[GeoNode-users] Upgraded to Geoserver 2.12.1 -- Unexpected
unni mana unnivm at gmail.com
Sun Jan 7 03:56:33 PST 2018
Thank you Toni for your valuable feedback,
Unni M
On Sun, Jan 7, 2018 at 4:20 PM, Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Unni,
> as said I´m afraid I cannot say if geonode 1.7 and geoserver 2.12 are
> compatible (I would say it should work).
> Let´s see what others say regarding your exception. (Alessio?)
> Gsconfig is used for manipulating geoserver through it´s rest api. I would
> check the version you´re using
> $ pip show gsconfig. (1.0.8 should be fine) But that's nothing more than a
> vague guess.
> Cheers,
> Toni
> Am 07.01.2018 um 11:30 schrieb unni mana <unnivm at gmail.com>:
> Hi Toni,
> Do I need to upgrade geonode as well? The main reason for upgrading
> geoserver to latest is that I need to use .mbtiles extension. But in order
> to use this extension, I need to use latest geoserver.
> Geoserver 2.10 does not support mbtiles. I have tried that earlier.
> what are the things I need to look into gsconfig file?
> Thanks
> Unni M
> On Sun, Jan 7, 2018 at 3:24 PM, Toni Schönbuchner <
>> Hi Unni,
>> Geonode needs a modified geoserver version (because of auth).
>> That´s why I mentioned the build resource.
>> Unfortunately I´m not familiar with this exception further cannot say if
>> geonode 1.7.11
>> and geoserver 2.12.1 are compatible. ( 1.7.11 ships with 2.10 as far as I
>> remember ) .
>> I´m sure other users can help you here.
>> Just to double check, you´re settings are correct and you brought
>> everything in sync?
>> manage.py updatelayers etc … ? Also a look at your gsconfig version could
>> be a first
>> step.
>> Cheers,
>> Toni
>> Hi Toni,
>> I upgraded to latest geoserver (2.12.x ) from that location(
>> http://build.geonode.org/geoserver/latest/) you have mentioned. But when
>> I upload a layer from *geonode*, I am getting the following error
>> *Unexpected excwpti9n 'NoneType'* object has no attribute 'store_type'
>> The current *geonode *version is used :is *1.7.11*
>> Thanks
>> Unni M
> If not played, Free Sudoku Android Game
> <https://play.google.com/store/apps/details?id=com.gamerfan.sudoku>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180107/632d8ea1/attachment.html>
More information about the geonode-users mailing list
