[GeoNode-users] Editing layer metadata via the geonode backend
Sam Franklin mr.samfranklin at gmail.com
Wed Nov 28 00:42:51 PST 2018
Hi Paolo. Many thanks for the prompt response.
I'll try your suggestion of a custom django command, good idea :).
Thanks so much,
Sam
Sam Franklin
On Tue, 27 Nov 2018 at 17:56, Paolo Corti <pcorti at gmail.com> wrote:
> Hi Sam
> 1. I don't think you can POST to the API as looking at CommonMetaApi
> in geonode.api.resourcebase_api I see just 'GET' in allowed_methods
> 2. I can provide you some help with this, but looking at 1. would you
> be still interested?
> 3. I would create a django management command for this purpose -
> provided that you can access to the server to run the command. Another
> approach is by using SQL
> best
> Paolo
> On Tue, Nov 27, 2018 at 9:26 AM Sam Franklin <mr.samfranklin at gmail.com>
> wrote:
> > Hi List
> > I want to edit the metadata of layers on geonode programmatically e.g.
> abstracts and ratings fields. One example is that I want to bulk update
> data abstracts for many uploaded layers.
> > I'm not sure of the best approach, so I tried using an HTTP POST request
> to the genode api, e.g. localhost/api/<some-endpoint>
> > I couldn't see a way to do this via the manage.py commandline
> application.
> > I didn't try a SQL insert/update approach, as thought the API route
> would be cleaner.
> > I attempted to construct a POST request (using POSTMAN).
> > Using a postman GET request and adding a valid sessionid cookie, I'm
> able to query a given layer (e.g. id=39) and get a JSON response of all the
> metadata using URL (get) https://localhost/api/layers/?id=39. This
> demonstrates that I can perform GET requests to the "layers" endpoint from
> outside the browser.
> > When I manually edited a layer rating via the geonode UI, I intercepted
> this output from the apache access log.
> > "POST /ratings/54/39/rate/ HTTP/1.1" 200 609 "
> https://localhost/layers/geonode:mylayer" <user-agent>
> > However, for a POST request (and adding a referer header) using URL
> https://localhost/ratings/54/39/rate/?rating=4, I receive a 403 forbidden
> error which relates to the CSRF verification, see below pasted as plain
> text body of the django response.
> > So this is obviously an authentication issue.
> > However, taking a step back, my queries are:
> > 1. Are POST requests to the API possible at all from curl or postman or
> some other client?
> > 2. Is there any documentation on geonode API i.e. obtaining a CSRF token
> via the API?
> > 3. Is there a better approach to achieving editing metadata from the
> backend?
> > Thanks in advance for any pointers.
> > Sam
> > #### POST request error
> > Forbidden (403)
> > CSRF verification failed. Request aborted.
> > Help
> > Reason given for failure:
> >     CSRF token missing or incorrect.
> > In general, this can occur when there is a genuine Cross Site Request
> Forgery, or when Django's CSRF mechanism has not been used correctly. For
> POST forms, you need to ensure:
> > Your browser is accepting cookies.
> > The view function passes a request to the template's render method.
> > In the template, there is a {% csrf_token %} template tag inside each
> POST form that targets an internal URL.
> > If you are not using CsrfViewMiddleware, then you must use csrf_protect
> on any views that use the csrf_token template tag, as well as those that
> accept the POST data.
> > You're seeing the help section of this page because you have DEBUG =
> True in your Django settings file. Change that to False, and only the
> initial error message will be displayed.
> > You can customize this page using the CSRF_FAILURE_VIEW setting.
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181128/4ed5a685/attachment.html>
More information about the geonode-users mailing list
