[GeoNode-users] GeoNode2.8.0 installed from source Thumbnails Error
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Thu Jun 14 08:49:58 PDT 2018
Hi Alessio Fabiani,
Thank you very much for your reply. Sorry, I missed your question in here.
Accordingly to [1] SITEURL should be configured as:
*SITEURL = **'http://localhost <http://localhost>'*
which is the same as
SITEURL = os.getenv('SITEURL', "http://localhost/") # if I am not wrong.
Now, I am comparing GeoNode at 2.8.0 Production (*GP*) and GeoNode at 2.8.0
DevMode (*GD*) which has the thumbnails working a lot better. In *GP
WSGI_APPLICATION* is set as the following:
*local_settings.py* (according to [1])
*WSGI_APPLICATION = "my_geonode.wsgi.application"*
*settings.py*
PROJECT_NAME = 'my_geonode'
*WSGI_APPLICATION = "{}.wsgi.application".format (PROJECT_NAME)*
printing the variable WSGI_APPLICATION on python terminal, the response is
>my_geonode.wsgi.application<
In the other hand *GD WSGI_APPLICATION* is set as the following:
*Not available.*
*settings.py*
*WSGI_APPLICATION = "{}.wsgi.application".format (PROJECT_NAME) *
*which is equal to WSGI_APPLICATION = "my_geonode.wsgi.application" # If I
am not wrong*
I appreciated your time.
Julierme
[1]
http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
On Tue, Jun 12, 2018 at 12:20 PM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Have you correctly configured the SITEURL?
> https://github.com/GeoNode/geonode/blob/2.8.0/geonode/settings.py#L632
> Il giorno ven 8 giu 2018 alle ore 22:26 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear Toni Schonbuchner and GeoNode developers,
>> First of all, my apologies to bring this topic back to discussion. I had
>> already started with Toni, as shown in the message bellow.
>> I am digging into GeoNode scripts architecture trying to find an issue
>> related to the creation of thumbnails. Let me introduce to you what I have
>> done so far.
>> I have GeoNode at 2.8.0. installed in a virtualenv according to
>> http://docs.geonode.org/en/master/tutorials/install_and_
>> admin/geonode_install/index.html. The thumbnails created by loading data
>> from GeoNode interface do not work at all.
>> They are displayed if and only if I upload the layers from GeoServer
>> interface and in a next step, run python manage.py updatelayers. It is very
>> interesting what happens here: after running updatelayers, if I go to
>> GeoNode interface, I see the thumbnail perfectly fine, but doing a right
>> click over it and copy image location, the response is an OWS url as I am
>> showing bellow. However If a make a request to the database,
>> get_thumbnail_url, the response is a http://localhost:8000/. Why port
>> 8000? Sorry to use this expression, this port 8000 is a nightmare, and I am
>> digging deep trying to find its source.
>> If I remove port 8000, the thumbnails work like a charm in port 80.
>> After following all Toni's recommendations [1] [2] and [3] (please, see
>> the message right in the bottom of this e-mail), I could not find port 8000
>> source. It is in somewhere, and I will keep looking for its source in
>> GeoNode scripts.
>> A brilliant idea came out. Let's compare GeoNode at 2.8.0 stable installed
>> via apt-get with GeoNode at 2.8.0 installed from source in a python
>> virtualenv. I am going through GeoServer data path, settings.py and
>> local_settings.py, [1], helpers.py [2], and signals.py[3]. I am not sure
>> that is a brilliant idea to find port 8000, my nightmare, but I found
>> another issue in respect to GeoNode apt-get. This issue tells me that port
>> 8000 is not the only one, there is another problem related to thumbnails
>> that occurs either in GeoNode at 2.8.0 installed from source and
>> GeoNode at 2.8.0 installed via apt-get when updating thumbnails in GeoNode
>> interface and I am showing it bellow:
>> *GeoNode installed from source in a virtualenv*
>> *Thumbnail created by loading data from GeoNode Interface*
>> *Does not work at all*
>> $ sudo geonode shell
>> >>> from geonode.layers.models import Layer
>> >>> layer = Layer.objects.all()
>> >>> for tn in layer:
>> ... print tn.get_thumbnail_url()
>> http://localhost:8000/uploaded/thumbs/layer-d3b7e06c-6b4a-11e8-a4cc-
>> *NOTE:* The nightmare is here: port 8000. Why? I have set
>> geoserver_location and geoserver_public_ location to port 8080. And there
>> is proxy reverse in geonode.conf to port 80.
>> *Thumbnail created by loading data from GeoServer Interface*
>> *Does not work at all *
>> >>> for tn in layer:
>> http://localhost:8000/uploaded/thumbs/layer-cfe8a292-80d4-4c59-bff5-
>> <http://localhost/uploaded/thumbs/layer-2524c8db-726e-4050-9689-055dc0bb9aaa-thumb.png>
>> *NOTE:*The nightmare is here: port 8000. Why? I have set
>> *HOWEVER: *after running updatelayers for the first time without
>> updating the thumbnail, there is a light at the end of the tunnel.
