[GeoNode-users] basic authentication with GeoNode 2.8, GeoServer 2.14 and GeoFence
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Oct 2 12:45:39 PDT 2018
As an instance
http://dev.geonode.geo-solutions.it/geoserver/geonode/states/wms?request=GetCapabilities
Il giorno mar 2 ott 2018 alle ore 21:16 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Dear list
> This is most likely for Alessio, but maybe someone else in the list can
> help.
> I am experiencing this in GeoNode 2.8 and GeoServer 2.14.
> I would need to access GeoServer OGC endpoints with curl or owslib
> using basic authentication. Unfortunately this doesn't look to work
> anymore - while it was working on previous versions GeoNode/GeoServer.
> This is a sample request I do:
> curl -v -u user:password -XGET -H "Accept: text/xml"
> http://myip/geoserver/geonode/layername/wms
> I receive a 404.
> Here is what I see in GeoServer log file: https://paste.ofcode.org/
> When opening the same url in a web browser authenticated with GeoNode
> I don't get the 404.
> Any hint here? Thanks in advance!
> Paolo
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181002/93c5618d/attachment-0001.html>
More information about the geonode-users mailing list
