[GeoNode-users] Leaflet settings
Stefano.LUONI at ext.ec.europa.eu Stefano.LUONI at ext.ec.europa.eu
Mon May 14 07:57:50 PDT 2018
Hi Alessio,
I have a bunch of errors where Leaflet is marked as initiatior of request (see attachment). This is from a page in a custom Geonode project; however, tiles are not loading in Geonode layer pages too.
Thanks,
Stefano
From: Alessio Fabiani [alessio.fabiani at geo-solutions.it]
Sent: 14 May 2018 16:35
To: LUONI Stefano (JRC-ISPRA-EXT)
Cc: geonode-users
Subject: Re: [GeoNode-users] Leaflet settings
So, in GeoNode 2.7 the Javascript context of the map is a bit different from the precious versions. It contains more informations about layer projection and temporal dimension.
Most probably the old Leaflet JS map configuration is no more able to find the layer configurations from the new-style json.
I'll try to take a look at this. In the meantime, can you confirm that you have a bunch of Javascript errors when trying to load the Leaflet viewer?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
2018-05-14 16:21 GMT+02:00 <Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu>>:
Hi everyone,
map tiles suddenly stopped loading on my Geonode installation (2.7); the urls generated by Leaflet are like https://c.tile.openstreetmap.org/3/3/2.png and simply won't load.
When I first installed Geonode I left all map and layers settings as default and everything worked. Can you address me on how I'm supposed to configure Geonode's Leaflet to use another layer provider, such as Mapbox, or do you have different suggestions to solve my issue?
Thanks,
Stefano
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180514/ef45a501/attachment-0001.html>
Type: image/png
Desc: tile_errors.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180514/ef45a501/attachment-0001.png>
More information about the geonode-users mailing list
