[GeoNode-users] Issues with Geonode map client after Linux
Joshi, Jigeeshu Jigeeshu.Joshi at ils-forschung.de
Mon May 14 00:44:47 PDT 2018
Hi Toni,
With the update, now the Geonode version is 2.8,
Geoserver version : 2.12-SNAPSHOT,
Ubuntu version : 16.04 xenial 64 minimal.
Yes I get pink tiles.
The layer preview on Geoserver also does not work.  When I click on Openlayers for preview it directs to localhost , even after I replace localhost with our web hostname I do not see the layer in the map. Even style preview does not work. Moreover Geoserver layers are not available when I try to add layers to the map. So there is certainly some problem loading geoserver resources in geonode ?
Error in dev console:
Access to Image at 'https://a.tile.openstreetmap.org/2/2/4.png' new?layer=geonode:ne_10m_admin_0_countries1:1  from origin 'https://www.ils-geomonitoring.de' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'https://www.ils-geomonitoring.de' is therefore not allowed access. The response had HTTP status code 404.
Thanks
Jio
Von: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] Im Auftrag von Toni Schönbuchner
Gesendet: Freitag, 11. Mai 2018 22:12
An: geonode-users at lists.osgeo.org
Betreff: Re: [GeoNode-users] Issues with Geonode map client after Linux
Dear Jio,
can you give a little more insight about your setup?
Which geonode, geoserver and Ubuntu Version are you actually running?
I assume you´re getting pink tiles right? First thing I would start with is:
does your layer preview work from geoserver gui? And are styles visible
in Geoserver?
Query and editing tools are not working for any user.
Which errors do you get in browser dev console?
Best regards,
Toni
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Mobil   +49/ (0) 176 6680 3198
Tel                   +49/ (0) 341 24 04 738
Fax                  +49/ (0) 341 24 04 73
Web                 http://csgis.de
Hinweis gemäß § 33 BDSG
Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
Am 11.05.2018 um 21:00 schrieb geonode-users-request at lists.osgeo.org<mailto:geonode-users-request at lists.osgeo.org>:
Message: 1
Date: Fri, 11 May 2018 08:09:54 +0000
From: "Joshi, Jigeeshu" <Jigeeshu.Joshi at ils-forschung.de<mailto:Jigeeshu.Joshi at ils-forschung.de>>
To: "geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>" <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
Subject: [GeoNode-users] Issues with Geonode map client after Linux
                software                update
Message-ID:
                <C4675B166D9C52428D58A434086CE80D23ACA8 at srv-exch.ils.local<mailto:C4675B166D9C52428D58A434086CE80D23ACA8 at srv-exch.ils.local>>
Content-Type: text/plain; charset="utf-8"
Hi All,
We have Geonode installed (not the latest 2.8) on linux server (Ubuntu). It is standard quick installation and not for development. So then, couple of weeks ago I ran the usual Linux update (apt get update) which resulted in update of tomcat from 7 to 8.  This did not go well with Geoserver. So we had to setup tomcat 7 again.  And since then we are having issues rendering layers in Geonode map client:
-          Layers are not visible. No layer style available it seems.  After running 'geonode updatelayers' they are visible for that session.
-          Overlaying more than one layer does not work (all layers have same reference system ) even after 'geonode updatelayers'.
-          Query and editing tools are not working for any user.
If anyone has had such an issue or aware of it. Kindly provide a solution.
Regards,
Jio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180514/e44d985d/attachment.html>
More information about the geonode-users mailing list
