[GeoNode-users] problems connect refused when upload shapefiles in geonode
SILVIA GAMERO gamerinsky at gmail.com
Tue Feb 20 13:16:36 PST 2018
Good afternoon everyone, I currently have problems when I try to upload
layers in geonode, a CONNECT REFUSED message appears.
I'm working with Geonode 2.6x on centos7.
[image: Imágenes integradas 1]
In the geonode log the following appears:
[Errno 111] Connection refused
  File "/opt/apps/geonode/geonode/geonode/layers/views.py", line 168, in
layer_upload
metadata_uploaded_preserve=form.cleaned_data["metadata_uploaded_preserve"]
  File "/opt/apps/geonode/geonode/geonode/layers/utils.py", line 499, in
file_upload
    defaults=defaults
  File "/usr/lib/python2.7/site-packages/django/db/models/manager.py", line
127, in manager_method
    return getattr(self.get_queryset(), name)(*args, **kwargs)
  File "/usr/lib/python2.7/site-packages/modeltranslation/manager.py", line
389, in get_or_create
    return super(MultilingualQuerySet, self).get_or_create(**kwargs)
  File "/usr/lib/python2.7/site-packages/django/db/models/query.py", line
407, in get_or_create
    return self._create_object_from_params(lookup, params)
439, in _create_object_from_params
    obj = self.create(**params)
381, in create
    return super(MultilingualQuerySet, self).create(**kwargs)
348, in create
    obj.save(force_insert=True, using=self.db)
  File "/usr/lib/python2.7/site-packages/polymorphic/models.py", line 90,
in save
    return super(PolymorphicModel, self).save(*args, **kwargs)
  File "/usr/lib/python2.7/site-packages/django/db/models/base.py", line
734, in save
    force_update=force_update, update_fields=update_fields)
758, in save_base
  File "/usr/lib/python2.7/site-packages/django/dispatch/dispatcher.py",
line 189, in send
    response = receiver(signal=self, sender=sender, **named)
  File "/opt/apps/geonode/geonode/geonode/geoserver/signals.py", line 93,
in geoserver_pre_save
    charset=instance.charset)
  File "/opt/apps/geonode/geonode/geonode/geoserver/helpers.py", line 1059,
in geoserver_upload
    workspace = cat.get_default_workspace()
  File "/usr/lib/python2.7/site-packages/geoserver/catalog.py", line 875,
in get_default_workspace
    ws.fetch()
  File "/usr/lib/python2.7/site-packages/geoserver/support.py", line 176,
in fetch
    self.dom = self.catalog.get_xml(self.href)
  File "/usr/lib/python2.7/site-packages/geoserver/catalog.py", line 211,
in get_xml
    response, content = self.http.request(rest_url)
  File "/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1609,
in request
    (response, content) = self._request(conn, authority, uri, request_uri,
method, body, headers, redirections, cachekey)
  File "/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1351,
in _request
    (response, content) = self._conn_request(conn, request_uri, method,
body, headers)
  File "/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1272,
in _conn_request
    conn.connect()
  File "/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 928,
in connect
    raise socket.error, msg
error: [Errno 111] Connection refused
"POST /layers/upload HTTP/1.1" 400 3357
I do not know if I have to modify the settings.py file where references to
localhost appear and not to the ip of the server where it is installed.
If someone could tell me how I can prove that geonode connects to postgis
to verify the connection, because geoserver connects very well to postgres.
Thanks
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180220/380f7579/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180220/380f7579/attachment-0001.png>
More information about the geonode-users mailing list
