[GeoNode-users] Geonode Install on Ubuntu 18.04
Jose Cáceres
jose.atyus at gmail.com
Sun Dec 2 07:15:31 PST 2018
Hi Toni
Thanks again for your reply.
geonode.settings is using sqlite, here is what that line looks like in my
file:
DATABASE_URL = os.getenv(
'DATABASE_URL',
'sqlite:///{path}'.format(
path=os.path.join(PROJECT_ROOT, 'development.db')
Everything looks same as in the file
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L104.
I'm I supposed to change that?
Running ./manage.py migrate sites --settings=geonode.local_settings gave me
this:
Operations to perform:
Apply all migrations: sites
Running migrations:
Applying sites.0001_initial... OK
Applying sites.0002_alter_domain_unique... OK
File "./manage.py", line 29, in <module>
execute_from_command_line(sys.argv)
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 364, in execute_from_command_line
utility.execute()
File
line 356, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/core/management/base.py",
line 283, in run_from_argv
self.execute(*args, **cmd_options)
File
line 330, in execute
output = self.handle(*args, **options)
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/core/management/commands/migrate.py",
line 227, in handle
self.verbosity, self.interactive, connection.alias,
apps=post_migrate_apps, plan=plan,
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/core/management/sql.py",
line 53, in emit_post_migrate_signal
**kwargs
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/django/dispatch/dispatcher.py",
line 193, in send
for receiver in self._live_receivers(sender)
File
"/home/geoportal/Envs/geonode/local/lib/python2.7/site-packages/jsonfield_compat/convert.py",
line 48, in handler_convert_json_fields
convert_model_json_fields(model)
File
line 43, in convert_model_json_fields
convert_column_to_json(model, column_name)
File
line 23, in convert_column_to_json
current_type = cursor.fetchone()[0].upper()
TypeError: 'NoneType' object has no attribute '__getitem__'
./manage.py migrate --settings=geonode.local_settings gave me this:
Apply all migrations: account, actstream, admin, agon_ratings,
announcements, auth, avatar, base, contenttypes, dialogos, documents,
geonode_client, geonode_themes, groups, guardian, invitations, layers,
maps, monitoring, oauth2_provider, people, pinax_notifications, services,
sessions, sites, socialaccount, taggit, tastypie, upload, user_messages
Running migrations:
Applying contenttypes.0001_initial... OK
Applying taggit.0001_initial... OK
Applying taggit.0002_auto_20150616_2121... OK
Applying contenttypes.0002_remove_content_type_name... OK
Applying auth.0001_initial... OK
Applying auth.0002_alter_permission_name_max_length... OK
Applying auth.0003_alter_user_email_max_length... OK
Applying auth.0004_alter_user_username_opts... OK
Applying auth.0005_alter_user_last_login_null... OK
Applying auth.0006_require_contenttypes_0002... OK
Applying people.24_initial... OK
Applying account.0001_initial... OK
Applying account.0002_email_max_length... OK
Applying actstream.0001_initial... OK
Applying actstream.0002_remove_action_data... OK
Applying admin.0001_initial... OK
Applying admin.0002_logentry_remove_auto_add... OK
Applying agon_ratings.0001_initial... OK
Applying announcements.0001_initial... OK
Applying announcements.0002_auto_20181201_1638... OK
Applying auth.0007_alter_validators_add_error_messages... OK
Applying auth.0008_alter_user_username_max_length... OK
Applying avatar.0001_initial... OK
Applying base.24_initial... OK
Applying base.24_to_26... OK
Applying base.26_to_27... OK
Applying base.0027_auto_20170801_1228... OK
