[GeoNode-users] Best way to install geonode
Annalisa Schiavon
annalisa.schiavon at gmail.com
Fri Nov 9 05:57:45 PST 2018
Ok, thanks a lot!
Il giorno ven 9 nov 2018 alle ore 14:46 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Yes, sure.
> The instructions are a bit old but still valid.
> At most you could experience minor issues with the packages versions.
> Il giorno ven 9 nov 2018 alle ore 14:39 Annalisa Schiavon <
> annalisa.schiavon at gmail.com> ha scritto:
>> Hi Alessio,
>> the first time I chose a different password for DB's geonode user. Than I
>> change it to geonode in Postgres and run again the paver commands. But
>> something is still wrong.
>> local_settings seems correct now, maybe it's better if I start to install
>> from a clean server.
>> Can I follow
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>> to install Geonode 2.8 on Ubuntu 16.04 or is outdated/wrong ?
>> Because I could install a VM in my local VirtualBox (in ubuntu client
>> 16.04) and than test it locally, before migrate the virtual machine in
>> VMWARE, it will more simple for me, but I can't with Ubuntu 18.04.
>> Moreover, I have some difficulties with Postgres 10, I'd prefer 9.5.
>> Thanks again,
>> Annalisa
>> Il giorno ven 9 nov 2018 alle ore 13:19 Alessio Fabiani <
>>> Hai Annalisa,
>>> it looks to me that you haven't correctly setup the local_settings.py
>>> environment variables before running the paver commands.
>>> Please double check you have a DB installed with the correct
>>> username/password and that the info on local_settings file are correct.
>>> Il giorno ven 9 nov 2018 alle ore 12:24 Annalisa Schiavon <
>>>> Hi Alessio,
>>>> I've tried to follow your document: "GeoNode 2.9.x -Deployment on
>>>> Ubuntu 18.04" (
>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit).
>>>> I've installed a brand new ubuntu 18.04 server on our WMWARE.
>>>> When I run the command
>>>> (geonode) system at gaia:~/geonode$ sudo WORKON_HOME=/home/system/Envs/geonode DJANGO_SETTINGS_MODULE=geonode.local_settings GEONODE_ETC=/home/system/geonode/geonode GEOSERVER_DATA_DIR=/var/lib/tomcat8/webapps/geoserver/data geonode_updateip -p 192.168.31.80
>>>> I have many errors like:
>>>> django.db.utils.ProgrammingError: relation "django_site" does not existLINE 1: ..."django_site"."domain", "django_site"."name" FROM "django_si...
>>>> and I see that my geonode DB is empty!
>>>> I tried to run again
>>>> DJANGO_SETTINGS_MODULE=geonode.local_settings paver reset; \
>>>> paver setup; \
>>>> paver sync; \
>>>> python manage.py collectstatic --noinput
>>>> I get an error on reset:
>>>> [Errno 3] No such process
>>>> ---> pavement.stop_qgis_server
>>>> but nothing else.
>>>> I've have no experience with Virtual Env, so I wonder if all command
>>>> after
>>>> mkvirtualenv --no-site-packages geonode
>>>> are to run in virtual env or not.
>>>> I found another error after running " pip install -r requirements.txt
>>>> --upgrade--no-cache --no-cache-dir ":
>>>> Command "python setup.py egg_info" failed with error code 1 in
>>>> /tmp/pip-install-6qw4Pu/Twisted/
>>>> Any suggestions?
>>>> Annalisa
>>>> Il giorno ven 26 ott 2018 alle ore 16:38 Alessio Fabiani <
>>>>> Uhm... well, that command should install the GeoNode dependencies.
>>>>> Maybe this is the reason why you are not able to find some packages.
>>>>> Anyway, you must run paver reset from the "my_geonode" root folder,
>>>>> where the "pavement.py" file is located. If you already did that, then I
>>>>> guess your installation is a bit messed up.
>>>>> Il giorno ven 26 ott 2018 alle ore 16:24 Paulo Frias <
>>>>> pfrias82 at gmail.com> ha scritto:
>>>>>> Yes, but after that I had to downgrade some python packages.
>>>>>> On Fri, 26 Oct 2018 at 15:21, Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>> From the link you sent to me, did you run also this one?
>>>>>>> pip install -e . --upgrade
>>>>>>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <
>>>>>>>> I've followed this instructions
>>>>>>>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>>>>>>>> After "pip install Paver==1.2.4"
>>>>>>>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings
>>>>>>>> paver reset
>>>>>>>> Build failed: Unknown task: reset
>>>>>>>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>>>>>>>> Uhm, that is very strange. How did you setup GeoNode?
>>>>>>>>> However, it seems to me that the issue is related to a missing
>>>>>>>>> dependency.
>>>>>>>>> Try maybe by typing
>>>>>>>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <
>>>>>>>>>> Hi Alessio,
>>>>>>>>>> The (pip install -r requirements.txt --upgrade) worked fine
>>>>>>>>>> after another try.
>>>>>>>>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>>>>>>>>> This is the error produced:
>>>>>>>>>> paver reset
>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>> File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line
>>>>>>>>>> 7, in <module>
>>>>>>>>>> from paver.tasks import main
>>>>>>>>>> ImportError: No module named paver.tasks
>>>>>>>>>> Any idea how to solve this?
>>>>>>>>>> Thanks,
>>>>>>>>>> Paulo
>>>>>>>>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>>>>>>>>> Hi Paulo,
>>>>>>>>>>> can you describe what's happening with a bit more detail?
>>>>>>>>>>> That command should just start downloading the Python
>>>>>>>>>>> dependencies. If it is stuck, most probably there's a problem reaching the
>>>>>>>>>>> PyPi repositories.
