[GeoNode-users] Problem with GeoFence permissions
Daniel Victoria
daniel.victoria at gmail.com
Mon Mar 5 09:26:39 PST 2018
Hi Paolo,
Thanks for the tip. However, I installed GeoNode from the APT repository
and I have no idea how to upgrade GeoNode or change GeoFence store from H2
to PostgreSQL.
I also added time.sleep(5) in sync_geofence.py, right before the try block
but I'm still getting an error: It fails with the message:
('Unexpected error:', <type 'exceptions.AttributeError'>)
File "/usr/bin/django-admin", line 21, in <module>
management.execute_from_command_line()
File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
354, in execute_from_command_line
utility.execute()
File
346, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv
self.execute(*args, **cmd_options)
line 445, in execute
output = self.handle(*args, **options)
File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/sync_geofence.py",
line 60, in handle
print 'perm_spec is %s' % perm_spec
UnboundLocalError: local variable 'perm_spec' referenced before assignment
Any other tips on how to fix this permission mess-up?
Thanks
Daniel
On Mon, Mar 5, 2018 at 12:13 PM Paolo Corti <pcorti at gmail.com> wrote:
> Another option could be to run a time.sleep for some seconds after
> each layer iteration in sync_geofence command
> cheers
> Paolo
> On Mon, Mar 5, 2018 at 10:04 AM, Paolo Corti <pcorti at gmail.com> wrote:
> > Hi Daniel
> > You seem to have hit this bug which I reported to GeoFence team in the
> past:
> > https://github.com/geoserver/geofence/issues/98
> > I didn't notice this happening in latest GeoFence version, so
> > upgrading to latest GeoNode could be an option.
> > Or you could try to use PostgreSQL instead than H2 as a GeoFence store
> > hope this helps
> > cheers
> > Paolo
> > On Mon, Mar 5, 2018 at 9:19 AM, Daniel Victoria
> > <daniel.victoria at gmail.com> wrote:
> >> Update: Apparently, if I update the layer permissions in the web
> interface
> >> or if i run `geonode updatelayers -f <layer_name>`, the correct GeoFence
> >> permissions are created. Thus, doing so a layer at a time works. But
> several
> >> layers at once, no.
> >> What should I look for in the GeoServer log to try to figure out where
> the
> >> problem is occurring? I can attach the GeoServer log if that helps.
> >> Cheers
> >> Daniel
> >> On Mon, Mar 5, 2018 at 9:52 AM Daniel Victoria <
> >> wrote:
> >>> Hi list,
> >>> I have GeoNode 2.6.3, installed from apt, in a Ubuntu machine. Right
> now i
> >>> have 108 registered layers, some imported using the web interface, some
> >>> using the `geonode importlayers` command.
> >>> Last week I noticed that some of the layers I was importing using the
> >>> management command had view permission problems. I realized that the
> cause
> >>> was that the GeoFence rules were not being created correctly.
> >>> Looking at the messages on the list, I saw that there were some
> >>> discussions about this issue and that 1) there was a patch for
> >>> geoserver/helper.py [1] and 2) a new `sync_geofence` management
> command.
> >>> I applied the patch and downloaded the `sync_geofence` command.
> >>> Now, every time I run `geonode updatelayers` I end up with a different
> set
> >>> of rules in GeoFence. Some times with 106 rules, some times with 209
> rules
> >>> etc. And I can't run `geonode sync_geofence` since I'm getting an
> error:
> assignment
> >>> Any idea how to fix this issue so I don't have to manually create the
> >>> GeoFence rules? And also, not have `geonode updatelayers` mess up the
> rules
> >>> already created?
> >>> Cheers
> >>> Daniel
> >>> [1] -
> https://github.com/GeoNode/geonode/commit/94b3b6abfd1bc856be94eb58f5bf13
> >> _______________________________________________
> >> geonode-users mailing list
> >> geonode-users at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
> > Paolo Corti
> > Geospatial software developer
> > web: http://www.paolocorti.net
> > twitter: @capooti
> > skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180305/e1ec4c32/attachment-0001.html>
More information about the geonode-users
