[GeoNode-users] Problems with deleting a layer (Ariel Cabezas)
Ariel Cabezas
gerardoarielc at gmail.com
Fri Jun 22 13:41:50 PDT 2018
Toni, thanks for the guide. Everything is working well,
I want to report a issue; the data uploaded to the geonode are all in EPSG
4326, located in the north of Argentina,
the problem: the map center in the map preview did not appear correctly,
they were shown on the map displaced towards southern Africa.
After trying many things, modify the DEFAULT_MAP_CRS from 900913 to 3857 in
the local_settings.py file, and the preview of the maps began to display
correctly.
I mention this, in case the same problem happens to someone.
I think this is not the final solution, it would have to be validated for
other CRS, but it worked for this particular case.
My installation, Geonode 2.8 from PPA in Ubuntu server 16.04 in a PROXMOX
environment, all data with EPSG 4326.
Sincerely,
Ariel
2018-06-22 3:15 GMT-03:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>:
> Hi Ariel,
> I had a look at the table layers_layerfile. From what I see it should be
> save to delete
> rows directly (If they trouble you). Make a backup before to be save.
> As written before that please try
> $ python manage.py updatelayers --remove-deleted
> (from a quick look at the source it will leave the table untouched but it´s
> worth a try ;)
> cheers,
> toni
> CSGIS
> Kolonnadenstraße 1
> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 21.06.2018 um 18:46 schrieb Ariel Cabezas <gerardoarielc at gmail.com>:
> layers_layerfile
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180622/9e933e0f/attachment.html>
More information about the geonode-users
