[GeoNode-users] GWC doesn't work on docker Geonode 2.10 master
francesco bartoli
xbartolone at gmail.com
Fri Dec 14 06:34:24 PST 2018
At first glance this jdbc:postgresql://localhost:5432/geonode has a wrong
hostname in a docker deployment. It should be
jdbc:postgresql://db:5432/geonode
Il giorno ven 14 dic 2018 alle ore 15:29 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Hello Dejan,
> could you send to me (in private email) some of the tiled OWS GetMap
> requests you are seeing on the browser?
> Il giorno ven 14 dic 2018 alle ore 15:14 Dejan Samardzic <
> dejan.samardzic at cedis.me> ha scritto:
>> Dear Geonode community,
>> We have made docker Gonode 2.10 master branch installation on Ubuntu
>> 18.04 by Alessio's guide:
>> https://docs.google.com/document/d/1S0ac9IR9IW9tUjMu7JETPLUjnfQ6P87m1PKNko8IPWY/edit
>> after that we have configure GeoWebCache:
>> 1) We have configure Caching to external postgresql database:
>> Tile caching - Disk quota....Enable disk Quota ....Maximum tile cache
>> size 50GiB
>> Disk quota check frequency:600s
>> Disk quota store type....External database
>> Target database type....PostgreSQL
>> JDBC data source...GeoServer managed connection pool
>> JDBC Driver class name.....org.postgresql.Driver
>> JDBC connection URL.....jdbc:postgresql://localhost:5432/geonode
>> User name.....geonode
>> Password.....****
>> Validation query.....select 1
>> 2) Define path for cache
>> From geoserver container:
>> mkdir /var/cache/geoserver
>> chmod -R 777 geoserver
>> vi /usr/local/tomcat/webapps/geoserver/WEB-INF/web.xml
>> insert :
>> <context-param>
>> <param-name>GEOWEBCACHE_CACHE_DIR</param-name>
>> <param-value>/var/cache/geoserver/</param-value>
>> </context-param>
>> Now seeding of GeoWebCache is working and creating png files in
>> /var/cache/geoserver.
>> But GeoWebCache is not working. When we browse new layer it doesn't
>> create png files in /var/cache/geoserver. Also, already created png files
>> (using Seeding of GeoWebCash) are not delivered form cache.
>> Please watch for yourself about layer novi_novi_r6_Ivanje_10kV_izmijenjen:
>> https://www.youtube.com/watch?v=SgyJw7mjXaU
>> regards,
>> Dejan Samardzic
>> * Dejan Samardžić* Rukovodilac Sektora za ICT / IT Manager
>> CEDIS d.o.o.
>> Ivana Milutinovića 12, 81000 Podgorica
>> gsm: +382 67 220 971
>> tel: +382 20 408 453
>> email: dejan.samardzic at cedis.me
>> web: www.cedis.me
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181214/092bcd52/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181214/092bcd52/attachment.jpg>
More information about the geonode-users
