[GeoNode-users] Print button not working on Chrome - Geonode 2.8
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Dec 21 01:07:00 PST 2018
Please,
update your settings.py and change the variable
GOOGLE_API_KEY = None
or either specify a valid api key (you must get one from Google).
Il giorno gio 20 dic 2018 alle ore 15:44 Jose Cáceres <jose.atyus at gmail.com>
ha scritto:
> Hi,
> I'm facing a "Uncaught RangeError: Maximum call stack size exceeded"
> whenever I hit the print button on a map in Google Chrome nothing happens
> and shows the previous error on console, however the button is working fine
> in Firefox. I have attached the pictures of the error on console. I'm using
> Google Chrome Versión 71.0.3578.98 (Build oficial) (64 bits)
> The map is at http://206.189.229.38/maps/150/view, and is public, if
> anyone can reproduce the error to see if it is something wrong with my site
> or my browser.
> Any help will be much appreciated.
> Kind regards,
> José
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com
> [image: Mailtrack]
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
> notificado con
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 20/12/18
> 08:41:54
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181221/ad78c0ad/attachment.html>
More information about the geonode-users
