[GeoNode-users] Various issues GeoNode 2.6 and 2.8
Federico Gianoli alpacagis at gmail.com
Fri Mar 9 01:17:23 PST 2018
Dear all,
I have some issues with myGeoNode istances.
Version 2.6.x
I am not able to change the contactrole from the django Administration
panel, (Admin > Base>Contact roles). I have the same issue on the 2.8rc11
version. Could it be a problem with django permission?
On the same version (2.6) it isn't possible to change the "owner" or the
point of contact of a layer from the metadata form page, but I I have noted
that in the 2.8rc11 version this issue was solved. Is it possible to port
this fix in the previous version? If yes, where can I find the correct code?
On the same 2.6 istance, I have a problem with the thumbnails generations.
GeoNode creates only a white png for the layers. If I run "geonode
updatelayers" the problem is not solved and I can not create the thumbnails
manually.
I read that this problem was solved on the new version, is it true?
Do you suggest me to move to 2.8 in order to solve this?
On the version 2.8rc11 I have an error with the map generation.
I am not able to see any layer in a map
If I do an inspect on the page I have these errors:
Failed to load resource: net::ERR_CONNECTION_REFUSED
wms:1 GET
http://localhost/geoserver/wms?SERVICE=WMS&access_token=ri9yEX1YquZrz5yoo66lWz5hRUaDFr&&LAYERS=geonode%3Alabels&FORMAT=image%2Fpng&TRANSPARENT=TRUE&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=5009377.085,3757032.81375,6261721.35625,5009377.085&WIDTH=256&HEIGHT=256
But I see the layer correctly from the layer view...
Where am I doing wrong?
Someone had the same issue?
Thanks a lot
Fede
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180309/c05122d7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180309/c05122d7/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180309/c05122d7/attachment-0003.png>
More information about the geonode-users mailing list
