[GeoNode-users] WMS GetCapabilities request takes too long to response on GeoExplorer
gpetrak gkpetrak at gmail.com
Fri Nov 23 05:29:31 PST 2018
Ok, thank you Francesco,
I 'll start with the Tomcat's log files and if I find the issue I 'll
post the solution here.
Best Regards,
George
On 23/11/18 15:05, Francesco Bartoli wrote:
> Sorry my email client acts all crazy…I wanted to say it probably
> requires time to understand what’s the problem. One possible starting
> point is to look at the GeoServer log while it is serving that request.
> Il 23 nov 2018, 13:58 +0100, Francesco Bartoli <xbartolone at gmail.com>,
> ha scritto:
>> There could be but it’s likely you have to spend time to understand
>> where the problem
>> Il 23 nov 2018, 13:57 +0100, Francesco Bartoli
>>> Il 23 nov 2018, 13:54 +0100, gpetrak <gkpetrak at gmail.com>, ha scritto:
>>>> Τhank you for your response Francesco,
>>>> We 're planning to upgrade to the latest version of GeoNode in
>>>> about four months but until then we have to work with these version
>>>> (GeoNode / GeoServer). I'm searching for a less "time consuming"
>>>> solution for the near future and when I found that other GeoNode
>>>> instances with older GeoServer versions (e.g 2.5) works fine with
>>>> WMS GetCapabilities request, I supposed that there should be an
>>>> easier solution.
>>>> Best regards,
>>>> George
>>>> On 23/11/18 14:34, Francesco Bartoli wrote:
>>>>> Hi George,
>>>>> even if there are cases which are still using such quite old
>>>>> version the suggestions here are still the same, I would strongly
>>>>> consider the upgrade. Neither GeoServer community nor GeoNode one
>>>>> still supports that version anymore.
>>>>> Best,
>>>>> Francesco
>>>>> Il 23 nov 2018, 13:01 +0100, George Petrakis <gkpetrak at gmail.com>,
>>>>> ha scritto:
>>>>>> Hello GeoNode community,
>>>>>> We are using a GeoNode 2.4 instance with about 300 vector and 30
>>>>>> raster layers. Everything works fine except the WMS
>>>>>> GetCapabilities response on GeoExplorer. It takes about 3 minutes
>>>>>> to load WMS GetCapabilities document. The version of GeoServer
>>>>>> that is used by GeoNode is 2.7.
>>>>>> I have limited the SRSs from WMS GeoServer admin page but the
>>>>>> result is the same.
>>>>>> I posted a question on GIS stackoverflow (
>>>>>> https://gis.stackexchange.com/questions/303652/geoservers-wms-getcapabilities-request-takes-too-long-to-respond?noredirect=1#comment489418_303652
>>>>>> ) for this issue and it is proposed to upgrade GeoServer to the
>>>>>> current version (2.13).
>>>>>> I think that it's not the only solution because I searched in
>>>>>> other GeoNode instances (from GeoNode Gallery) and there are many
>>>>>> instances with GeoServer 2.7 and many layers stored in which WMS
>>>>>> GetCapabilities is loaded very fast on GeoExplorer.
>>>>>> Any suggestions ?
>>>>>> Thank you in advance !
>>>>>> George
>>>>>> Πετράκης Γεώργιος
>>>>>> Αγρ & Τοπογράφος Μηχανικός ΕΜΠ
>>>>>> MSc Γεωτεχνολογία & Περιβάλλον
>>>>>> Πλ. Ελευθερίας 29Α (Μέγαρο Ντορέ)
>>>>>> Τηλ: 2810-288363
>>>>>> Κιν: 6984871889
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181123/5a68f637/attachment-0001.html>
More information about the geonode-users mailing list
