[GeoNode-users] GeoNode migration from 2.4 to 2.8
Muhammad Nabi Ahmad
mnabiahmad at gmail.com
Thu Dec 20 03:07:07 PST 2018
Dear Alessio
Sorry for the delayed response.
I managed to migrate our GeoServer data using these instructions. Thanks a lot for helping.
Best regards
Muhammad
From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Date: Monday, August 13, 2018 at 2:24 PM
To: Muhammad <mnabiahmad at gmail.com>
Cc: geonode-users <geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] GeoNode migration from 2.4 to 2.8
Dear Muhammad,
the old version of GeoNode/GeoServer used an obsolete authentication method which therefore is no more available on the new GeoServer versions.
The exception you are experiencing are caused, most probably, by some wrong security/config.xml file on your geoserver data directory.
You should compare the security folder with the one provided with
http://build.geonode.org/geoserver/latest/data-2.13.x.zip
Also you should finalize your GeoNode configuration with OAuth2 by following the guidelines here
http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html
Also this doc, nevertheless it is a bit outdated, could be useful in order to make some comparison between old configuration files and new ones
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_update/index.html#
Il giorno lun 13 ago 2018 alle ore 11:55 Muhammad <mnabiahmad at gmail.com> ha scritto:
Hi All
I am migrating GeoNode 2.4 to 28. For GeoServer data migration, I took GeoServer (version 2.7) data folder from GeoNode 2.4 vm and copied it to the GeoNode 2.8 vm (GeoServer 2.12.2). Now, when I restart tomcat, GeoServer does not start. In catalina.out file I can see an exception "GeoNodeAnonymousAuthFilterConfig" but have no idea why this exception is being raised
The file /var/log/tomcat8/catalina.out shown in the following link
https://bpaste.net/show/be0b362314b7
Thanks and best regards
Muhammad
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181220/79610685/attachment.html>
More information about the geonode-users