Applying base.0028_resourcebase_is_approved... OK
Applying base.0029_auto_20171114_0341... OK
Applying base.0030_auto_20180309_0833... OK
Applying base.0031_auto_20180309_0837... OK
Applying base.0032_auto_20180329_1844... OK
Applying base.0033_auto_20180330_0951... OK
Applying base.0034_auto_20180606_1543... OK
Applying base.0035_resourcebase_dirty_state... OK
Applying dialogos.0001_initial... OK
Applying documents.24_initial... OK
Applying documents.25_add_documentresourcelink_table... OK
Applying documents.26_move_data_to_documentresourcelink_table... OK
Applying documents.27_drop_resource_columns_from_document_table... OK
Applying documents.0028_auto_20170801_1228... OK
Applying documents.0029_auto_20180301_1947... OK
Applying documents.0030_auto_20180302_0430... OK
Applying documents.0031_auto_20180409_1238... OK
Applying documents.0032_auto_20180412_0822... OK
Applying documents.0033_auto_20180414_2120... OK
Applying geonode_client.0001_initial... OK
Applying geonode_client.0002_auto_20180412_1039... OK
Applying
geonode_client.0003_geonodethemecustomization_jumbotron_welcome_hide... OK
Applying geonode_client.0004_auto_20180416_1319... OK
Applying geonode_client.0005_auto_20181015_1201... OK
Applying geonode_themes.0001_initial... OK
Applying geonode_themes.0002_auto_20181015_1208... OK
Applying
geonode_themes.0003_remove_geonodethemecustomization_identifier... OK
Applying groups.24_initial... OK
Applying groups.26_to_27... OK
Applying groups.0027_auto_20180105_1631... OK
Applying groups.0028_auto_20180606_1543... OK
Applying guardian.0001_initial... OK
Applying invitations.0001_initial... OK
Applying invitations.0002_auto_20151126_0426... OK
Applying invitations.0003_auto_20151126_1523... OK
Applying layers.24_initial... OK
Applying services.24_initial... OK
Applying services.0025_harvestjob... OK
Applying services.0026_auto_20171130_0600... OK
Applying services.0027_harvestjob_details... OK
Applying services.0028_auto_20171201_0640... OK
Applying services.0029_auto_20171203_1624... OK
Applying services.0030_auto_20171212_0518... OK
Applying layers.24_to_26... OK
Applying layers.26_to_27... OK
Applying layers.0027_auto_20170801_1228... OK
Applying layers.0028_auto_20171218_0249... OK
Applying layers.0029_layer_service... OK
Applying layers.0030_auto_20180228_0812... OK
Applying layers.0031_uploadsession_resource... OK
Applying layers.0032_auto_20180424_1638... OK
Applying layers.0033_auto_20180606_1543... OK
Applying maps.24_initial... OK
Applying maps.0025_auto_20170801_1228... OK
Applying maps.0026_auto_20180301_1947... OK
Applying maps.0027_auto_20180302_0430... OK
Applying maps.0028_auto_20180409_1238... OK
Applying maps.0029_auto_20180412_0822... OK
Applying maps.0030_auto_20180414_2120... OK
Applying monitoring.0001_monitoring_init... OK
Applying monitoring.0002_monitoring_update... OK
Applying monitoring.0003_monitoring_resources... OK
Applying monitoring.0004_monitoring_metric_type... OK
Applying monitoring.0005_monitoring_ows_service... OK
Applying monitoring.0006_monitoring_path_text... OK
Applying monitoring.0007_monitoring_exception_message... OK
Applying monitoring.0008_monitoring_notifications_check... OK
Applying monitoring.0009_sample_count... OK
Applying monitoring.0010_metric_unit... OK
Applying monitoring.0011_notification_def... OK
Applying monitoring.0012_notifications_service... OK
Applying monitoring.0013_notifications_def_description... OK
Applying monitoring.0014_notifications_emails... OK
Applying monitoring.0015_notification_grace_period... OK
Applying monitoring.0016_notification_severity... OK
Applying monitoring.0017_monitoring_notification_active... OK
