[GeoNode-users] Problem with GeoFence permissions
Daniel Victoria
daniel.victoria at gmail.com
Tue Mar 6 08:26:07 PST 2018
Hi Paolo,
I removed the try block. The error happens in the first print statement,
when it tries to print layer.alternate.
It says:
AttributeError: 'Layer' object has no attribute 'alternate'
I then removed the layer.alternate from the print statement and the
sync_geofence command runs. But each time I run it, I get a different
number of geofence data rules.
I'll try to run the commands in a python interpreter and try to identify
what's going on.
Cheers
On Tue, Mar 6, 2018 at 11:37 AM Paolo Corti <pcorti at gmail.com> wrote:
> Daniel
> remove the try block, and paste here the error trace stack
> ps: to debug with the shell, you must use "django-admin shell" command
> (which is "geonode shell" if you are using the Ubuntu package, I
> believe)
> thanks
> Paolo
> On Tue, Mar 6, 2018 at 7:11 AM, Daniel Victoria
> <daniel.victoria at gmail.com> wrote:
> > Hi Paolo,
> > There are 2 print statements in the except block. The first prints the
> error
> > and the second is the one that complains about the variable 'perm_spec'
> > referenced before assignment.
> > If I comment out just the second print statement I the following message
> > printed to the screen, one for each layer registered in GeoServer
> > ('Unexpected error:', <type 'exceptions.AttributeError'>)
> > I tried to run the commands in a python interpreter to debug this. But I
> > could not get the environment set. When I import the
> geonode.layers.models
> > in the interpreter, it complains about django_settings_module.
> > Cheers
> > Daniel
> > On Mon, Mar 5, 2018 at 10:08 PM Paolo Corti <pcorti at gmail.com> wrote:
> >> Hi Daniel
> >> can you try to remove the line with the print statement and see what
> >> kind of error is raising?
> >> Paolo
> >> On Mon, Mar 5, 2018 at 12:26 PM, Daniel Victoria
> >> > Hi Paolo,
> >> > Thanks for the tip. However, I installed GeoNode from the APT
> repository
> >> > and
> >> > I have no idea how to upgrade GeoNode or change GeoFence store from H2
> >> > to
> >> > PostgreSQL.
> >> > I also added time.sleep(5) in sync_geofence.py, right before the try
> >> > block
> >> > but I'm still getting an error: It fails with the message:
> >> > Traceback (most recent call last):
> >> > File "/usr/bin/django-admin", line 21, in <module>
> >> > management.execute_from_command_line()
> >> > File
> >> > "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
> >> > line
> >> > 354, in execute_from_command_line
> >> > utility.execute()
> >> > File
> >> > line
> >> > 346, in execute
> >> > self.fetch_command(subcommand).run_from_argv(self.argv)
> >> > File
> >> > "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
> >> > line 394, in run_from_argv
> >> > self.execute(*args, **cmd_options)
> >> > File
> >> > line 445, in execute
> >> > output = self.handle(*args, **options)
> >> > File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/sync_geofence.py",
> >> > line 60, in handle
> >> > print 'perm_spec is %s' % perm_spec
> >> > UnboundLocalError: local variable 'perm_spec' referenced before
> >> > assignment
> >> > Any other tips on how to fix this permission mess-up?
> >> > Thanks
> >> > Daniel
> >> > On Mon, Mar 5, 2018 at 12:13 PM Paolo Corti <pcorti at gmail.com> wrote:
> >> >> Another option could be to run a time.sleep for some seconds after
> >> >> each layer iteration in sync_geofence command
> >> >> cheers
> >> >> Paolo
> >> >> On Mon, Mar 5, 2018 at 10:04 AM, Paolo Corti <pcorti at gmail.com>
> wrote:
> >> >> > Hi Daniel
> >> >> > You seem to have hit this bug which I reported to GeoFence team in
> >> >> > the
> >> >> > past:
> >> >> > https://github.com/geoserver/geofence/issues/98
> >> >> > I didn't notice this happening in latest GeoFence version, so
> >> >> > upgrading to latest GeoNode could be an option.
> >> >> > Or you could try to use PostgreSQL instead than H2 as a GeoFence
> >> >> > store
> >> >> > hope this helps
> >> >> > cheers
> >> >> > Paolo
> >> >> > On Mon, Mar 5, 2018 at 9:19 AM, Daniel Victoria
> >> >> >> Update: Apparently, if I update the layer permissions in the web
> >> >> >> interface
> >> >> >> or if i run `geonode updatelayers -f <layer_name>`, the correct
> >> >> >> GeoFence
> >> >> >> permissions are created. Thus, doing so a layer at a time works.
> But
> >> >> >> several
> >> >> >> layers at once, no.
> >> >> >> What should I look for in the GeoServer log to try to figure out
> >> >> >> where
> >> >> >> the
> >> >> >> problem is occurring? I can attach the GeoServer log if that
> helps.
> >> >> >> Cheers
> >> >> >> Daniel
> >> >> >> On Mon, Mar 5, 2018 at 9:52 AM Daniel Victoria
> >> >> >> wrote:
> >> >> >>> Hi list,
> >> >> >>> I have GeoNode 2.6.3, installed from apt, in a Ubuntu machine.
> >> >> >>> Right
> >> >> >>> now i
> >> >> >>> have 108 registered layers, some imported using the web
> interface,
> >> >> >>> some
> >> >> >>> using the `geonode importlayers` command.
> >> >> >>> Last week I noticed that some of the layers I was importing using
> >> >> >>> the
> >> >> >>> management command had view permission problems. I realized that
> >> >> >>> the
> >> >> >>> cause
> >> >> >>> was that the GeoFence rules were not being created correctly.
> >> >> >>> Looking at the messages on the list, I saw that there were some
> >> >> >>> discussions about this issue and that 1) there was a patch for
> >> >> >>> geoserver/helper.py [1] and 2) a new `sync_geofence` management
> >> >> >>> command.
> >> >> >>> I applied the patch and downloaded the `sync_geofence` command.
> >> >> >>> Now, every time I run `geonode updatelayers` I end up with a
> >> >> >>> different
> >> >> >>> set
> >> >> >>> of rules in GeoFence. Some times with 106 rules, some times with
> >> >> >>> 209
> >> >> >>> rules
> >> >> >>> etc. And I can't run `geonode sync_geofence` since I'm getting an
> >> >> >>> error:
> >> >> >>> assignment
> >> >> >>> Any idea how to fix this issue so I don't have to manually create
> >> >> >>> the
> >> >> >>> GeoFence rules? And also, not have `geonode updatelayers` mess up
> >> >> >>> the
> >> >> >>> rules
> >> >> >>> already created?
> >> >> >>> Cheers
> >> >> >>> Daniel
> >> >> >>> [1] -
> https://github.com/GeoNode/geonode/commit/94b3b6abfd1bc856be94eb58f5bf13
> >> >> >> _______________________________________________
> >> >> >> geonode-users mailing list
> >> >> >> geonode-users at lists.osgeo.org
> >> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
> >> >> > Paolo Corti
> >> >> > Geospatial software developer
> >> >> > web: http://www.paolocorti.net
> >> >> > twitter: @capooti
> >> >> > skype: capooti
> >> >> Paolo Corti
> >> >> twitter: @capooti
> >> >> skype: capooti
> >> Paolo Corti
> >> twitter: @capooti
> >> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180306/9b6b3592/attachment.html>
More information about the geonode-users
