[GeoNode-users] updateip command
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Thu Nov 22 23:46:07 PST 2018
Yes it is dear handy,
this should work:
# PATH_TO_YOUR_VIRTUALENV = is the path to the geonode virtualenv
source PATH_TO_YOUR_VIRTUALENV/bin/activate
# let´s copy the scripts to /usr/bin to make it systemwide exectuable
sudo cp PATH_TO_YOUR_VIRTUALENV/package/support/geonode.binary /usr/bin/geonode
sudo cp PATH_TO_YOUR_VIRTUALENV/package/support/geonode.updateip /usr/bin/geonode_updateip
sudo chmod +x /usr/bin/geonode
sudo chmod +x /usr/bin/geonode_updateip
# set env vars. make sure to set correct settings name and correct path to your gn project
DJANGO_SETTINGS_MODULE=geonode.local_settings
GEONODE_ETC=/home/handy/geonode/geonode/geonode
GEOSERVER_DATA_DIR=/var/lib/tomcat8/webapps/geoserver/data
# now run updateip
geonode_updateip -p example.com
This is taken from Alessios install docs here:
https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
Best,
Toni
> Am 22.11.2018 um 23:13 schrieb Handy Rusydi <handy at galerigis.com>:
> I still dont get it. so it is possible to used python manage.py and geonode-update ip in one project?
> I am never used Ansible. it looks interested to learn.
> Cheers
> Handy
> Sent from myMail for Android
More information about the geonode-users