Applying monitoring.0018_notification_check_def... OK
Applying monitoring.0019_notification_check_def_link... OK
Applying monitoring.0020_metric_description... OK
Applying monitoring.0021_auto_20180301_0932... OK
Applying monitoring.0022_service_last_check_default... OK
Applying oauth2_provider.0001_initial... OK
Applying oauth2_provider.0002_08_updates... OK
Applying oauth2_provider.0003_auto_20160316_1503... OK
Applying oauth2_provider.0004_auto_20160525_1623... OK
Applying oauth2_provider.0005_auto_20170514_1141... OK
Applying oauth2_provider.0006_auto_20170903_1632... OK
Applying oauth2_provider.0007_application_algorithm... OK
Applying oauth2_provider.0008_idtoken... OK
Applying oauth2_provider.0006_auto_20171214_2232... OK
Applying oauth2_provider.0009_merge_20180606_1314... OK
Applying people.0025_auto_20170924_0932... OK
Applying people.0026_auto_20171120_0730... OK
Applying people.0027_auto_20180414_2120... OK
Applying people.0028_auto_20180606_1543... OK
Applying pinax_notifications.0001_initial... OK
Applying pinax_notifications.0002_auto_20171003_2006... OK
Applying services.0031_auto_20180301_1947... OK
Applying services.0032_auto_20180302_0430... OK
Applying services.0031_service_proxy_base... OK
Applying services.0033_merge... OK
Applying services.0034_auto_20180309_0917... OK
Applying services.0035_auto_20180327_0846... OK
Applying services.0036_auto_20180331_1039... OK
Applying services.0037_auto_20180409_1238... OK
Applying services.0038_auto_20180412_0822... OK
Applying services.0039_auto_20180414_2120... OK
Applying sessions.0001_initial... OK
Applying socialaccount.0001_initial... OK
Applying socialaccount.0002_token_max_lengths... OK
Applying socialaccount.0003_extra_data_default_dict... OK
Applying tastypie.0001_initial... OK
Applying upload.24_initial... OK
Applying user_messages.0001_initial... OK
Applying user_messages.0002_auto_20171107_1128... OK
Applying user_messages.0003_auto_20171108_1037... OK
Applying user_messages.0004_auto_20171108_1101... OK
actstream: Converting data to use native TEXT field
However I ran ./manage.py migrate sites --settings=geonode.local_settings
one more time and didm't show anything weird:
Running migrations:
No migrations to apply.
I ran sudo WORKON_HOME=/home/geoportal/Envs/geonode
DJANGO_SETTINGS_MODULE=geonode.local_settings
GEONODE_ETC=/home/geoportal/geonode/geonode
GEOSERVER_DATA_DIR=/var/lib/tomcat8/webapps/geoserver/data geonode_updateip
-p 10.8.11.66 and got different error this time:
PUBLIC_IP http://10.8.11.66
LOCAL_IP http://localhost
Replacing SITEURL value with 'http://10.8.11.66' in
/home/geoportal/geonode/geonode/local_settings.py ... done.
Adding entry for '10.8.11.66' in
/var/lib/tomcat8/webapps/geoserver/data/printing/config.yaml ...
'10.8.11.66' already found to the printing whitelist.
Setting up oauth
Waiting Tomcat Service to Restart...
Waiting Apache HTTPD Service to Restart...
File "/home/geoportal/Envs/geonode/bin/django-admin", line 11, in <module>
sys.exit(execute_from_command_line())
File
utility.execute()
File
File
File
File
"/home/geoportal/geonode/geonode/geoserver/management/commands/updatelayers.py",
line 98, in handle
owner = get_valid_user(user)
File "/home/geoportal/geonode/geonode/people/utils.py", line 44, in
get_valid_user
theuser = get_default_user()
File "/home/geoportal/geonode/geonode/people/utils.py", line 35, in
get_default_user
raise GeoNodeException('You must have an admin account configured '
geonode.GeoNodeException: You must have an admin account configured before
importing data. Try: django-admin.py createsuperuser
Yes, /home/geoportal/ is the root of my geonode.
