[GeoNode-users] basic authentication with GeoNode 2.8, GeoServer 2.14 and GeoFence
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Oct 3 06:53:07 PDT 2018
Btw Paolo.... https://github.com/GeoNode/geonode/pull/3956
Il giorno mer 3 ott 2018 alle ore 15:45 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Yes, you are right Alessio, that was!
> I upgraded the staging a few days ago and forgot to add the line with
> ip for GeoServer in the Django OAuth Toolkit application table. Now
> GetCapabilities works well again.
> Sorry for the noise and thanks again :)
> p
> On Wed, Oct 3, 2018 at 4:24 AM Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > By the way,
> > I noticed that http://128.31.22.103/geoserver Layer Preview is empty.
> > As long as this is happening that means that there's some
> misconfiguration on your security settings.
> > Moreover, any chance to update the WAR of GeoServer with the latest
> build here?
> > http://build.geonode.org/geoserver/latest/geoserver-2.14.x.war
> > Il giorno mer 3 ott 2018 alle ore 10:16 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
> >> Hi Paolo,
> >> yeps, it is quite strange indeed.
> >> It really looks to me that it is due to GeoFence rules somehow.
> Sometimes the rules of GeoFence could be a bit tricky.
> >> Any chance to send here all the rules associated to one of those layers?
> >> Il giorno mer 3 ott 2018 alle ore 01:03 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >>> Hi Alessio
> >>> all of the layers in our instance are published and advertised on
> GeoServer.
> >>> For example try this layer in our staging instance.
> >>> Layer details page in GeoNode:
> >>> http://128.31.22.103/layers/geonode:Neighborhoods_BRA_1
> >>> Layer GetCapabilities:
> http://128.31.22.103/geoserver/geonode/Neighborhoods_BRA_1/wms?service=WMS&request=GetCapabilities
> >>> The layer GetCapabilities is correctly returned when I am logged as
> >>> GeoServer admin, but it returns a 404 when I am not.
> >>> Thanks for your help!
> >>> Paolo
> >>> On Tue, Oct 2, 2018 at 4:28 PM Alessio Fabiani
> >>> > Hi Paolo,
> >>> > it is working here. Remember that the Layer must be published too,
> which means "Advertised" on GeoServer.
> >>> > Il giorno mar 2 ott 2018 alle ore 22:13 Paolo Corti <
> pcorti at gmail.com> ha scritto:
> >>> >> Hi Alessio
> >>> >> the url I am using it is correct. If I open it in an authenticated
> >>> >> browser (logged in as GeoServer admin), it returns the correct
> >>> >> GetCapabilities document.
> >>> >> Unfortunately it is not working from a not authenticated sessions. I
> >>> >> believe GeoFence is not giving access to the layer.
> >>> >> I realized that in my previous email I didn't include the correct
> link
> >>> >> to the log file https://paste.ofcode.org/3aBryGaRK7Xz3j3ySqXxfkN
> >>> >> hope this helps you to suggest a solution to this problem
> >>> >> thanks!
> >>> >> Paolo
> >>> >> On Tue, Oct 2, 2018 at 3:45 PM Alessio Fabiani
> >>> >> > As an instance
> http://dev.geonode.geo-solutions.it/geoserver/geonode/states/wms?request=GetCapabilities
> >>> >> > Il giorno mar 2 ott 2018 alle ore 21:16 Paolo Corti <
> >>> >> >> Dear list
> >>> >> >> This is most likely for Alessio, but maybe someone else in the
> list can help.
> >>> >> >> I am experiencing this in GeoNode 2.8 and GeoServer 2.14.
> >>> >> >> I would need to access GeoServer OGC endpoints with curl or
> owslib
> >>> >> >> using basic authentication. Unfortunately this doesn't look to
> work
> >>> >> >> anymore - while it was working on previous versions
> GeoNode/GeoServer.
> >>> >> >> This is a sample request I do:
> >>> >> >> curl -v -u user:password -XGET -H "Accept: text/xml"
> >>> >> >> http://myip/geoserver/geonode/layername/wms
> >>> >> >> I receive a 404.
> >>> >> >> Here is what I see in GeoServer log file:
> >>> >> >> When opening the same url in a web browser authenticated with
> GeoNode
> >>> >> >> I don't get the 404.
> >>> >> >> Any hint here? Thanks in advance!
> >>> >> >> Paolo
> >>> >> >> Paolo Corti
> >>> >> >> Geospatial software developer
> >>> >> >> web: http://www.paolocorti.net
> >>> >> >> twitter: @capooti
> >>> >> >> skype: capooti
> >>> >> >> _______________________________________________
> >>> >> >> geonode-users mailing list
> >>> >> >> geonode-users at lists.osgeo.org
> >>> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
> >>> >> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> >>> >> > Ing. Alessio Fabiani
> >>> >> > @alfa7691
> >>> >> > Founder/Technical Lead
> >>> >> > GeoSolutions S.A.S.
> >>> >> > Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> >>> >> > phone: +39 0584 962313
> >>> >> > fax:     +39 0584 1660272
> >>> >> > mob:   +39 331 6233686
> >>> >> > http://www.geo-solutions.it
> >>> >> > http://twitter.com/geosolutions_it
> >>> >> > Con riferimento alla normativa sul trattamento dei dati personali
> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
> si precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> >>> >> > This email is intended only for the person or entity to which it
> is addressed and may contain information that is privileged, confidential
> or otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> >>> >> Paolo Corti
> >>> >> twitter: @capooti
> >>> >> skype: capooti
> >>> > @alfa7691
> >>> > GeoSolutions S.A.S.
> >>> > This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> >>> Paolo Corti
> >>> twitter: @capooti
> >>> skype: capooti
> >> @alfa7691
> >> GeoSolutions S.A.S.
> >> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> > @alfa7691
> > GeoSolutions S.A.S.
> Paolo Corti
> twitter: @capooti
> skype: capooti
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181003/f8f40394/attachment-0001.html>
More information about the geonode-users mailing list
