[GeoNode-users] Geonode Install on Ubuntu 18.04
Jose Cáceres
jose.atyus at gmail.com
Sat Dec 1 09:01:33 PST 2018
I've been trying to deploy Geonode 2.10 on a Ubuntu 18.04 server using the
instructions provide here:
https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
However I'm getting the same error every time I try to run the command:
sudo WORKON_HOME=/my/opt_path/Envs/geonode
DJANGO_SETTINGS_MODULE=geonode.local_settings
GEONODE_ETC=/my/opt_path/geonode/geonode
GEOSERVER_DATA_DIR=/var/lib/tomcat8/webapps/geoserver/data geonode_updateip
-p localhost
I've change /my/opt_path/ for my own directory, but I get the following
error:
File "/home/geoportal/Envs/geonode/bin/django-admin", line 11, in <module>
sys.exit(execute_from_command_line())
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 364, in execute_from_command_line
utility.execute()
File
line 356, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/core/management/base.py",
line 283, in run_from_argv
self.execute(*args, **cmd_options)
File
line 330, in execute
output = self.handle(*args, **options)
File
"/home/geoportal/geonode/geonode/base/management/commands/fixsitename.py",
line 39, in handle
site = Site.objects.get_current()
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/contrib/sites/models.py",
line 63, in get_current
return self._get_site_by_id(site_id)
File
line 35, in _get_site_by_id
site = self.get(pk=site_id)
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/db/models/manager.py",
line 85, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/db/models/query.py",
line 374, in get
num = len(clone)
File
line 232, in __len__
self._fetch_all()
File
line 1121, in _fetch_all
self._result_cache = list(self._iterable_class(self))
File
line 53, in __iter__
results = compiler.execute_sql(chunked_fetch=self.chunked_fetch)
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py",
line 899, in execute_sql
raise original_exception
django.db.utils.ProgrammingError: relation "django_site" does not exist
LINE 1: ..."django_site"."domain", "django_site"."name" FROM "django_si...
Any help will be very much appreciated since I'm kind of stuck here.
Kind Regards,
José
José David Cáceres
Ingeniero Ambiental
Máster en Tecnologías de la Información Geográfica
e-mail: jose.atyus at gmail.com
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
Remitente
notificado con
Mailtrack
01/12/18
11:00:26
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181201/80feef92/attachment.html>
More information about the geonode-users
