[GeoNode-users] Error when installing Geonode 2.6 Ubuntu
James Mbugua
jmbugua at cordioea.net
Tue Jan 2 22:18:36 PST 2018
I had the same issues and reverted to using ubuntu 14.04
<http://releases.ubuntu.com/14.04.5/> and it worked.
James.
On Wed, Jan 3, 2018 at 5:45 AM, Franklin, Chris - Perth. <
CFranklin at rml.com.au> wrote:
> Hi,
> Im installing Geonode 2.6.3 from PPA on Ubuntu 16.04 but keep getting this
> error:
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> geonode is already the newest version (2.6.3+thefinal0).
> 0 to upgrade, 0 to newly install, 0 to remove and 244 not to upgrade.
> 2 not fully installed or removed.
> After this operation, 0 B of additional disk space will be used.
> Do you want to continue? [Y/n] Y
> Setting up geoserver-geonode (2.9.0) ...
> Job for tomcat7.service failed because the control process exited with
> error code. See "systemctl status tomcat7.service" and "journalctl -xe" for
> details.
> dpkg: error processing package geoserver-geonode (--configure):
> subprocess installed post-installation script returned error exit status 1
> dpkg: dependency problems prevent configuration of geonode:
> geonode depends on geoserver-geonode | geoserver; however:
> Package geoserver-geonode is not configured yet.
> Package geoserver is not installed.
> dpkg: error processing package geonode (--configure):
> dependency problems - leaving unconfigured
> No apport report written because the error message indicates its a
> followup error from a previous failure.
> Errors were encountered while processing:
> geoserver-geonode
> geonode
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> Any ideas what going wrong?
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Best regards,
James Mbugua
____________________________________________________________
Research Assistant GIS & Remote sensing at CORDIO East Africa #9 Kibaki
Flats,
P.O.Box10135 Mombasa 80101,
Bamburi
Mobile: +254720978196
Skype: mbugua.james1 Email: jmbugua at cordioea.net
Website:www.cordioea.net
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180103/f172ef90/attachment.html>
More information about the geonode-users
