[GeoNode-users] Switching to SSL login problems
Dimitris Karakostis
karakostis.dimitris at gmail.com
Tue Jun 26 00:11:14 PDT 2018
Hello Nils,
I've been through the same process a couple of weeks ago and I also faced
the same issue (we have GeoNode 2.4). Eventually Francesco Bartoli
recommended to add the SSL certificates apart from the webserver (in my
case nginx) also in the keystores of java and the python http module. I
have also added the certs in the OS level. After that the authentication
between GeoNode and Geoserver started working again.
Let me know if this works for you.
Dimitris
On Mon, Jun 25, 2018 at 1:24 PM, Nils Noelke <nilsnoelke at googlemail.com>
wrote:
> Hi,
> I recently switched to SSL following the instructions from here:
> http://docs.geonode.org/en/master/tutorials/advanced/
> geonode_production/ssl.html
> Everything went fine, so I can reach Geonode now by SSL as well as the
> Geoserver, but wat is not working anymore is the authentication between
> Geonode and Geoserver.
> If I open the GeoServer from Geonode as the admin than I'am not logged in
> and no layer is displayed
> It seems that the geonodeauth module is able to work with SSL without
> changing some settings.
> Does anybody if there are other settings to modify?
> Nils
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180626/0387b578/attachment.html>
More information about the geonode-users
