[GeoNode-users] Geonode 2.10RC4 Layer Upload Method
Paolo Corti pcorti at gmail.com
Mon Nov 26 08:25:10 PST 2018
Hello
yes this is correct: local_settings.py is imported in the geonode-project
looking at current code base.
If you are not using a geonode-project you can try to import in the geonode
settings.py file by forking it (not recommended)
best regards
Paolo
On Wed, Nov 21, 2018 at 11:37 PM aditya fikri ghozali <
adityafikrighozali at gmail.com> wrote:
> Thank you Paulo,
> I've already changing DATABASE and OGC_SERVER on local_settings.py
> accordingly.
> Then I also change the DATABASE in settings.py, it still not working
> But i lately find out there is also OGC_SERVER on settings.py and i must
> change that. And then it works.
> It seems like in 2.10RC4 version local_settings.py somehow will not
> override settings.py.
> Is this an Issue? or it's because different version of django?
> Best Regards,
> *Aditya Fikri Ghozali*
> Bachelor of Geodesy and Geomatics Engineering
> e-mail: adityafikrighozali at gmail.com
>  | www.adityafikrighozali.com <http://www.adityafikrighozali.com>
>           <https://www.facebook.com/welcomemybest>
> <https://www.linkedin.com/in/fikriaditya/>
> <https://www.youtube.com/user/adityafikri/>
> <https://medium.com/@adityafikrighozali>
> On Wed, Nov 21, 2018 at 11:33 PM Paolo Corti <pcorti at gmail.com> wrote:
>> Hello
>> this is how to set GeoNode 2.10rc to use PostGIS: you need to change
>> DATABASES at the start of your project settings file:
>> DATABASES = {
>>     'default': {
>>          'ENGINE': 'django.contrib.gis.db.backends.postgis',
>>          'NAME': 'geonode',
>>          'USER': 'geonode',
>>          'PASSWORD': '***',
>>          'HOST' : 'localhost',
>>          'PORT' : '5432',
>>          'CONN_TOUT': 900,
>>     # vector datastore for uploads
>>     'data' : {
>>         'NAME': 'data',
>>         'USER' : 'geonode',
>>         'PASSWORD' : '***',
>>         'PORT' : '5432',
>>         'CONN_TOUT': 900,
>> 'default' is the database containing the GeoNode Django tables. 'data' is
>> the PostGIS database containing the vector data.
>> You also need to override OGC_SERVER in your settings file, and set
>> 'DATASTORE' to the name of the database containing the data ('data' in the
>> above case).
>> Hope this helps
>> best
>> Paolo
>> On Wed, Nov 21, 2018 at 7:04 AM aditya fikri ghozali <
>>> Dear all,
>>> Sorry for promoting my question again, but i think is a different case
>>> with Dejan. I am installing geonode on ubuntu 18.04. And I really need a
>>> hints to this.
>>> >>>> I have a problem with geonode uploads method on Geonode 2.10RC4. The
>>> >>>> default layer upload was geonode directly sent the file to
>>> geoserver as a
>>> >>>> new vector layer datastore. I try to make the layer upload to store
>>> it in
>>> >>>> geonode_data database which is defined as a datastore in geoserver.
>>> I've
>>> >>>> done the following configuration but not working.
>>> >>>> - migrate the dtb to postgresql (succeeded, the default dtb are now
>>> use
>>> >>>> postgresql.)
>>> >>>> - use either geoserver.sample or psql_test local_settings.
>>> >>>> - use either geonode.rest or geonode.importer as UPLOADER BACKEND.
>>> >>>> any hints? or Is there any workaround to this?
>>> >>>> Thanks  in Advance
>>> Best Regards,
>>> On Mon, Nov 19, 2018 at 6:00 PM <geonode-users-request at lists.osgeo.org>
>>> wrote:
>>>> Send geonode-users mailing list submissions to
>>>>         geonode-users at lists.osgeo.org
>>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>>         https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> or, via email, send a message with subject or body 'help' to
>>>> You can reach the person managing the list at
>>>>         geonode-users-owner at lists.osgeo.org
>>>> When replying, please edit your Subject line so it is more specific
>>>> than "Re: Contents of geonode-users digest..."
>>>> Today's Topics:
>>>>    1. Re: geonode-users Digest, Vol 46, Issue 22 (francesco bartoli)
>>>>    2. Re: geonode-users Digest, Vol 46, Issue 22 (Alessio Fabiani)
>>>> Message: 1
>>>> Date: Mon, 19 Nov 2018 11:46:26 +0100
>>>> From: francesco bartoli <xbartolone at gmail.com>
>>>> To: Paulo Frias <pfrias82 at gmail.com>
>>>> Cc: dejan.samardzic at cedis.me, geonode-users
>>>>         <geonode-users at lists.osgeo.org>
>>>> Subject: Re: [GeoNode-users] geonode-users Digest, Vol 46, Issue 22
>>>> Message-ID:
>>>> CAL6s8vD2YmXEkpBWT7189TmK7+ktORpGES2a8jTO73bKQmmaBg at mail.gmail.com>
>>>> Content-Type: text/plain; charset="utf-8"
>>>> Hi all,
>>>> I guess the issue is not strictly limited to the docker deployment. Can
>>>> you
>>>> try out with the development paver based setup and in case open an
>>>> issue on
>>>> github?
