[GeoNode-users] Geonode 2.10.x installation
Paolo Corti pcorti at gmail.com
Tue Dec 4 09:46:27 PST 2018
Hi
Is this a standard GeoNode installation or you made any customization?
I remember I got into this once, and I fixed by removing all the .pyc
files. But this doesn't make sense if you installed a vanilla GeoNode and
made no changes.
hope this helps
Paolo
On Mon, Dec 3, 2018 at 11:17 PM aditya fikri ghozali <
adityafikrighozali at gmail.com> wrote:
> Thank you Paulo,
> heres the additional log messages from wsgi
> [Sun Dec 02 12:16:56.805981 2018] [wsgi:error] [pid 12750] [remote
> 127.0.0.1:49732] Traceback (most recent call last):
> [Sun Dec 02 12:16:56.806017 2018] [wsgi:error] [pid 12750] [remote
> 127.0.0.1:49732]   File "/home/aditya/geonode/geonode/wsgi.py", line 30,
> in <module>
> [Sun Dec 02 12:16:56.806058 2018] [wsgi:error] [pid 12750] [remote
> 127.0.0.1:49732]     application = get_wsgi_application()
> [Sun Dec 02 12:16:56.806071 2018] [wsgi:error] [pid 12750] [remote
> "/home/aditya/Envs/geonode/lib/python2.7/site-packages/django/core/wsgi.py",
> line 13, in get_wsgi_application
> [Sun Dec 02 12:16:56.806098 2018] [wsgi:error] [pid 12750] [remote
> 127.0.0.1:49732]     django.setup(set_prefix=False)
> [Sun Dec 02 12:16:56.806117 2018] [wsgi:error] [pid 12750] [remote
> "/home/aditya/Envs/geonode/lib/python2.7/site-packages/django/__init__.py",
> line 27, in setup
> [Sun Dec 02 12:16:56.806143 2018] [wsgi:error] [pid 12750] [remote
> 127.0.0.1:49732]     apps.populate(settings.INSTALLED_APPS)
> [Sun Dec 02 12:16:56.806158 2018] [wsgi:error] [pid 12750] [remote
> "/home/aditya/Envs/geonode/lib/python2.7/site-packages/django/apps/registry.py",
> line 78, in populate
> [Sun Dec 02 12:16:56.806185 2018] [wsgi:error] [pid 12750] [remote
> 127.0.0.1:49732]     raise RuntimeError("populate() isn't reentrant")
> [Sun Dec 02 12:16:56.806214 2018] [wsgi:error] [pid 12750] [remote
> 127.0.0.1:49732] RuntimeError: populate() isn't reentrant
> after seeing that, I suppose to check INSTALLED_APPS in settings.py. But i
> didnt find anything suspicious about it.
> Is there another clue from the error ?
> heres the look of INSTALLED_APPS in settings.py
> GEONODE_CORE_APPS = (
> # GeoNode internal apps
> 'geonode.api',
> 'geonode.base',
> 'geonode.layers',
> 'geonode.maps',
> 'geonode.documents',
> 'geonode.security',
> 'geonode.catalogue',
> GEONODE_INTERNAL_APPS = (
> 'geonode.people',
> 'geonode.client',
> 'geonode.themes',
> 'geonode.proxy',
> 'geonode.social',
> 'geonode.groups',
> 'geonode.services',
> # QGIS Server Apps
> # Only enable this if using QGIS Server
> # 'geonode.qgis_server',
> # GeoServer Apps
> # Geoserver needs to come last because
> # it's signals may rely on other apps' signals.
