[GeoNode-users] GeoNode-Project Installation
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Thu Nov 22 13:04:39 PST 2018
Dear all,
Trying to find what is going on with GeoNode-Project at 2.8 docker
installation. Just for further information, I got to solve the SITEURL
issue by placing it after SITE_HOST_NAME and SITE_HOST_PORT in
local_settings.py at 2.8. But now, I am getting stuck in a database issue as
shown by docker-compose logs -f:
celery4my_geonode | django.db.utils.OperationalError: could not connect to
server: Connection refused
celery4my_geonode | Is the server running on host "localhost"
(127.0.0.1) and accepting
celery4my_geonode | TCP/IP connections on port 5432?
celery4my_geonode | could not connect to server: Network is unreachable
celery4my_geonode | Is the server running on host "localhost" (::1) and
accepting
Any help on that will be very appreciated.
Kind regards
Julierme
On Thu, Nov 22, 2018 at 5:03 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Toni,
> Thank you very much for the highlights. I got it.
> I appreciated your time.
> Regards
> Julierme
> On Thu, Nov 22, 2018 at 4:59 PM Julierme Pinheiro <
>> Regarding the previous e-mail:
>> I realized that in local_settings.py at 2.8 --> DATABASES: { 'HOST':
>> 'localhost' in, but local_settings.py at 2.7 --> DATABASES: { 'HOST': 'db'
>> Regards
>> Julierme
>> On Thu, Nov 22, 2018 at 4:47 PM Julierme Pinheiro <
>>> Hi Toni,
>>> Thank you very much for the hints. I see in
>>> https://github.com/GeoNode/geonode/commits/master/geonode/local_settings.py.geoserver.sample
>>> that there is a lot of work and contributions behind the whole project. You
>>> all deserve many rounds of beer in the next Summit. I hope to be there to
>>> celebrate with you all.
>>> I noticed those differences I mentioned before, mainly settings.py at 2.7
>>> has more configuration than settings.py at 2.8. And I am not sure about
>>> whether SITEURL can be declared before SITE_HOST_NAME and SITE_HOST_PORT (I
>>> can do a test changing SITEURL location in the file) in local_settings.py.
>>> My first guess is not because python interprets the file from top to the
>>> bottom.
>>> One thing to consider is: If we follow the guide
>>> <https://github.com/GeoNode/geonode-project/tree/2.8> the way it is,
>>> using local_settings in wsgi.py. The GeoNode-Project at 2.8 docker
>>> installation will fail.
>>> I appreciated your time, Toni.
>>> Kind regards
>>> Julierme
>>> On Thu, Nov 22, 2018 at 4:09 PM Toni Schönbuchner <
>>> toni.schoenbuchner at csgis.de> wrote:
>>>> Hi Julierme,
>>>> as a little hint. With github you can view the history of each file.
>>>> For example local_settings:
>>>> The commit message often explains why the file was updated.
>>>> When you click the button on the right hand side showing a specific
>>>> commit hash
>>>> you get a nice diff view what has changed. With this it should be easy
>>>> to
>>>> see what changed form 2.7 to 2.8 etc.
>>>> Do you notice something?
>>>> – Exactly! Most of the time it´s Allesio who changed the file.
>>>> That´s why we should spend him not only one round of beer
>>>> at the next summit :))
>>>> Hope this makes your work a bit easier
>>>> Cheers,
>>>> Toni
>>>> Am 22.11.2018 um 18:10 schrieb geonode-users-request at lists.osgeo.org:
>>>> Message: 2
>>>> Date: Thu, 22 Nov 2018 15:10:40 -0200
>>>> From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
>>>> To: handy at galerigis.com
>>>> Cc: geonode-users <geonode-users at lists.osgeo.org>, Paolo Corti
>>>> <pcorti at gmail.com>
>>>> Subject: Re: [GeoNode-users] GeoNode-Project Installation
>>>> Message-ID:
>>>> <CAKTKyJKinYoxwh4KV4VvqB2CaVGP407h8_y-cRDc1WLQVRm7+A at mail.gmail.com>
>>>> Content-Type: text/plain; charset="utf-8"
>>>> Dear all,
>>>> Ok. After many tests, I finally got GeoNode-Project installed using
>>>> "local_settings" in my_geonode/wsgi.py -->
>>>> os.environ.setdefault("DJANGO_SETTINGS_MODULE",
>>>> "my_geonode.local_settings").
>>>> I have an old instance of GeoNode-Project at 2.7 running in a VM. I
>>>> compared
>>>> settings and local_settings files of GeoNode-Project at 2.7 and
>>>> GeoNode-Project at 2.8. Here are some differences found:
>>>> Regarding local_settings.py
>>>> In GeoNode-Project at 2.8 SITEURL is declared before SITE_HOST_NAME and
>>>> SITE_HOST_PORT. But SITEURL depends on both variables.
>>>> In contrast, GeoNode-Project at 2.7, its local_settings.py sets SITEURL
>>>> right
>>>> after SITE_HOST_PORT and SITE_HOST_NAME. It seems the correct settings.
>>>> Regarding settings.py
>>>> What I realized is that settings.py for GeoNode-Project at 2.8 is smaller
>>>> than
>>>> GeoNode-Project at 2.7. For instance I can find configuration for #
>>>> prevent
>>>> signing up by default # in Geonode-Project at 2.7 settings.py , but I can
>>>> not
>>>> find the same config in GeoNode-Project at 2.8 settings.p.
>>>> What I did: I cloned geonode-project and my_geonode folders for
>>>> GeoNode-Project at 2.8 and I used settings.py at 2.7 and
>>>> instead of
>>>> settings.py at 2.8 and local_settings.py at 2.8. The response is:
>>>> GeoNode-Project at 2.8 is up and running via Docker installation.
>>>> Find the files settings.py and local_settings.py for GeoNode-Project at 2.7
>>>> and GeoNode-Project at 2.8 in attached.
>>>> Kind regards
>>>> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181122/5bdae0fb/attachment-0001.html>
More information about the geonode-users
