[GeoNode-users] Geonode Docker provisioning problems. tasks.py
John, Steffen s.john at atenekom.eu
Thu Jun 14 02:08:38 PDT 2018
Thanks, Alessio.
Which GeoNode version is actually in the master branch? is it the current stable version 2.8?
Steffen
[X]
Steffen John
Geodaten und Anwendungsentwicklung
Tel. +49 (0)30 22183-3534 | Fax +49 (0)30 60989-99
s.john at atenekom.eu<mailto:s.john at atenekom.eu>
atene KOM GmbH
Agentur für Kommunikation, Organisation und Management
Invalidenstraße 91 | 10115 Berlin
www.atenekom.eu<http://www.atenekom.eu/> | Link All<http://www.link-all.eu/index.php?language=de> | Apps<https://itunes.apple.com/de/app/atene-kom-funds/id589783071?mt=8&ls=1> | facebook<https://www.facebook.com/atenekom> | XING<https://www.xing.com/companies/atenekomgmbh%25257Cagenturf%2525C3%25259Crkommunikationorganisationundmanagement?user_view=true> | YouTube<http://www.youtube.com/profile?user=atenekom>
Geschäftsführer: Tim Brauckmüller  |  AG Berlin Charlottenburg  |  HRB 111699  |  USt-ID: DE259091767
Am Donnerstag, den 14.06.2018, 10:23 +0200 schrieb Alessio Fabiani:
Uhm,
it seems like the "instancename" is not containing the ":port" and therefore you get the exception.
I see in "master" branch of "geonode-docker" there was a tentative to fix this issue
https://github.com/GeoNode/geonode-docker/blob/master/tasks.py#L96
Notice the differences with the version you are currently using
https://github.com/GeoNode/geonode-docker/blob/2.7.x/tasks.py#L86
Il giorno gio 14 giu 2018 alle ore 09:48 John, Steffen <s.john at atenekom.eu<mailto:s.john at atenekom.eu>> ha scritto:
Hi!
I tried setting up Geonode 2.6 from this repo (https://github.com/GeoNode/geonode-docker/ and https://hub.docker.com/r/geonode/geonode/) using docker.
Building the container works without problem, but when I integrate into my docker-compose stack and try to start the container, I get the following error message:
django_1         | Traceback (most recent call last):
django_1         |   File "/usr/local/bin/invoke", line 11, in <module>
django_1         |     sys.exit(program.run())
django_1         |   File "/usr/local/lib/python2.7/site-packages/invoke/program.py", line 293, in run
django_1         |     self.execute()
django_1         |   File "/usr/local/lib/python2.7/site-packages/invoke/program.py", line 414, in execute
django_1         |     executor.execute(*self.tasks)
django_1         |   File "/usr/local/lib/python2.7/site-packages/invoke/executor.py", line 129, in execute
django_1         |     result = call.task(*args, **call.kwargs)
django_1         |   File "/usr/local/lib/python2.7/site-packages/invoke/tasks.py", line 115, in __call__
django_1         |     result = self.body(*args, **kwargs)
django_1         |   File "/usr/src/app/tasks.py", line 25, in update
django_1         |     pub_port = _geonode_public_port()
django_1         |   File "/usr/src/app/tasks.py", line 144, in _geonode_public_port
django_1         |     os.getenv('GEONODE_INSTANCE_NAME', 'geonode')
django_1         |   File "/usr/src/app/tasks.py", line 95, in _container_exposed_port
django_1         |     ) if '{0}'.format(instname) in c.name<http://c.name>][0]
django_1         | IndexError: list index out of range
As far as I understood, the error originated from tasks.py which does some kind of provisioning.
But what my be the reason for that error and how can I fix it?
Any help is appreciated! Thanks a lot!
Steffen
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180614/6cafb4fc/attachment-0001.html>
More information about the geonode-users mailing list