>> *Thumbnails are displayed. *
>> *Right Click over thumbnail --> Copy image Location*
>> A OWS url appears
>> http://localhost:8080/geoserver/ows?layers=geonode:
>> GPS&crs=EPSG:4326&service=WMS&format=image/png8&request=
>> GetMap&height=150&width=200&version=1.1.1&bbox=-69.935496180600000,-29.
>> 789445458300000,-35.777101013900000,0.047035064700000
>> Why these urls patterns are different? One uses GeoServer, but the other
>> do not.
>> *Now, let's edit this layer (zoom in / zoom out) and Set Thumbnails *
>> *Layer --> Edit Layer --> Zoom in or Zoom out --> Set Thumbnails*
>> Thumbnails url (http://localhost/uploaded/thumbs/layer-2524c8db-726e-
>> 4050-9689-055dc0bb9aaa-thumb.png) does not work properly.
>> *Error message:*
>> The image 'http://localhost/uploaded/thumbs/layer-2524c8db-726e-
>> 4050-9689-055dc0bb9aaa-thumb.png' cannot be displayed because it
>> contains errors.
>> *CONCLUSION GEONODE INSTALLED BY SOURCE:* There are two issues: *port
>> 8000* and *thumbnails update.*
>> *GEONODE INSTALLED VIA APT-GET *
>> *Works like a charm *
>> >>> for tn in layer:
>> http://localhost/uploaded/thumbs/layer-f519c8d4-6b35-
>> *Now, let's edit this layer (zoom in / zoom out) and Set Thumbnail*
>> Thumbnail url (http://localhost/uploaded/thumbs/layer-a7c6035e-6b49-
>> 11e8-90e2-080027ac8c10-thumb.png) does not work properly.
>> *Error message:*
>> The image 'http://localhost/uploaded/thumbs/layer-a7c6035e-6b49-
>> 11e8-90e2-080027ac8c10-thumb.png' cannot be displayed because it
>> contains errors.
>> Works like a charm
>> >>> for tn in layer:
>> *Right Click over thumbnail blank image --> Copy image Location*
>> http://localhost/geoserver/ows?layers=geonode:RBMC&crs=
>> EPSG:4326&service=WMS&format=image/png8&request=GetMap&
>> height=150&width=200&version=1.1.1&bbox=-64.706650088900000,-31.
>> 802449444400000,-35.777101013900000,0.047035064700000
>> *Error message:*
>> contains errors.
>> *CONCLUSION GEONODE INSTALLED VIA APT-GET:* There is only one issue: *Thumbnails
>> update.*
>> As I said above, I do not know if it is a good idea, but I will keep
>> comparing [1] [2] and [3] in GeoNode apt-get and GeoNode virtualenv in
>> order to find port 8000 source. However the issue related to updating
>> GeoNode thumbnails I have no clue.
>> Sorry for this long e-mail. Thank you for your time in advance. I
>> appreciated your help and attention.
>> Dear Julierme,
>> I think using grep does not really help to get insights.
>> Why not look at the code? The geoserver URL is composed
>> in settings.py [1]. I think here you will find your 8000.
>> Next I think the best way to see what´s going on is to have
>> a look at the helpers.py [2]. Here you should find the code which
>> is responsible for creating thumbnails and here [3] the signal
>> which you see in stdout logging. If there is some time I will
>> do a dev installation and will test it as well.
>> Further you´ve asked if there is something like geonode-updateip
>> for an installation by source? Not that I know of but yes it would be
>> helpful.
>> But it should not be to hard to write a little script which does the job.
>> Have a look what geonode-updateip actually does [4] it programatically
>> changes
>> the parts which the documentation [5] explains regarding auth.
>> I hope this helps a bit.
>> Best greetings to Brasilia!
>> Toni
>> [1] https://github.com/GeoNode/geonode/blob/2.8.0/
>> geonode/settings.py#L650
>> [2] https://github.com/GeoNode/geonode/blob/master/
>> geonode/geoserver/helpers.py#L1730
>> [3] https://github.com/GeoNode/geonode/blob/
>> df12893ced001973bd748f86d08fa6ae4c10dde9/geonode/geoserver/
>> signals.py#L497
>> [4] https://github.com/GeoNode/geonode/blob/
>> df12893ced001973bd748f86d08fa6ae4c10dde9/package/support/
>> geonode.updateip#L126
>> [5] http://docs.geonode.org/en/master/tutorials/install_
>> and_admin/geonode_install/install_geoserver_application.
>> html#geonode-authentication-integration
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A -
> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
> Massarosa
> (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180614/a5bcdbf4/attachment-0001.html>
More information about the geonode-users
