[GeoNode-users] Serve directory contents using apache on the same GeoNode server
Daniel Victoria
daniel.victoria at gmail.com
Fri Aug 31 07:17:15 PDT 2018
Great, thanks!
On Fri, Aug 31, 2018 at 11:16 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Daniel,
> yes, I would say also that is the best way to do it.
> Il giorno ven 31 ago 2018 alle ore 15:46 Daniel Victoria <
> daniel.victoria at gmail.com> ha scritto:
>> OK, replying to myself just in case someone wants to do something similar
>> In order to open a directory for listing it's file contents, one needs to
>> change
>> /etc/apache2/sites-enabled/geonode.conf
>> You need to set an alias for the directory you want and then add the
>> proper <directory> entry similar to:
>> Alias /dados /var/www/html/dados/
>> <Directory "/var/www/html/dados/SL_publications/">
>> Order allow,deny
>> Options Indexes FollowSymLinks
>> Allow from all
>> Require all granted
>> IndexOptions FancyIndexing
>> </Directory>
>> On Thu, Aug 30, 2018 at 9:45 PM Daniel Victoria <
>> daniel.victoria at gmail.com> wrote:
>>> Hi all,
>>> I have an Ubuntu server running GeoNode 2.8, installed from the PPA. Now
>>> I'd like to expose a directory ( /var/www/data) using apache so other users
>>> can download some files that I will place there. But I can't figure out
>>> where (and how) to set this.
>>> Should this be done in /etc/apache2/sites-enabled/geonode.conf ?
>>> What should I place there?
>>> Thanks
>>> Daniel
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A -
> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
> Massarosa
> (LU) - Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> mob: +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180831/b1c29198/attachment.html>
More information about the geonode-users
