[GeoNode-users] Geonode DevMode Installation (Julierme Pinheiro)
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Wed May 16 11:32:54 PDT 2018
Dear Toni Schonbuchner,
Thank you very much for the updates and explanation. I could see through
the link https://github.com/GeoNode/geonode/blob/master/pavement.py#L560
that Paver Script (pavement.py) has 3 functions def setup_geoserver
start_geoserver and stop_geoserver.
I realized these functions here http://geonode.org/dev-workshop/#/2/3
and in here
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html
1 -$ paver setup
*# This command downloads and extract the correct GeoServer version*
2 -$ paver sync
*# This command prepares the DB tables and loads initial data*
3 -$ paver start
*# This command allows you to start GeoNode in development mode*
When I installed geonode from source (
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/),
I realized at the installation stage (
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html)
I had geoserver being fired by tomcat8 in port 8080 <
http://localhost:8080/geoserver> and in port 80 <
http://localhost/geoserver/web>. However, during geonode-project
installation (https://github.com/GeoNode/geonode-project), one thing to do
is to run *DJANGO_SETTINGS_MODULE=my_geonode.settings paver setup *and this
command will download geoserver and in this point I have a question: in
which port geoserver is going to run, because I have already por 80 and
8080 being used for geonode production installed from source (using
virtualenv).
If I run *DJANGO_SETTINGS_MODULE=my_geonode.settings paver stop or paver
stop or paver stop_geoserver *this is the response to
pavement.stop_geoserver
Stopping java (process number 1215)
File
"/home/geo/Envs/my_geonode/local/lib/python2.7/site-packages/paver/tasks.py",
line 196, in _run_task
return do_task()
File
line 192, in do_task
task()
File
line 321, in __call__
retval = environment._run_task(self.name, self.needs, self.func)
File
line 214, in _run_task
return do_task()
File
line 193, in do_task
return func(**kw)
File "pavement.py", line 470, in stop_geoserver
kill('java', 'geoserver')
File "pavement.py", line 1051, in kill
% (arg1, '\n'.join([l.strip() for l in lines])))
Exception: Could not stop java: Running processes are
tomcat8 1215 0.8 9.2 4524172 944172 ? Sl 10:54 2:13
/usr/lib/jvm/default-java/bin/java
-Djava.util.logging.config.file=/var/lib/tomcat8/conf/logging.properties
-Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
-Djava.awt.headless=true -XX:MaxPermSize=512m -XX:PermSize=128m -Xms512m
-Xmx2048m -Duser.timezone=GMT -Dorg.geotools.shapefile.datetime=true
-XX:+UseConcMarkSweepGC -XX:+UseParNewGC -XX:ParallelGCThreads=4
-Dfile.encoding=UTF8 -Duser.timezone=GMT
-Djavax.servlet.request.encoding=UTF-8
-Djavax.servlet.response.encoding=UTF-8
-DGEOSERVER_DATA_DIR=/data/geoserver-data
-Dgeofence.dir=/data/geoserver-data/geofence
-DGEOSERVER_LOG_LOCATION=/data/geoserver-logs/geoserver.log
-DGEOWEBCACHE_CACHE_DIR=/data/gwc_cache_dir
-Djava.endorsed.dirs=/usr/share/tomcat8/endorsed -classpath
/usr/share/tomcat8/bin/bootstrap.jar:/usr/share/tomcat8/bin/tomcat-juli.jar
-Dcatalina.base=/var/lib/tomcat8 -Dcatalina.home=/usr/share/tomcat8
-Djava.io.tmpdir=/tmp/tomcat8-tomcat8-tmp
org.apache.catalina.startup.Bootstrap start
geo 23162 0.0 0.0 4508 756 pts/1 S+ 15:18 0:00 /bin/sh -c
ps aux | grep java
geo 23164 0.0 0.0 21296 1016 pts/1 S+ 15:18 0:00 grep java
Also after refreshing the browser, geonode-project (http://localhost:8000)
and geoserver (http://localhost:8080/geoserver), both sites keep running.
Why I can not stop geonode-project and geoserver through paver? Also when I
ran *DJANGO_SETTINGS_MODULE=my_geonode.settings paver start *for the first
time a warning message says that port 8080 has been already used and indeed
it is being used by geoserver in geonode production as mentioned above.
I appreciated your time and help.
Kind regards
Julierme
2018-05-16 5:13 GMT-03:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>:
> Dear Julierme,
> I got confused in one thing here. When Geonode is installed in DevMode,
> Geoserver and Geonode are served by Paver.
> this is a bit vague. Paver does not „serve“ geonode or geoserver.
> It´s a managment tool like make which runs tasks for you.
> So when you run 'paver start‘ it runs django´s build in webserver:
> and ‚jetty' to serve geoserver:
> https://github.com/GeoNode/geonode/blob/master/pavement.py#L685
> Django´s runserver reloads whenever you change some py file.
> Perfect for development;) But not for production:
> Now’s a good time to note: *don’t* use this server in anything resembling
> a production environment. It’s intended only for use while developing.
> (We’re in the business of making Web frameworks, not Web servers.)
> https://docs.djangoproject.com/en/2.0/intro/tutorial01/
> In production you setup apache or nginx uwsgi, or … together with most
> likely
> Tomcat to serve geonode and geoserver. (Apache does not restart if
> you change a python file as runserver does ;)
> Hope that clarifies things a bit.
> Cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1
> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 15.05.2018 um 18:08 schrieb geonode-users-request at lists.osgeo.org:
> Dear geonode Developers,
> Geoserver and Geonode are served by Paver. So, I can do that following any
> of these guides:
> 1 - Ubuntu 16.04 LTS installation until the end of this URL:
> 2 - https://github.com/GeoNode/geonode-project
> 3 - http://geonode.org/dev-workshop/#/3/2
> And when geonode is not in DevMod are the followings cases:
> 1 - Installed via apt-get
> 2 - Geoserver is served by tomcat and Geonode by apache2
> Are my statements corrects? Could someone give an explanation on that
> please?
> Thank you for your time in advance
> Kind regards
> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180516/a543fdf3/attachment.html>
More information about the geonode-users
