[GeoNode-users] Serve directory contents using apache on the same GeoNode server
Daniel Victoria
daniel.victoria at gmail.com
Fri Aug 31 06:46:11 PDT 2018
OK, replying to myself just in case someone wants to do something similar
In order to open a directory for listing it's file contents, one needs to
change
/etc/apache2/sites-enabled/geonode.conf
You need to set an alias for the directory you want and then add the proper
<directory> entry similar to:
Alias /dados /var/www/html/dados/
<Directory "/var/www/html/dados/SL_publications/">
Order allow,deny
Options Indexes FollowSymLinks
Allow from all
Require all granted
IndexOptions FancyIndexing
</Directory>
On Thu, Aug 30, 2018 at 9:45 PM Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> Hi all,
> I have an Ubuntu server running GeoNode 2.8, installed from the PPA. Now
> I'd like to expose a directory ( /var/www/data) using apache so other users
> can download some files that I will place there. But I can't figure out
> where (and how) to set this.
> Should this be done in /etc/apache2/sites-enabled/geonode.conf ?
> What should I place there?
> Thanks
> Daniel
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180831/08e0bd96/attachment.html>
More information about the geonode-users