> 'geonode.geoserver',
> 'geonode.upload',
> 'geonode.tasks',
> 'geonode.messaging',
> GEONODE_CONTRIB_APPS = (
> # GeoNode Contrib Apps
> # 'geonode.contrib.dynamic',
> # 'geonode.contrib.exif',
> # 'geonode.contrib.favorite',
> # 'geonode.contrib.geogig',
> # 'geonode.contrib.geosites',
> # 'geonode.contrib.nlp',
> # 'geonode.contrib.slack',
> # 'geonode.contrib.createlayer',
> # 'geonode.contrib.datastore_shards',
> 'geonode.contrib.metadataxsl',
> 'geonode.contrib.api_basemaps',
> # 'geonode.contrib.ows_api',
> # Uncomment the following line to enable contrib apps
> GEONODE_APPS = GEONODE_CORE_APPS + GEONODE_INTERNAL_APPS +
> INSTALLED_APPS = (
> 'modeltranslation',
> # Boostrap admin theme
> # 'django_admin_bootstrapped.bootstrap3',
> # 'django_admin_bootstrapped',
> # Apps bundled with Django
> 'django.contrib.auth',
> 'django.contrib.contenttypes',
> 'django.contrib.sessions',
> 'django.contrib.sites',
> 'jet.dashboard',
> 'jet',
> 'django.contrib.admin',
> 'django.contrib.sitemaps',
> 'django.contrib.staticfiles',
> 'django.contrib.messages',
> 'django.contrib.humanize',
> 'django.contrib.gis',
> # Utility
> 'dj_pagination',
> 'taggit',
> 'treebeard',
> 'geoexplorer',
> 'leaflet',
> 'bootstrap3_datetime',
> 'django_extensions',
> 'django_basic_auth',
> 'autocomplete_light',
> 'mptt',
> # 'crispy_forms',
> # 'djkombu',
> # 'djcelery',
> # 'kombu.transport.django',
> 'storages',
> 'floppyforms',
> # Theme
> "pinax_theme_bootstrap",
> 'django_forms_bootstrap',
> # Social
> 'avatar',
> 'dialogos',
> # 'pinax.comments',
> 'agon_ratings',
> # 'pinax.ratings',
> 'announcements',
> 'actstream',
> 'user_messages',
> 'tastypie',
> 'polymorphic',
> 'guardian',
> 'oauth2_provider',
> 'corsheaders',
> 'invitations',
> # login with external providers
> 'allauth',
> 'allauth.account',
> 'allauth.socialaccount',
> # Django REST Framework
> 'rest_framework',
> # GeoNode
> 'geonode',
> ) + GEONODE_APPS
> Best Regards,
> *Aditya Fikri Ghozali*
> Geodesy and Geomatics Engineering
> e-mail: adityafikrighozali at gmail.com
>  | www.adityafikrighozali.com <http://www.adityafikrighozali.com>
>           <https://www.facebook.com/welcomemybest>
> <https://www.linkedin.com/in/fikriaditya/>
> <https://www.youtube.com/user/adityafikri/>
> <https://medium.com/@adityafikrighozali>
> On Tue, Dec 4, 2018 at 2:17 AM Paolo Corti <pcorti at gmail.com> wrote:
>> Hi
>> the posted log gives you a hint: "Exception occurred processing WSGI
>> script '/home/aditya/geonode/geonode/wsgi.py"
>> So wsgi is failing and not apache. Try to check the wsgi log -
>> location can vary depending on installation type and configuration -
>> and see what is the actual problem
>> best
>> Paolo
>> On Sun, Dec 2, 2018 at 7:25 AM aditya fikri ghozali
>> <adityafikrighozali at gmail.com> wrote:
>> > Dear all,
>> > i've been following geonode 2.10.x ubuntu 18.04  installation
>> instruction on
>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>> > all work well,but in the end in the end of installation it only can be
>> accessed from http://localhost:8000/ .
>> > It gives Internal Server Errors(500) when accessed through
>> http://localhost/
>> > my path were home/aditya/geonode ; home/aditya/Envs/geonode
>> > i've already set up geonode.conf on apache2 accordingly
>> > apache2 log:
>> > [Sun Dec 02 11:57:29.936734 2018] [wsgi:error] [pid 12750] [remote
>> 127.0.0.1:49646] mod_wsgi (pid=12750): Target WSGI script
>> '/home/aditya/geonode/geonode/wsgi.py' cannot be loaded as Python module.
>> > [Sun Dec 02 11:57:29.936794 2018] [wsgi:error] [pid 12750] [remote
>> 127.0.0.1:49646] mod_wsgi (pid=12750): Exception occurred processing
>> WSGI script '/home/aditya/geonode/geonode/wsgi.py'.
>> > Did anyone know what to do to fix it?
>> > Thanks in advance.
>> > Best Regards,
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181204/0da9b5f4/attachment-0001.html>
More information about the geonode-users mailing list
