[GeoNode-users] Authentication problem between Geonode and Geoserver
francesco bartoli xbartolone at gmail.com
Fri Jul 6 04:55:47 PDT 2018
Which version of GeoNode are you using? What kind of installation and
startup procedure did you follow? Without these information it's difficult
to say exactly what's the problem.
A good start point however is to check your configuration against the docs
http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html?highlight=oauth2#geoserver-2-12-x-and-above
Hope this helps
Il giorno ven 6 lug 2018 alle ore 13:41 Joshi, Jigeeshu <
Jigeeshu.Joshi at ils-forschung.de> ha scritto:
> Hi ,
> I am having trouble understanding the authentication / authorization
> settings between Geonode and Geoserver. I have a problem that , the layers
> in Geonode are not available/ visible unless logged into Geosever with user
> admin. After login to Geoserever as admin, everything works normally.  But,
> every user does not have Geoserver admin credential so in that case, any
> user other than admin would not be able to see the layers.
> Has anyone come across this problem. Any solution is appreciated. Let me
> know if I have not made the problem clear.
> Regards,
> Joshi
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180706/e675e51a/attachment.html>
More information about the geonode-users mailing list
