEONODE_LB_PORT: 81
>> Said that, in the geonode_project folder, I am running python manage.py
>> collectstatic  and I am hitting a error message shown bellow:
>> File "manage.py", line 31, in <module>
>>     execute_from_command_line(sys.argv)
>>   File
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
>> line 364, in execute_from_command_line
>>     utility.execute()
>>   File
>> line 308, in execute
>>     settings.INSTALLED_APPS
>>   File
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/conf/__init__.py",
>> line 56, in __getattr__
>>     self._setup(name)
>>   File
>> line 41, in _setup
>>     self._wrapped = Settings(settings_module)
>>   File
>> line 110, in __init__
>>     mod = importlib.import_module(self.SETTINGS_MODULE)
>>   File "/usr/lib64/python2.7/importlib/__init__.py", line 37, in
>> import_module
>>     __import__(name)
>>   File "/home/geo/geonode_project/geonode_project/settings.py", line 30,
>> in <module>
>>     from geonode.settings import *
>> ImportError: No module named geonode.settings
>> Am I missing any configuration? Could you give me a hint on that, please?
>> I appreciated your time
>> Kind regards
>> Julierme
>> [1]
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/setup_docker_compose.html
>> [2]https://github.com/GeoNode/geonode-project
>> On Sat, Aug 25, 2018 at 4:56 PM Toni Schönbuchner <
>>> Hey Julierme,
>>> how are you doing? I haven´t followed the whole converersation.
>>> Just my two cents, is it possible that your´re look in the wrong place?
>>> Contrib app is a way to run multiple website. Are you looking for
>>> templates
>>> here? ->
>>> https://github.com/GeoNode/geonode/tree/master/geonode/templates
>>> Like base.html, index.html and so on?
>>> If so it would be better to start with geonode_project:
>>> here you can easily overwrite the files you mentioned here:
>>> https://github.com/GeoNode/geonode-project/tree/master/project_name/templates
>>> Without changing the core templates.
>>> cheers,
>>> toni
>>> CSGIS
>>> Kolonnadenstraße 1
>>> 04109 Leipzig
>>> Web http://csgis.de
>>> Am 25.08.2018 um 21:00 schrieb geonode-users-request at lists.osgeo.org:
>>> Message: 1
>>> Date: Fri, 24 Aug 2018 18:02:26 -0300
>>> From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
>>> To: francesco bartoli <xbartolone at gmail.com>
>>> Cc: geonode-users <geonode-users at lists.osgeo.org>
>>> Subject: Re: [GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS
>>> - Templates
>>> Message-ID:
>>> <CAKTKyJKomRPN8nTi-S7yLhk-S7BoH3wTmHDyEDEryx4WxoDCxQ at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Hi Francesco,
>>> Thank you very much for reply.
>>> I went back and ran the command < docker-compose up --build -d>, but I am
>>> still not getting any success by editing the file site_index.html in
>>> ./geonode/contrib/geosites/site_template/templates/site_index.html.
>>> I appreciated your time.
>>> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180828/c4d6afc1/attachment-0001.html>
More information about the geonode-users mailing list
