[GeoNode-users] Cross-site scripting test - Security related - Issue
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Oct 1 09:06:58 PDT 2018
Dear Naresh,
I have crafted a PR which mitigates the issue you reported here
https://github.com/GeoNode/geonode/pull/3952
Please take a look if it does match your needs.
Regards,
Alessio Fabiani.
Il giorno lun 1 ott 2018 alle ore 08:44 Naresh N <naresh919 at gmail.com> ha
scritto:
> Dear All,
> We have used GeoNode for development of our portal SUVIDHA. As a part of
> security we have changed the parameter value * 'limit' *in following url
> to verify c*ross- site scripting attack.*
> *Requested URL:*
> http://bhuvan-suvidha.nrsc.gov.in/api/base/?limit=10&offset=0&title__icontains=&
> *limit=10'%22()%26%25<acx><ScRiPt%20>promp*
> *t(971923)</ScRiPt>*
> &offset=0&title__icontains=e&type__in=raster&undefined=undefined
> *Response for above URL:*
> {"error": "Invalid limit '10'\"()&%<acx><ScRiPt
> >prompt(971923)</ScRiPt>' provided. Please provide a positive integer."}
> Although it is not accepted wrongly given input, but error message
> contains user given input in given format. As per cross site scripting when
> ever any meta characters( Special Characters) appears in url, *the
> application should encode the special characters. Since response not
> contained encoded user **given** input,So The given request treated as
> security alert for **cross-site** scripting attack*
> Please help me how to make all GET Request parameters to encode before
> proceeding further steps
> Is that any setting is available for making all the requested GET
> parameters to encode in GeoNode /Django?
> Thanks&Regards,
> Naresh
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181001/ea5e4ece/attachment.html>
More information about the geonode-users
