[GeoNode-users] Commiting Geonode-Project Changes to Geonome Production
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Wed May 16 12:40:55 PDT 2018
Hi all,
I finally got to solve this problem. The issue was related to geonode.conf.
After some tests I concluded that for my case:
DocumentRoot and Alias /uploaded/ could be either
/home/my_geonode/my_geonode/my_geonode or
/home/geonode/my_geonode/my_geonode
However, for the rest of the configuration, this was the final settings:
WSGIDaemonProcess geonode
python-path=/home/geonode/my_geonode:/home/geo/Envs/geonode/lib/python2.7/site-packages
user=www-data threads=15 processes=2
<VirtualHost *:80>
ServerName http://localhost
ServerAdmin webmaster at localhost
DocumentRoot /home/my_geonode/my_geonode/my_geonode
LimitRequestFieldSize 32760
LimitRequestLine 32760
ErrorLog /var/log/apache2/error.log
LogLevel warn
CustomLog /var/log/apache2/access.log combined
WSGIProcessGroup geonode
WSGIPassAuthorization On
WSGIScriptAlias / /home/my_geonode/my_geonode/my_geonode/wsgi.py
Alias /static/ /home/my_geonode/my_geonode/my_geonode/static_root/
Alias /uploaded/ /home/my_geonode/my_geonode/my_geonode/uploaded/
<Directory "/home/my_geonode/my_geonode/my_geonode/">
<Files wsgi.py>
Order deny,allow
Allow from all
Require all granted
</Files>
Order allow,deny
Options Indexes FollowSymLinks
Allow from all
IndexOptions FancyIndexing
</Directory>
<Directory "/home/my_geonode/my_geonode/my_geonode/static_root/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/thumbs/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/avatars/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory
"/home/my_geonode/my_geonode/my_geonode/uploaded/people_group/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/group/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/documents/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/layers/">
Order allow,deny
Allow from all
Require all granted
</Directory>
<Proxy *>
Order allow,deny
Allow from all
</Proxy>
ProxyPreserveHost On
ProxyPass /geoserver http://127.0.0.1:8080/geoserver
ProxyPassReverse /geoserver http://127.0.0.1:8080/geoserver
</VirtualHost>
Thank you all for the patience.
I appreciated it
Julierme
2018-05-16 13:08 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> Hi All,
> I had try to commit genode-project template (index.html) changes to
> geonode production installed via apt-get, but I had an issue related to the
> production database. After configuring geonode.conf, I could see the
> changes over geonode production templates, made through geonode-project,
> however my production database would get covered / disappeared after
> geonode.conf according to geonode-project WSGI.
> So, I changed my approach and I installed geonode from source as in here:
> http://docs.geonode.org/en/master/tutorials/install_and_
> admin/geonode_install/
> I have geonode production running in virtualenv directory "/home/geo/Envs"
> and it is found in /home/geonode/my_geonode/*
> I have geonode-progect in the same virtualenv directory "/home/geo/Envs"
> and it is found in /home/my_geonode/my_geonode/*
> I installed geonode-project as in here https://github.com/GeoNode/
> geonode-project (Using Virtualenv)
> Now, I am having the same issue, my production database "development.db" =
> sqlite that is in ~/Envs/geonode/lib/python2.7/site-packages/geonode/development.db
> is being covered or disappears after geonode.conf configuration.
> I have granted all permissions to development.db (-rwxrwxrw- 1 www-data
> www-data 425984 Mai 14 13:40 development.db) but the issue remains and I am
> unable to sign in to geonode production.
> Could someone help me to figure out what is going on and get this problem
> fixed? Find bellow my geonode.conf
> WSGIDaemonProcess geonode python-path=/home/my_geonode/
> my_geonode:/home/geo/Envs/my_geonode/lib/python2.7/site-packages
> <VirtualHost *:80>
> DocumentRoot /home/geonode/my_geonode/my_geonode
> LogLevel warn
> <Files wsgi.py>
> Order deny,allow
> Allow from all
> Require all granted
> </Files>
> Order allow,deny
> Allow from all
> </Directory>
> Order allow,deny
> Allow from all
> Require all granted
> </Directory>
> Order allow,deny
> Allow from all
> Require all granted
> </Directory>
> Order allow,deny
> Allow from all
> Require all granted
> </Directory>
> <Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/people_
> group/">
> Order allow,deny
> Allow from all
> Require all granted
> </Directory>
> Order allow,deny
> Allow from all
> Require all granted
> </Directory>
> Order allow,deny
> Allow from all
> Require all granted
> </Directory>
> Order allow,deny
> Allow from all
> Require all granted
> </Directory>
> <Directory "/home/my_geonode/my_geonode/">
> Order allow,deny
> Require all granted
> </Directory>
> <Proxy *>
> Order allow,deny
> Allow from all
> </Proxy>
> </VirtualHost>
> Thank you for your time in advance
> Kind regards
> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180516/2ed5e082/attachment-0001.html>
More information about the geonode-users