>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>>> I'm trying to install Geonode on Mac os X, following the
>>>>>>>>>>>> tutorial you recommended (
>>>>>>>>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>>>>>>>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>>>>>>>>> Can you help me with some possible solution?
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Paulo Frias
>>>>>>>>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>>>>>>>>> Hi Julierme,
>>>>>>>>>>>>> please see my responses below.
>>>>>>>>>>>>> "1 - can I make geonode-project my production environment? I
>>>>>>>>>>>>> meant run GeoNode-Project as my production instance on the web."
>>>>>>>>>>>>> Sure, but you will need to tweak a bit security options and
>>>>>>>>>>>>> settings in order to secure and optimize your instance. Especially
>>>>>>>>>>>>> important are the admin passwords and openid keys. This is valid in any
>>>>>>>>>>>>> case though.
>>>>>>>>>>>>> "2 - do I need GeoNode Core to run together with
>>>>>>>>>>>>> GeoNode-Project?"
>>>>>>>>>>>>> geonode-project makes use of geonode-core as a dependency.
>>>>>>>>>>>>> Until we do final releases (2.10 and 2.8), meaning that packages will go on
>>>>>>>>>>>>> Pypi repositories, yes, you'll need the geonode-core among the python deps.
>>>>>>>>>>>>> "3 - GeoNode-Project can run independently, no need for
>>>>>>>>>>>>> GeoNode Core?"
>>>>>>>>>>>>> geonode-project runs independently, but it still needs
>>>>>>>>>>>>> geonode as a dependency. However by using it, you won't touch the
>>>>>>>>>>>>> geonode-core. This will allow you to easily keep it up to date with the
>>>>>>>>>>>>> development version, without clashes.
>>>>>>>>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>>>>>>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8
>>>>>>>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>>>>>>>>> The tutorial and the documentation in general is outdated. We
>>>>>>>>>>>>> are lacking of resources and, unfortunately, we did not found time yet to
>>>>>>>>>>>>> cleanup it. I'm very sorry about that.
>>>>>>>>>>>>> We will try to do it when we start officially the release
>>>>>>>>>>>>> process.
>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>>>>>>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>>>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>>>>>>>>> look.
>>>>>>>>>>>>>> Now:
>>>>>>>>>>>>>> GeoNode-Project?
>>>>>>>>>>>>>> GeoNode Core?
>>>>>>>>>>>>>> Thank you very much for your time in advance
>>>>>>>>>>>>>> Kind regards
>>>>>>>>>>>>>> Julierme
>>>>>>>>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>>>>>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>>>>>>>>>>> Thanks for the tip!
>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>>>>>>>>>> Yes, absolutely. Currently, the deb installation is the
>>>>>>>>>>>>>>>> most buggy and unstable one.
>>>>>>>>>>>>>>>> It is worth notice that now GeoNode provides natively a way
>>>>>>>>>>>>>>>> to customize the interface, at least some part of it, without the need of
>>>>>>>>>>>>>>>> changing the files or the templates.
>>>>>>>>>>>>>>>> Take a look at the GeoNode Themes option on the Django
>>>>>>>>>>>>>>>> Admin gui.
>>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>>>>>>>>> So you advise against the deb package installation, also
>>>>>>>>>>>>>>>>> if I don't think to develop on geonode, only to customize the look?
>>>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>>>>>>>>> If you want to install geonode for development, I would
>>>>>>>>>>>>>>>>>> suggest following the procedure here
>>>>>>>>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>>>>>>>>>>> If you want to start customizing your own portal (but
>>>>>>>>>>>>>>>>>> still develop it), I would suggest starting from a geonode-project
>>>>>>>>>>>>>>>>>> template. In that case, follow the instructions here
>>>>>>>>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant
>>>>>>>>>>>>>>>>>> or docker. There are several ways and configurations around that you might
>>>>>>>>>>>>>>>>>> want to evaluate.
>>>>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa
>>>>>>>>>>>>>>>>>> Schiavon <annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>>>>>>>>>>>>> Please someone may confirm that installation by deb
>>>>>>>>>>>>>>>>>>> packages, with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at
>>>>>>>>>>>>>>>>>>> now?)
>>>>>>>>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox
>>>>>>>>>>>>>>>>>>> installation (
>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>>>>>>>>> If I want to changes logos, colors and texts, is it
>>>>>>>>>>>>>>>>>>> recommended install geonode-project and create a template, in similar way
>>>>>>>>>>>>>>>>>>> than once? Because in
>>>>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project I find
>>>>>>>>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa
>>>>>>>>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04,
>>>>>>>>>>>>>>>>>>>> installed via apt-get, following these commands:
>>>>>>>>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>>>>>>>>> Then I had installed geonode-project for a few changes
>>>>>>>>>>>>>>>>>>>> in logos, colors and so on:
>>>>>>>>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>>>>>>>>>>> -epy,rst
>>>>>>>>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to
>>>>>>>>>>>>>>>>>>>> 2.8 (jumping the 2.6 release)?
>>>>>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>>>>>>> This email is intended only for the person or entity to
>>>>>>>>>>>>>>>>>> which it is addressed and may contain information that is privileged,
>>>>>>>>>>>>>>>>>> confidential or otherwise protected from disclosure. We remind that - as
>>>>>>>>>>>>>>>>>> provided by European Regulation 2016/679 “GDPR” - copying, dissemination or
>>>>>>>>>>>>>>>>>> use of this e-mail or the information herein by anyone other than the
>>>>>>>>>>>>>>>>>> intended recipient is prohibited. If you have received this email by
>>>>>>>>>>>>>>>>>> mistake, please notify us immediately by telephone or e-mail.
>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>> This email is intended only for the person or entity to which
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> notizia.
>>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181109/10c3eda9/attachment-0001.html>
More information about the geonode-users