less /etc/apache2/sites-available/geonode.conf looks like this:
WSGIDaemonProcess geonode
python-path=/home/geoportal/geonode:/home/geoportal/Envs/geonode/lib/python2.7/site-packages
user=www-data threads=15 processes
=2
<VirtualHost *:80>
ServerName http://localhost
ServerAdmin webmaster at localhost
DocumentRoot /home/geoportal/geonode/geonode
LimitRequestFieldSize 32760
LimitRequestLine 32760
ErrorLog /var/log/apache2/error.log
LogLevel info
CustomLog /var/log/apache2/access.log combined
WSGIProcessGroup geonode
WSGIPassAuthorization On
WSGIScriptAlias / /home/geoportal/geonode/geonode/wsgi.py
Alias /static/ /home/geoportal/geonode/geonode/static_root/
Alias /uploaded/ /home/geoportal/geonode/geonode/uploaded/
<Directory "/home/geoportal/geonode/geonode/">
<Files wsgi.py>
Order deny,allow
Allow from all
Require all granted
</Files>
Order allow,deny
Options Indexes FollowSymLinks
Allow from all
IndexOptions FancyIndexing
</Directory>
<Directory "/home/geoportal/geonode/geonode/static_root/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/geoportal/geonode/geonode/uploaded/thumbs/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/geoportal/geonode/geonode/uploaded/avatars/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/geoportal/geonode/geonode/uploaded/people_group/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/geoportal/geonode/geonode/uploaded/group/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/geoportal/geonode/geonode/uploaded/documents/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/geoportal/geonode/geonode/uploaded/layers/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/geoportal/geonode/geonode/uploaded/img/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Proxy *>
Order allow,deny
Allow from all
</Proxy>
ProxyPreserveHost On
ProxyPass /geoserver http://localhost:8080/geoserver
ProxyPassReverse /geoserver http://localhost:8080/geoserver
</VirtualHost>
apachectl configtest shows this:
AH00558: apache2: Could not reliably determine the server's fully
qualified domain name, using 10.8.11.66. Set the 'ServerName' directive
globally to suppress this message
Syntax OK
Many thanks for all your help.
Kind Regards,
José
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
Remitente
notificado con
Mailtrack
02/12/18
09:12:00
On Sun, Dec 2, 2018 at 2:45 AM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hi Jose,
> I'm not sure if the last part, when it says that found another file, is
> because I have already runing this command, although the error that I send
> in my first email happen the first time I run the command.
> This could be as you already run it before.
> Coming back to you error before:
> django.db.utils.ProgrammingError: relation "django_site" does not exist
> My guess, geonode.settings is using the local sqlite development.db
> database:
> Here migration have been applied and site is correctly setup.
> local_settings is using
> postgresql and the migration are missing there .
> Can you check
> I can access http://my_ip/geoserver site just fine, but I cannot access
> http://my_ip as it shows a "500 Internal Server Error"
> The error 500 looks like ALLOWED_HOSTS setting is missing your IP.
> https://github.com/GeoNode/geonode/blob/master/geonode/local_settings.py.geoserver.sample#L52
> My guess it´s geonode.settings which is still in use. This because of
> either wsgi.py pointing to settings or a missconfigured vhost (see below).
> I do have a doubt with this line:
> GEONODE_SRC_PATH="\/my\/opt_path"; sudo sed -i -e
> "s/\/home\/geo/$GEONODE_SRC_PATH/g"
> I know my/opth_path is where I deploy my geonode but the /home/geo will
> alway be the same? Or that directory also depends on my local installation?
> the sed is /OLD-TEXT/NEW-TEXT/
> means it´s using the var GEONODE_SRC_PATH as replacement for /home/geo.
> In other words after that /home/geo should be repaced everywhere with
> /my/opt/
> in /etc/apache2/sites/available/geonode.conf
> If /home/geoportal is in your case the root for your geonode (?) the
> correct command should be
> $ GEONODE_SRC_PATH="\/home\/geoportal/"; sudo sed -i -e
> # should not find anything
> $ grep "home/geo" /etc/apache2/sites-available/geonode.conf
> # check your config
> $ less /etc/apache2/sites-available/geonode.conf
> $ apachectl configtest
> $ sudo service apache2 restart
> Let me know if this works for you.
> Cheers,
> Toni
José David Cáceres
Ingeniero Ambiental
Máster en Tecnologías de la Información Geográfica
e-mail: jose.atyus at gmail.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181202/4a508755/attachment-0001.html>
More information about the geonode-users
