[GeoNode-users] Geonode-Project: Apache Config / geonode.conf
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Thu May 17 11:30:51 PDT 2018
2018-05-17 15:30 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> Hi Francesco,
> Thank you for your questions. I added tabs and text change to geonode-dev
> (geonode-dev.png) and I can see the changes over geonode-production
> (geonode-production.png). However If I keep WSGIDaemonProcess my_geonode
> python-path=/home/my_geonode/my_geonode:/home/geo/Envs/my_
> geonode/lib/python2.7/site-packages user=www-data threads=15 processes=2
> I can see the changes done through geonode-dev css and site_base.html and
> site_index.html over the geonode-production, But geonode-production uses
> geonode-dev within this python-path config.
> However if I keep WSGIDaemonProcess geonode python-path=/home/geonode/my_
> geonode:/home/geo/Envs/geonode/lib/python2.7/site-packages user=www-data
> I can see the changes done through geonode-dev css and not the changes in
> site_base.html and site_index.html. But geonode-productions is using its
> right database.
> Could you give a clue in what is going on? I also following the directions
> in here http://geonode.org/dev-workshop/#/8/3.
> Thank you for your time in advance
> Julierme
> 2018-05-17 13:16 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Once you have installed GeoNode as a library/package in your my_geonode
>> virtual environment did you see your custom text and tabs changes starting
>> the development server? That means “python manage.py run server” ?
>> Once you’ll get this achievement then the apache configuration will be
>> easier.
>> Hope this helps
>> Francesco
>> Il giorno 17/mag/2018, alle ore 18:01, Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear Framcesco,
>> Thank you very much for your reply. I have gone through
>> http://geonode.org/dev-workshop/#/ several times. It is a great source,
>> but again this issue was related to geonode.conf /apache2 config.
>> I got to fix this problem making changes to geonode.conf. In my case, if
>> I have geonode production in /home/geonode and geonode-project in
>> /home/my_geonode, the geonode.conf must have all information related to
>> geonode-project, and I was still gathering information from
>> geonode-production in geonode.conf.
>> I appreciated your time and help.
>> Kind regards
>> Julierme
>> 2018-05-17 12:17 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Dear Julierme,
>>> I encourage you to follow scrupulously the developer workshop where
>>> everything you are trying to do is well covered http://geonode.org/dev
>>> -workshop/#/.
>>> Francesco
>>> Il giorno 17/mag/2018, alle ore 17:06, Julierme Pinheiro <
>>> Dear all geonode developers,
>>> I have made changes in my geonode production through geonode-project.
>>> Just now, I realized that the geonode-project css config is being applied
>>> to geonode production main page, however my new tabs and text change in
>>> site_base.html and site.index.html are not being applied to geonode
>>> production main page.
>>> I ran the commands python manage.py migrate and python manage.py
>>> collectstatic and realized that static_root was created in
>>> /home/my_geonode/my_geonode/my_geoonde/static_root
>>> geonode.conf Directories make reference to several paths
>>> /home/my_geonode/my_geonode/my_geonode/uploaded/ and
>>> /home/my_geonode/my_geonode/my_geonode/uploaded/* (group, people_group,
>>> documents, Layers, avatars and thumbs)
>>> but directory uploaded is no in /home/my_geonode/my_geonode/my_geoonode
>>> I wonder if this directory <uploaded> and its subdirectories <group,
>>> people_group, documents, Layers, avatars and thumbs> are added manually.
>>> In order to see the new tabs and text changes in geonode production, I
>>> also added another directory to geonode.conf
>>>  <Directory "/home/my_geonode/my_geonode/my_geonode/templates/">
>>>         Order allow,deny
>>>         Options Indexes FollowSymLinks
>>>         Allow from all
>>>         Require all granted
>>>         IndexOptions FancyIndexing
>>>  </Directory>
>>> The directory templates contains site_base.html and site_index.html. But
>>> yet I could not see the new tabs in my geonode production main page.
>>> Any help on that will be very appreciated.
>>> Kind regards
>>> Julierme
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180517/5a889aa3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180517/5a889aa3/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180517/5a889aa3/attachment-0003.png>
More information about the geonode-users mailing list