>>>> Thanks,
>>>> Francesco
>>>> Il giorno lun 19 nov 2018 alle ore 11:33 Paulo Frias <
>>>> ha scritto:
>>>> > I have the same issue.
>>>> > On Sat, 17 Nov 2018 at 20:41, Dejan Samardzic <
>>>> dejan.samardzic at cedis.me>
>>>> > wrote:
>>>> >> Dear Geonode community,
>>>> >> I have also installed Geonode ver 2.10RC4 Master branch on docker.
>>>> >> Upload of any files doesn't work at all.
>>>> >> When I go to Data -> Upload Layers -> Choose Files.....nothing happen
>>>> >> (I'm not able to choose file). Look for yourself.
>>>> >> https://www.youtube.com/watch?v=XFxC5tyQiLo
>>>> >> regards,
>>>> >> Dejan Samardžić
>>>> >> On 11/17/2018 9:00 PM, geonode-users-request at lists.osgeo.org wrote:
>>>> >> Today's Topics:
>>>> >>    1. Geonode 2.10RC4 Layer Upload Method (aditya fikri ghozali)
>>>> >> Message: 1
>>>> >> Date: Sat, 17 Nov 2018 16:15:16 +0700
>>>> >> From: aditya fikri ghozali <adityafikrighozali at gmail.com> <
>>>> >> To: geonode-users at lists.osgeo.org
>>>> >> Subject: [GeoNode-users] Geonode 2.10RC4 Layer Upload Method
>>>> >> Message-ID:
>>>> >>      <CABSG5bZCXna+eRUu=
>>>> Y+aOVUkqLmofhDR0d0aLKVkdom4Z3DdMg at mail.gmail.com> <CABSG5bZCXna+eRUu=
>>>> >> Dear all,
>>>> >> default layer upload was geonode directly sent the file to geoserver
>>>> as a
>>>> it in
>>>> I've
>>>> use
>>>> >> postgresql.)
>>>> >> Thanks  in Advance
>>>> >> Best Regards,
>>>> >>  | www.adityafikrighozali.com <http://www.adityafikrighozali.com> <
>>>> >>         <https://www.facebook.com/welcomemybest> <
>>>> https://www.facebook.com/welcomemybest><
>>>> https://www.linkedin.com/in/fikriaditya/> <
>>>> https://www.linkedin.com/in/fikriaditya/><
>>>> https://www.youtube.com/user/adityafikri/> <
>>>> https://www.youtube.com/user/adityafikri/><
>>>> https://medium.com/@adityafikrighozali> <
>>>> https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
>>>> >> Virus-free.www.avast.com<
>>>> >> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>> >> -------------- next part --------------
>>>> >> An HTML attachment was scrubbed...
>>>> >> URL: <
>>>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181117/746e4bbc/attachment-0001.html>
>>>> >> Subject: Digest Footer
>>>> >> _______________________________________________
>>>> >> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://
>>>> >> End of geonode-users Digest, Vol 46, Issue 22
>>>> >> * Dejan Samardžić* Rukovodilac Sektora za ICT / IT Manager
>>>> >> CEDIS d.o.o.
>>>> >> Ivana Milutinovića 12, 81000 Podgorica
>>>> >> gsm: +382 67 220 971
>>>> >> tel: +382 20 408 453
>>>> >> email: dejan.samardzic at cedis.me
>>>> >> web: www.cedis.me
>>>> URL: <
>>>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181119/0612ff7d/attachment-0001.html
>>>> Message: 2
>>>> Date: Mon, 19 Nov 2018 12:00:32 +0100
>>>> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>>>> Message-ID:
>>>> CAM7ZvL+VoHCoND22QSHtF_h+UKAPx47JNsXc_30gznH1C8_y8w at mail.gmail.com>
>>>> Hi,
>>>> can you please open up che debug window on your browser and check for
>>>> any
>>>> Javascript issue?
>>>> (see "console -> errors")
>>>> Il giorno lun 19 nov 2018 alle ore 11:32 Paulo Frias <
>>>> >> regards,
>>>> >> Dejan Samardžić
>>>> >> Today's Topics:
>>>> >> Message: 1
>>>> >> Message-ID:
>>>> >>      <CABSG5bZCXna+eRUu=
>>>> >> Dear all,
>>>> as a
>>>> it in
>>>> I've
>>>> use
>>>> >> postgresql.)
>>>> >> Thanks  in Advance
>>>> >> Best Regards,
>>>> >> URL: <
>>>> >> CEDIS d.o.o.
>>>> >> web: www.cedis.me
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V
>>>> for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE
>>>> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene
>>>> notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential
>>>> or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of
>>>> this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake,
>>>> please
>>>> notify us immediately by telephone or e-mail.
>>>> URL: <
>>>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181119/11782c66/attachment.html
>>>> End of geonode-users Digest, Vol 46, Issue 25
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181126/156d4708/attachment-0001.html>
More information about the geonode-users mailing list
